Bridge faucet. After using sprayer, the sprayer leaks upon turning the faucet back on. We've had it two years and was like this from the get-go. We were advised that it was a bad part inside sprayer and had that replaced, only to still have the leaky sprayer. Should we replace the whole sprayer?
SOURCE: kitchen spray not working completely.
Make sure the sprayer is clean of debris. IF YOU HAVE HARD WATER, soak in CLR overnight. If sprayer is clear then its the diverter which is more indepth thru the stem.
Phil
SOURCE: Srayer leaking down the hose from pivot joint near spray head
there is an oring in that connection that is most likey bad. turn water off and disconnect coupling to spayer. remove the black oring and match it up at your local hardware store. when installin it lubricate it with vaseline for ease of insatlltion and to help protect it during installation.
SOURCE: Side sprayer won't spray
THe diverter inside of the faucet is malfuncting. Remove and replace the diverter valve. It is located right under the spout assemble.
SOURCE: kitchen faucet leaking pull down sprayer spout type
try tightening the nut that attaches the flex line to the pull out spout
SOURCE: My single control faucet is leaking on the side,
Kohler should provide you with a rebuild kit for free. Contact them at 1-800-4KOHLER. This is the parts breakdown for your Kohler faucet.
