Dishwasher will only run on Pots/Pan cycle
SOURCE: Dishwasher Making Loud High Pitched Noise.
A loud high pitch whine while running the dishwasher means that there is something caught in the chopper assembly. To get to the chopper assembly you need to take the racks out and take the pump apart from the inside of the dishwasher. The chopper assembly looks like a metal grate with holes in it. And it might not even be stuck in the grate but somewhere in the pump area due to the water being pumped out, so the best idea is to take the whole thing apart and clean everywhere. However I do not recommend doing this unless you are completely certain you will remember where the screws and gaskets go, otherwise you risk damaging your pump or house from a leak or improper installation. You have been warned.
SOURCE: Whirlpool dishwasher Fault codes
Fault code related to Flow meter. Cleaned the connections and reconnected.It worked fine for 2 weeks and failed again.Replaced the water chamber which contains the flow meter and the issue is resolved. The water chamber cost me 87euro including postage from Quinnspares in Co.Derry Ireland.
SOURCE: dishwasher keeps running in wash cycle
I lifted this off the tech sheet for your dishwasher, it explains your problem of long wash times.
Heater or temperature
sensor problem:
■ Open connection or
component in heater or
temperature sensor
circuit(s).
■ Open in heater or faulty
temperature sensor.
■ Faulty heater drive
circuit or temperature
sensor input on control
SOURCE: Whirlpool Dishwasher Not Working
Change the thermal fuse in the control and door switches. The thermal fuse is designed to fail if there is a problem with the switches.
SOURCE: Dishwasher pops the circuit breaker
Here is a tip that I wrote that will help you ti find out why the circuitbreaker is tripping.
Circuit Breaker Keeps Tripping
heatman101
