Panasonic PT-50LCX63 50" Rear Projection Television Logo
A
Anonymous Posted on Jan 12, 2014
Ballast kit for panasonic52lcx65 - Panasonic PT-50LCX63 50" Rear Projection Television
I just replaced my headlight harnesses because of dim lights new bulbs as well now my low beams and high beams are reversed and my lights are extremely dim what could have caused this
1. My HID Kit or LED Kit does not turn on at all. If you install your HID kit or LED kit and they do not turn on you may have a reverse polarity issue. What this means is the power and ground wires of your vehicle's stock harness are reversed.
To reverse polarity on HID headlights, you must rotate the 2-pin oval connector on the HID ballast by 180 degrees in order to reverse the orientation of the plug.
To reverse polarity on LED headlights, you simply rotate the connector which plugs to your vehicle's factory harness by 180 degrees.
This problem is unrelated to the HID kit or LED Kit. It is an issue with the vehicle's factory wiring orientation. Halogen bulbs are not affected by polarity therefore some car manufacturer may have their polarity reversed.
If your HID kit or LED kit still doesn't light up after reversing the polarity, your headlight fuse might be too weak. Upping the fuse by 5 amps might do the trick.
2. My HID Bi-Xenon high beams or low beams are not working or are inverted. This is a similar issue as above, the polarity of the connector's pins are not correctly aligned. Bi-Xenon HID kits have 3 pins on the harness connector for ground, low beam and high beam connections. You will need to release the pins inside the connector and reorder them. You may need several tries to find the proper orientation. Look inside the connector and with a precision screwdriver you can release the pins and reverse the wires.
3. My HID lights are flickering. Flickering usually means the car is unable to supply enough power to the ballast. You can easily test this by connecting the HID kit directly to the car battery. If the kit works, it is a power issue. To resolve this, you will need a wiring harness.
If your car has Daytime Running Lights (DRL) flickering is usually caused by the lower voltage needed to run the DRL at half power. The car's factory harness does not provide enough power to the ballasts. If the flickering is caused by the DRL you will need a wiring harness or have the DRL disabled (this may not be legal in all areas).
Flickering can also be caused by the vehicle's onboard computer failing self-check test due to the new HID kit you just installed. This can easily be corrected with a set of warning cancellers (capacitors).
4. My LED headlights are flickering. LED lights may flicker on some vehicles, this is caused by the vehicle's onboard computer failing self-check test due to the new LED kit you just installed. This can easily be corrected by adding a set of warning cancellers (capacitors) to your setup.
5. My HID kit works sporadically. If only one side turns on from time to time or your lights work inconsistently, you probably have a power issue. You will need a wiring harness to power your HID kit directly from the car's battery.
If you install the wiring harness and still experience intermittent firing, please check your wiring connections. Make sure the power terminal is properly connected to your car battery and that the wiring harness is securely grounded.
6. Only one side is working on my HID kit or LED kit. If one side sometimes doesn't turn on it could be caused by a bad bulb, HID ballast, LED driver or wiring. To help identify which component is defective follow these steps.
  1. Swap the ignitors to opposing sides (not applicable for LED kits). If the problem is reversed, you might have a bad ignitor.
    • This step will check if you have a bad ignitor. The ignitor is the black rectangular box that is plugged between the ballast and the bulbs. To perform this test, please swap your ignitors to opposing sides and note what happens to your kit.
  2. Swap the HID ballasts or LED drivers to opposing sides. If the problem is reversed, you might have a bad ballast.
    • This step will check if you have a bad HID ballast or LED driver. The HID ballasts or LED drivers are the two metal boxes that came with your kit. To perform this test, please swap your HID ballast or LED driver to opposing sides and note what happens to your kit.
  3. Swap the HID or LED bulbs to opposing sides. If the problem is reversed, you might have a bad bulb.
    • This step will check if you have a bad bulb. To perform this test, please swap your bulbs to opposing sides and note what happens to your kit.
  4. If none of the above helps, please check for loose connections. If you installed a power relay harness with your HID kit, make sure you have properly grounded the harness.
tip
Lamp vs Ballast
This is to help explain the short lives of Lamps.
WARRANTY: If a lamp fails within the first year replace Lamp and Ballast.
If Lamp explodes do not replace Ballast only lamp, but if lamp didn’t explode replace both.
If you experience more than one Lamp failure within one year of use replace the Ballast.
The Panasonic Brand offers a Ballast repair kit (LSUC0022), it only works about 20% of the time.
I would not recommend this replacement kit. It will get you past the 30-45 day warranty period in most cases but it will not be the proper FIX to the customer’s unit and they will only call you back or (most important) call another Service Center.
I have experienced maybe 100 customers that had other Service Companies come out and only replace the Lamp. When the Lamp and Ballast should have been replaced.
I hope this helps the Customers and the Technicians in their judgment.
If I was redundant I apologize, just trying to help.
Good Day, big IRISH
on Dec 09, 2009 • Televison & Video
Ballast went out on my02 745i.what is cheapest way to fix this?how much are hid conversion kits?
you can find a used ballast on ebay or hid conversion kit for little as $49 USD! eBayeBay
How do I wire a ge ballast p.n.532-2995?
Your ballast kit replacement has a diagram in the box. Make sure you get the correct ballast kit. The diagram is pretty complicated, unless you know how to read prints.
Oct 16, 2014 • Home
1helpful
89 jeep wrangler was carburated now has a Howell throttle body injection kit (kit was installed years ago) jeep has sat for 10 years now it will start but will not stay running without holding the key in...
check the ballast resistor near the coil. white thing with wires...
run a wire from the +battery to the +coil and test (no more than 30 seconds)
if it works, replace the ballast resistor.
ballast should have 12v on one side and 7v on the other side with the ignition on.
I need a replacement ballast and capacitor for a 400W metal halide outside light, I need to know who would carry it and also a wiring diagram
most home depots will have a replacement ballast for this light, inside of box will have the correct wiring diagram, and how to wire it, if not sure as to how to wire it call an electrician
Nov 22, 2011 • Home
Trouble with tv coming on to long and new bulb didn't work
Is the lamp light blinking twice every 5 seconds or once every 5. Once every 5 sec. lamp failure,...twice every 5 sec.. ballast or thermal fuse. The ballast is discontinued and must be rebuilt or purchased used,.....try Ebay. NO TV REPAIR SHOP IS GOING TO HAVE THE BALLAST! They may be prudent enough to check into and find the rebuild kit for the ballast. FYI a rebuilt ballast costs around $175.00 ,....the rebuild kit costs anywhere from $12.00-$55.00
2answers
Just replaced circline bulb and the new one only lights up dimly within 2 inches of where the plug goes. any advice?
I had same problem. The ballast is bad and I'm lloking to see if I can get just the ballast. I know the ballast is bad because I had an identical light kit that I hadn't installed on another light yet and used it to see if the first ballast was bad. It was. I suspect I (we) will have to get a new light kit. That kit won't be anything fancy, just something that will take a regular lamp.
3answers
Where can i buy the ballast repair kit for the PT-50LC13 tv?
try these guys out
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&rd=1&item=150273671347&ssPageName=STRK:MEWA:IT&ih=005
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
