Goto device manager , uninstall the card. go into control panel and check that the driver is uninstalled from the programs list. Swich of the pc for a minute or two then reboot Windows updares does not download drivers for graphics cards so will not install or reinstall the driver that is causing the issue, 307? Users forget to uninstall from program manger in control panel which is why the card keeps reinstalling with the undesired driver.
Please let me know what happens
b> Your display adapter is the component of your computer that allows your monitor to work. On the operating system side of things, this display adapter is controlled by a device driver. If you're having issues with your display adapter (like colors are displaying incorrectly or the screen is flickering), you can fix these problems by rolling back your device driver using the Windows Device Manager.
Open your Control Panel by clicking "Start" and then "Control Panel." Click "System." Click "Device Manager." Scroll down to the "Display Adapter" heading. On a single monitor setup, there will only be one device listed under "Display" adapter. Right-click it and click "Properties." Click the "Driver" tab. Click the "Roll Back Driver" button. This will uninstall your current display adapter driver and reinstall the last version that worked properly. This will fix the issues you were having with the device. Hope this helps
Try installing the latest audio driver. You can download the audio and device drivers from the Compaq/HP WEBsupport/download page. Make sure you select your model laptop and the Windowsdrivers you require and install them. Click on this link to download thedrivers: - www.compaq.com/country/cpq_support.html
You need the Display and Graphics drivers. Click here to go the download page. It is a good idea to update all the other drivers as well if not done already.
What year prelude? I have a 95 and I have mine setup with the headunit in the DIN where the original radio was and the brain installed behind the panel behind the drivers seat and ran the wires up under the carpet to the headunit
Hi, check if the display driver is installed or not in your computer, here is the step to check the display driver is installed or not, step 1. go to start and select control panel. step 2. double click on system. step 3. after this a window pop up select hardware. step 4. click the device manager and after this another window pop up. step 5. in this window you can display adapter on 4th row. if you cant see this display adapter row so you can see something with ? sign in other rows and you can see vga adapter or display adapter down there. if you see ? sign that mean this driver is not loaded you need to load the driver for your display driver. there is no problem in your LCD monitor.
In that case, your pc might have a conflict.. it maybe the version of the display driver.. perform a clean install on the video card driver by doing this.. assuming that your PC's OS is WinXP..
1. On your desktop right click the icon My Computer and click properties.. 2. On the System properties click Hardware then click Device Manager.. 3. On the device manager window look for the display adapters then click the + sign on the left side.. then it will shows the display adapter you have on your pc.. 4. Right click your display adapter then click uninstall.. from there your pc will remove the display adapter you select then it will ask you to reboot.. 5. Now were assuming at this time that your pc has been rebooted.. Browse your Display driver and then install..
