Question about Dacor EHD3618SS Kitchen Hood
Spring on light bulb trim ring on Dacor vent hood
6ya staff
SOURCE:
Anonymous
SOURCE: took off trim around lightbulb
Place the circle of the springs on the two small post that are in the center piece of the trim that heads into the hood, make sure that the two legs of the springs are to the outside of the post. The small legs should lay against outside the center piece. The larger legs should be angled downward. Look in the hood and you should see a piece of metal with a central vertical opening on each side. Take the trim piece with the springs attached and lift the wings of the springs so that they enter the slits. The important part is that the small legs of the springs must be placed against the outside surtace of the hood. As you push the trim piece in the hood the wings of the spring will be forced down through the slits by the pressure of the small legs of the spring against the exterior of the surface of the hood. This pressure will keep the trim piece in place. It may help to remove the filters so that you can see inside of the hood. Make sure that the small legs of the spring are against the outside surface of the hood or there will not be any resistance to create pressure by the springs.
Posted on Jun 04, 2009
Anonymous
SOURCE: Dacor oven light bulb
Yeah, it's a rip-off isn't it? Been there. :-( Find the bulb part number or electrical values and search eBay. I think this is what you're looking for:
G4 halogen 12v 10w, dacor part 86364.
A search right now shows multiple vendors offering 10-piece packs for $7.00 including shipping. I'm about to order a set myself.
Posted on Nov 24, 2009
arikrom
911 SERVICE TODAY
  • 528 Answers
SOURCE: How do you get the light bulb out of a dacor hood?
Using your finger nail or a small flat-head screwdriver, gently depress lens retainer tabs.
Posted on Jan 23, 2010
stanarnold1
SOURCE: What if you don't have the suction cup/light
not certain about the afore mentioned resolution...but here is how i did it...i buy work gloves with a latex rubber coating...i put a pair of these on and was able to get a good grip with my fingers to spin the light out of the socket....the cover lens popped off....but that was ok...i got a better grip on the inside of the light...came right out. i will certainly be applying some wd40 to the next bulb i put in....
Posted on Sep 06, 2010
Axel Gringmuth
  • 54 Answers
SOURCE: can't replace light bulb for dacor hood it's 4
did you try to remove the filters to get to the bulbs?
Posted on Jan 23, 2011
Best (Broan) K260A - I tried to change the bulb as well....completely inaccessible to change with hands (bulb is set deeper in hood, not even flush) tried gloves, rubber jar opener but cannot get access to...
The lamp holder assembly snaps into a hole in the range hood with spring clips. To remove the light bulbs, you simply push and turn, like older, bayonet style automotive turn signal bulbs. It seems you have broken your lamp holder assembly. Just break the trim ring so it can be removed, or you can try to take it out reverse polish style by releasing the spring clips from the middle inwards. Once the trim ring is loose, you can extract the body of the lamp holder through the hole... the wires will be barely long enough to stick out the hole if you are lucky. If you are crafty, you may fashion a repair on the separated lamp socket assembly. If not, your replacement part number is SV16569. just call nutone-broan at 800-558-1711 and they will be glad to ship you a new lamp shell socket trim assembly.
25439092-xipalmoknr3fbjmp51kycajc-3-0.jpg Retail on that part is around $50.
http://cdn.appliancepartspros.com/images/product/cache/broan-light-fixture-assy-sv16569-ap5178165_01_l.jpg
Feb 16, 2015 | Cars & Trucks
How do i replace a head light, high beam
remove trim piece surrounding light, this is like 4 star bolts in trim and 2 in top of trim under hood, once removed this will allow access to small screws holding light bulb ring, remove screws and un plug light . replace in reverse order.
Mar 16, 2011 | 1991 Chevrolet K1500
Can't replace light bulb for dacor hood it's 4 yrs old
Jan 23, 2011 | Dacor EHD3618SS Kitchen Hood
We can't unscrew the bulb from our ihl48 dacor vent hood insert. Someone said to just unscrew it like a light bulb in a lamp but that isn't working. We are afraid to torque it any harder. Any suggestions?
Hello. Be sure to kill the power to the hood at the breaker. Then back to the bulb.
Yes it does unscrew like any bulb. [right is tight and left is loose]. Wear a glove on the hand you will unscrew the bulb with. If it does break, no problem; then use a pair of needle nosed vise grips to grab hold of the metal threaded ring and unscrew it. Often times these bulbs are exposed to so much moisture that they corrode resulting in the difficulty you are having.
4 thumbs up please. ty Joe
Oct 23, 2010 | Kitchen Ranges
How do you get the light bulb out of the hood?
there is a tool (suction cup) that dacor provides with unit or you can order the "kit" online for $30. i used some gloves with latex coating on palms to get "decent grip" to spin it out. that stainless stell rim actually pops out on my ventilation hood....it is similar to recessed lighting baffles...spring loaded....it may give you a bit more room to manuever your fingers.
Sep 30, 2009 | Dacor EHD3618SS Kitchen Hood
How do i replace the halogen light bulb?
turn it off and light usually just pull off and if has lens most of the time they unsnap.
Jul 04, 2009 | Dacor IVSR1 Integrated Ventilation with...
Took off trim around lightbulb
Mar 16, 2009 | Dacor EHD3618SS Kitchen Hood
How do you take out light ballbs from dacor hod fan
To replace the light bulb:
1. Remove the right filter and turn off the main power
switch.
2. Gently push the suction cup on the light replacement
tool A (provided with you range hood)
onto the lens of the light bulb B .
3. Turn the tool counter-clockwise until the bulb
comes loose.
4. Remove the tool from the bulb and put it on the
lens of the replacement bulb.
5. Screw the new bulb into the light fixture clockwise
until it is tight. Turn on power at the fuse or junction
box. Turn on the main power switch and touch
the light key to make sure it is working.
6. Replace the filter.
You can download the manual here.
Good Luck And please Rate FixYa!
Dec 19, 2008 | Dacor EHD3618SS Kitchen Hood
Dacor IVS1 Vent Hood - How to change a light bulb?
Buylighting.com, JDR120V-75W-E27CG...also comes in 50 watt. They aren't inexpensive, but if installed properly, will last a while. We have a little suction cup to take them out and put them in. It came with the range hood. If you get fingerprints on a halogen bulb, it can blow out quicker.
Dec 30, 2007 | Kitchen Ranges
Halogen
sorry but when you have speciality fixtures you have to pay what ever price places want .. FIXYA does not search for sources for anyone . try google, try amazon, try ebay Google Amazon com Online Shopping for Electronics Apparel Computers Books DVDs... eBayeBay many bulbs sites online
Jan 12, 2018 | Dacor EHD3618SS Kitchen Hood
Dacor EHD3618SS Kitchen Hood Logo
1,416 people viewed this question
Top Dacor Kitchen Ranges Experts
Ekse
Marvin
Marvin
Paul Carew
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
