Question about Minolta Maxxum 7000 35mm SLR Camera
Film wont rewind automatically - Minolta Maxxum 7000 35mm SLR Camera
2 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 44 Answers
SOURCE: Camera keeps rewinding film
Check the manual rewind button on the bottom plate of the camera. Make sure the button is not jammed under the edge of the button opening. If it is you might be able to carefully pry it out with a sharp pin or tooth pick (be careful not to pierce the button or you could damage the circuit board underneath) Or you could remove the bottom plate and reseat the button (be careful of a loose spring to the film door latch)
Posted on Dec 12, 2008
Film rewinds when loaded
Align film leader at mark, then close the camera back for prewind loading. Film rewinds as each shot is exposed. Built-in motor for automatic winding/rewinding. Film advance: Automatic. Single-frame and continuous (1 fps). Automatically rewinds film leader into cartridge when designated number of frames have been exposed (midroll rewind available).
sorce: http://www.canon.com/camera-museum/camera/film/data/1996-2000/1999_eos3000.html?p=2
Canon Camera Museum Camera Hall Film Cameras
good luck
Dec 20, 2014 | Canon EOS-AE-1 35mm SLR Camera
How do u get the camera 2 rewind
Usually the automatic rewind starts when the film roll has come to the end. You can rewind also before that by a rewinding button you'll find usually somewhere in the camera body.
To rewind manually, press the film release button (consult the manual if you don't find it) and use the rewinding lever to rewind the film. See this for inspiration: http://www.ehow.com/how_2028878_film-mm-manual-slr-camera.html
Jun 19, 2010 | Nikon Photography
Canon t50 wont load film
Take the film a little further almost inside the chamber and close the door, it's probably automatic rewinder can't find your film.
Jul 23, 2009 | Photography
Film automatically rewinds upon loading
Hi. Check that the manual rewind button or whayever is not stuck.
Jul 22, 2009 | Canon EOS Rebel G 35mm SLR Camera
FILM WILL NOT REWIND
On the N80 - there are custom functions you can set in terms of when a film rewinds. Normally it is default to rewinding automatically at the end of a film. If this setting has been changed, or you want to rewind a film before the end - you need to press two buttons and hold them, at the same time.
The first button is the LCD backlight button next to the LCD, and the second is the flash sync button on the rear of the camera. Both should have a little red film symbol on them. Press them both and hold them, and the film should begin to rewind.
May 21, 2009 | Nikon N80 35mm SLR Camera
Can't rewind film
It should automatically rewind when the roll is at the end. For mid-roll rewind press both the rewind buttons simultaneously for about 1 sec and the film will rewind.
May 21, 2009 | Nikon F80 35mm SLR Camera
Film rolls back automaticaly
The camera shouldn't be doing this, assuming you're using 36 exposure (or 24 exposure) film. You may want to set a custom function to prevent automatic rewind -- you would have to rewind the film yourself by pressing the rewind button.
To do this:
1. Under the palm grip, press the 'CF' (custom function) button.
2. Use the main dial to select 'F1' in the LCD. It should show a '0' below the 'F1'.
3. Press the 'CF' button to change the '0' to a '1'.
4. Press the shutter button half way to save the change and exit the custom function setting mode.
If you want to stop the rewind with the film leader still exposed (film doesn't rewind entirely into the cannister), use the same steps but set custom function 'F2' to a value of '1'.
Mar 17, 2009 | Canon EOS-1N RS 35mm SLR Camera
Film wont rewind
nadyne,
manual rewind is next to lcd panel right side. hold the button down for 3sec. the re-wind symbol will be displayed on the lcd panel.while holding down the re-wind button depress the shutter button. film will re-wind.
Dec 15, 2008 | Pentax IQZoom 928 35mm Point and Shoot...
Camera Rewinds New Roll of Film
Check the camera and the manual to see if there is a control to override the auto rewind; it may be set to rewind. Other than that, check Mikon's website for support info.
Jun 16, 2007 | Nikon N55 35mm SLR Camera
Minolta Maxxum 7000 35mm SLR Camera Logo
79 people viewed this question
Top Minolta Photography Experts
Ekse
Parshiv Luthra
Are you a Minolta Photography Expert? Answer questions, earn points and help others
