Go to your TV menu and see if there is an audio delay setting under the audio section or the setup menu. Some menus you can still see video while changing the delay setting until it appears synced.
It is normal and real stupid---either ignore it (I won't) or go component as in a blind test done at our shop people could not tell on identical sets on HD program which was HDMI and which was Component---most of the time they thought the component was the HDMI picture
That is very common because of video processing delay. You have to listen with either TV speakers or surround sound; but not both. Some TVs have an audion delay adjustment for TV speaker sync.
make sure the dish network menu settings in setup under audio are on high. Some tv's require it to be off. Try both and see what works. Also the delay is caused by digital conversion. new stereos have settings for this delay and they have delay boxes for sale online. You could try to change your delay settings on your stereo surround to help. I had to do this.
hi, are you trying to get sound from your TV through your home sound system? I'm not quite sure what you mean about "direct TV" thing if that is a specific term. Please ellaborate.
If you have a line (audio) output on your TV then it could be easily connected to an auxillary line input in your sound system controller. hope this helps..
Make sure the RCA cable is going from an audio OUT on TV or DirecTV box to a red/white (non-digital) audio IN on surround sound or home theater system.
I received an e-mail from Samsung which reads
"What you have described in your e-mail was an issue that was logged and has been investigated we have released a firmware update to resolve the issue"
also
"In order for the firmware to be updated on the unit please call our product support team on 0870 726 7864 for assistance"
Lip-sync error is a widespread problem caused when video is delayed and audio arrives too soon. Widespread enough that three different manufacturers make dedicated products to address it, in fact (see review link below for those three).
It is present to some extent in essentially all broadcasts and DVD?s. If you have a recently acquired DLP, LCD or plasma display it may have added enough additional video delay to make it noticeable but lip-sync error comes from MANY sources starting at image capture and continuing through post production and broadcast or DVD encoding and it is cumulative. There is usually enough lip-sync error in broadcasts and DVD's to cause a negative impact on viewer perception (Research done at Stanford showed this.)
Many people don't consciously notice it until it gets very large because it's such an unnatural phenomenon ( audio can't come before the action causing the sound in the real world) we apparently subconsciously avoid looking at the faces and seeing the lips move "after" the sound from them is heard. A study at Stanford proved this causes negative viewer perception even for those who don't notice it so this is something we all need to notice as you already have.
For those reading this who haven't noticed it, take a close look at the LIPS - force yourself to overcome your natural avoidance mechanism that keeps you from looking at the lips - and you will see lip-sync error you never noticed before. I think you will be amazed that you could possibly not have noticed it before. You will be seeing what JC is seeing. I even see it now on CRT TV's
and am amazed I never noticed it so it's very obvious some avoidance mechanism is at work.
And back to JC?s solution: I'd recommend one of these digital audio delay units. That way you can correct for ALL cumulative lip-sync error no matter what its source might be. Any one of these units reviewed will correct it ALL.
With any one of these units you can adjust for perfect lip-sync at the start of each DVD or broadcast and not disturb the image you are watching during that fine adjustment. I have had a Felston DD340 since 2004 (three generations earlier than the DD740 covered in the review) but it still has the most important feature of all these units from these three different manufacturers which is their "plus and minus" buttons on their remotes that allow you to tweak the delay while watching your material without upsetting the video your are watching.
My av receiver has a built in delay of 80 ms which isn't even enough audio delay to offset the video delay my plasma display adds but even if it were it isn't practical to adjust it for the changes in lip-sync error from program to program and DVD to DVD since it overlays the screen with menus when making the delay adjustment. With my DD340 (and any of the units reviewed) all you have to do is press the plus or minus button until you get perfect sync.
Here is the review I mentioned:
[URL="http://www.audaud.com/article.php?ArticleID=3011"]
