SOURCE: television hlp5063wx/xaa model No
This is very common in Samsung DLPs. The DMD board may be going bad or it could be one of the fans that cool the engine while it is running is going bad (even though the fan looks like it is running, it is not running fast enough to cool the engine). Just before it shuts down your picture should read at the bottom of your screen which fan is bad. But I have found that does not alway happen.
SOURCE: no picture on samsung hlp5063wx/xaa
to test this set
unpug the 4 pin conector labeld + and _ 20v on the cg convergence module
if set turns on, the problem is that modual
repaie
replace bolth convergence IC'c stk392-040
also check all 3.9 ohm resistors and both pico fuses.
regards,
daniel.
SOURCE: I have a Samsung HLP5063wx xaa and I am getting a
I fixed it, if anyone is having this problem, you will have to tell your Directv box to only accept 720p resolution, I only have one line hooked up to my Hd-DVR right now and I had to tell the Directv box that it was on a Single tuner not Dual, I re-booted the directv box and everything works. I hope this helps anyone w/ an older model DLP, It took me hours on the internet to find the answers I needed.
SOURCE: Tv keeps turning off
Lamp! Or defective Lamp Fan that cools Lamp, Call Encompass Parts or visit them on their website.
1-800-638-3328
SOURCE: Samsung HLP5063WX/XAA 50
Bad color wheel.
Testimonial: "Diagnosis was on the money, ordered the color wheel on-line and installed it myself. TV is as good as new. Thanks!"
