Wipers wont stop need to find programmer 94 mustang
Pin Number
Circuit
Circuit Function
57 (BK)
Wiper Motor Ground (Park)
28 (BK/PK)
Wiper Module to Wiper Motor (Park Switch)
65 (DG)
Wiper Motor Power (Park Feed)
61 (Y/R)
Wiper Motor Common (RUN)
5
56 (DB/O)
Wiper Motor LO
6
58 (W)
Wiper Motor HI
Windshield Wiper System
The windshield wiper system consists of :
The windshield wiper control module is:
The windshield wiper motor is:
The turn signal and windshield wiper switch features a:
OFF/Low/High Speed
Interval
When the turn signal and windshield wiper switch is in the interval position:
While in the interval wiper mode:
Section 01-16: Wiper and Washer Systems
1994 Mustang. Workshop Manual
REMOVAL AND INSTALLATION
Windshield Wiper Control Module
The windshield wiper control module is located at the instrument panel fuse panel.
Removal and Installation Disconnect battery ground cable (14301) .
Disconnect harness connector.
Remove windshield wiper control module from bracket.
To install, reverse Removal procedure. Check wiper system operation.
Removal and Installation Disconnect the battery (10653) and remove the windshield wiper pivot arms (17526) and windshield wiper blades (17528) .
Remove the cowl vent screen (018A16) by carefully prying up on rear edge of cowl vent screen .
Remove plastic cowl extension from cowl.
Remove clip retaining windshield wiper mounting arm and pivot shaft (17566) to windshield wiper motor link.
Disconnect the linkage drive arm from the windshield wiper motor .
Disconnect the windshield wiper motor electrical connector and remove the windshield wiper motor three retaining screws. Pull the windshield wiper motor from the opening.
To install, reverse Removal procedure. Tighten all motor retaining screws to 13-17 Nm (10-12 lb-ft).
Before installing the windshield wiper pivot arm to the windshield wiper mounting arm and pivot shaft , ensure the windshield wiper motor is in PARK and the windshield wiper blades are set to Dimension X as outlined under Adjustments .
