TV NOT CONNECTING TO VIEW BOX. REMOTE DOES NOT TURN ON THE CHANNELS. CANNOT SELECT PROGRAMMES.HAS MY TV GIVEN UP ALTOGETHER? OR IS IT A TUNING PROBLEM?
SOURCE: Dark horizontal lines on Sony KLV-26HG2 LCD TV screen
If you can fix it by yourself, there is a problem in horizontal circuit panel, you need to check that in series because the part appear visbly good but when tested by the exact tester you register busted. that should be replaced immediately. Check also the vertical panel parts of the circuit. but if hard you do the job you may consult the service center of your TV or the vendor of the TV.
ps. please don't rate me if you are not convince of my suggestion.
best regards, melnavz
SOURCE: TV not finding Digital Channels from Cable Box
We have Comcast and we plugged the cable straight into our Bravia, searched for Digital Channels and it found 131. We actually get all the HD channels that we had using the box, plus a few more. It's worth a try.
SOURCE: KDL-32XBR6
Try resetting the TV by holding down the "up" button on the remote (with the TV powered on) and then, while you hold down the up button on the remote, hit the power button on the TV. This should do a "factory reset" which will wipe all settings in the TV. There is no reason why the TV should not "remember the last input it was on when it was ;last turned off. Also be sure that the TV is not plugged into a switched AC outlet, like the outlet on the back of the cable bix. The TV should be plugged into an output that receives power at all times.
SOURCE: How to set SONY TV # KLV-S32A10 to receive HDTV channels?
the new lcd tv you have will pick up hd channels. run the autoprogramming for the channels for sd and hd. be prepared for about a 20 minute wait
SOURCE: Digital tuning is failing
The retuning process is as follows:
If you wish to CANCEL the auto tuning process whilst it is processing then press the BLUE button at any time.
You may lose some channels when you retune the TV as the channels have been rearranged. To locate them look at the EPG although you may still find that some channels are no longer available on FREEVIEW. See the following link for additional information
http://www.freeview.co.uk/_retuneinfo/
If the above process does not work then check the link above for additional information and also visit the accompanying site links below to find more information for your model of TV / FREEVIEW box.
For troubleshooting the retune procedure visit http://tvretune.co.uk/troubleshooting/
For specific model information visit http://tvretune.co.uk/productmanuals/
