Question about Minolta bizhub 180 Black and White Copier
Reset error m2 in konica minolta 164
Error code m2
Norman J Weimar Jr
  • Minolta Master
  • 6,960 Answers
Replace the drum and developer first. Resetting counters with out replacing parts is not good. The machine works on base on counter info you reset counters then not replace parts the copier will adjust voltages on certain items when in fact they are same items image problems and codes.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Feb 01, 2015
5 Related Answers
Anonymous
  • 210 Answers
SOURCE: Bizhub Konica Minolta - Error Code C1183
First check the alignment front and rear of the finisher, check the finisher exit guide rollers if the paper is exiting properly, open both rear and the front cover and check the lower gears attach is the up/down drive belt. that lower gear one might be broken by the pin slot.
Posted on Jul 09, 2009
firecontrol7
Norman J Weimar Jr
  • 6960 Answers
SOURCE: Error code C5354 on our Konica Minolta machine
Ozone Ventilation Fan Motor’s failure to turn. To clear open and close the door where you place the toner.
Posted on Mar 14, 2010
firecontrol7
Norman J Weimar Jr
  • 6960 Answers
SOURCE: konica minolta bizhub 350 error code c5352
Cooling Fan fault. To clear open and closer the front door.
Posted on Apr 04, 2010
Anonymous
SOURCE: error code 0X00dc0652 on Konica Minolta Di2010
C0501
Posted on Mar 30, 2011
saeed_rahimo
saeed_rahimo
SOURCE: Konica Minolta Di450 Error C1326
how to remove di 470 minolta error c1029
Posted on Nov 03, 2012
Konica minolta bizhub 164 showing M2 maintanaince call
You need to replace 1st the consumables before simulation/reset to prevent further damage to Bizhub 164.
Mintenance call m2
M2 means Time to replace your consumables (drum,developer,cleaning blade,drum charge assy & cleaning pad) after replacement reset it to Tech rep mode.
BIZHUB 164 error M2 what have I to do
Replace the developer and the drum make sure counters are cleared first and that Gradation adj is run along with Toner adj
replace the drum and developer and then reset the counter
3helpful
Konica bizhub 164 M2
1-Press "Menu
2-press Quick settings,
3-then press right arrow key 2 times
4-press Quick settings
5-then press left arrow then right arrow key.
Stop work with error m2
clear the counters first then replace the drum and developer then run F8
17helpful
2answers
Desbloqueo del codigo m2 en konica minolta bizhub 163
Este código significa que la vida las partes de su desarrollo + unidad de imagen se ha caducado. Ahora es el momento de reemplazar las partes.
56helpful
5answers
How do I clear error message C-2558 for the Konica Minolta bizhub C253
tis error means abnormal tonder density in the balck image unit take the blacke image unit out and shake it while holding it level and put it back in the machine to reset the error code leave the machine on and open then close the front door
Minolta bizhub 180 Black and White Copier Logo
Top Minolta Office Equipment & Supplies Experts
Ekse
George Mclaughlin
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
