There is a message on the screen M1 M2 M4 how i can finish
Utility button then stop 00 stop 01. Then use arrows to clear data screen then clear counters. Has the drum and developer been replace do that before clearing the counters
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: Copies shows: Call Maintenance M2
Hello, the error code M2 means that the machine needs to have maintenance done ( like tune up to a car).. The only way to clear it would be to reset the counters and the service tech mode.
SOURCE: upon turning on the machine, machine display error
M4 is maintenance counter, you clear it in service mode.
SOURCE: minolta di 181 error M4
This means that the drum has reached it life count of 80,000 copies. If your copies are good and the machine is still making copies the you can just ignore the M4 as if you are in the USA then the factory settting allows you to continue making copies. If the M4 appeared and you can NOT make copies then you will need to get into the service mode to turn the disable copy feature off or reset the count for the drum unit. Just let me know what your situation is and if need be we can walk you thru the reset. I just don't recommend this action unless it is absolutely necessary.
