Question about Beverage-Air BM23
The fan inside runs all the time
Should the fan on the in side run all the time ?
Where can I get a cooling fan wiring diagram?
The cooling fans should come with a sensor and tells fans to come on at certain temperature
Jan 02, 2016 | 1998 Plymouth Voyager
I have a Rheem Heat Pump unit. This winter, the outside unit fan at times trips off, but the inside unit keeps running continuously. I woke up one morning & it was 62 in the house. The inside unit ran...
Dear Friend!
Due to very low ambient temp, the fan will not run. Once the pressure build up, it's automatically run for some time and again cut off. But if you keep Heat mode and still tem not raised in your room means the reversable valve not working and hence the compressor and out side fan also will not work. Keep "Heat" mode and temp setting +29 to get better heat. Hope is it helpful?
Dec 10, 2010 | Heating & Cooling
The fan on my Side by side GE Hotpoint HSM25GFRFSA refidgerator was making a constant whining noise from the condenser fan. I replaced the fan and the nose stopped but it seams the fan is running...
the fan only runs when the compressor runs . are the coils clean. and if fan was bad maybe it was running all the time . run time is controled by the min pc control. .it may have to be replaced it is located in the back on the left side under the plate cover .. mm hope this helped .
Oct 21, 2010 | GE HSM25GFTSA Side by Side Refrigerator
Inside fan never shuts off. Freezes fine.
The fan is controlled by the by the electronic control located in the back by the compressor.
If the fan is running all the time there is something we need to determine before replacing parts.
Is the compressor also running all the time? The inside fan should run at the same time as the compressor, if they are both running then check and clean the coils behind the freezer. If they are clean and both running then check the door seal to make sure it is not broken or torn. If all these are okay then the compressor is just wearing out and getting inefficient.
If the compressor is not running and the inside fan is running the problem is within the control board down by the compressor, this is a replace only component and runs about $180.00
Apr 22, 2010 | Frigidaire 20.3 cu. ft. Upright Freezer...
GE side by side TFX22RLC
If the condenser fan is not running while the compressor is running could damage the compressors overload. Yes it's a serious problem if not repaired soon. (Unplug until repaired.) This can cause a weakened internal overload inside the compressor. Thanks, Sea Breeze
Sep 21, 2009 | Refrigerators
Upright freezer hot to the touch on the sides.
inspect the unit for a fan near the compressor not to be alarmed some do not have a fan if so insure that it is running while the compressor is running also some defrost problems will cause this the unit runs for a long time heating the compressor and by way passing the heat along
Aug 13, 2009 | Freezers
Our 4 year old GE side by side frig suddenly warmed to 64 degrees. Freezer stopped freezing and is at 43. Motor is running.
Really need to know what motor(s) are running (compressor, evap fan inside freezer compartment, condenser fan under fridge)?? Of course, check your temperature (thermostat) settings. Side-by-sides usually have 2 of them. They should be labled for refridgerator and freezer. The freezer control usually only opens a baffle from the freezer compartment to the refridge compartment. The refrigerator temp control is the one that controls the compressor on-off cycles and the temp of refrig compartment (this keeps the refrig compartment from freezing the milk and cokes) If the freezer control/baffle is set too far open, this will cause the refrig temp control to shut off too soon for the freezer temp to get low enough. These controls can get bumped out of the correct setting accidently from time to time.
To check the following, the fridge has to be running, or in a condition where it "should be" running: If compressor is running (condenser fan should be too), check if evaporator fan (inside freezer) is running. Open (freezer) door and hold door light switch in when you check evaporator fan operation (some fans stop when door is open) If it is not running you may have a bad evaporator fan motor. It could also be a bad defrost timer, causing the evaporator (also inside back of freezer) to ice-up. This blocks the air flow over evap. Also, there is a defrost terminator switch on the evaporator coil that stops the defrost cycle when coil is clear of ice/frost (but timer hasn't ended defrost cycle). If it is defective, that could also keep the fridge from going into the defrost cycle, or taking it out too soon. If it is the timer, change the defrost terminator as well. Depending on how handy you are, you may be able to check/change any of these parts yourself. If you don't know much about elecrical stuff, you should leave it to a repair tech. Hope this helps.
Jun 25, 2009 | GE Refrigerators
Freezer dying first, fridge failing...
Is the compressor running. also check to see if the fan next to compressor is running. They should both run at same time..is the compressor fan running and compressor not? Could be the compressor start relay. Next, is there frost buildup on inside back wall of freezer? If so u may have a defrost control out or defrost heater or defrost terminating thermostat out. Greg
Jun 11, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Inside fans not running
verify wiring probably lose wire(s) in movement
Apr 21, 2008 | True T-49 Side by Side Refrigerator...
Beverage-Air BM23 Logo
52 people viewed this question
Top Beverage-Air Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Marvin
Marvin
Are you a Beverage-Air Refrigerator Expert? Answer questions, earn points and help others
