Kettler Caterpillar Excavator Logo
A
Anonymous Posted on Jan 14, 2014
Controls switch from cat to JD on a 312EL - Kettler Caterpillar Excavator
On hitachi ex120-2 how. Change from jd to cat control
You will get your solution and all info on service info, repair info, parts info, wiring/electrical/fuse diagrams, error/fault codes, torque specs, PCV,
owner's/service/repair/parts/maintenance manuals etc everything
this website www.reliable-store.com
it's a very good website for vehicle problems even as old as 1991 ford..
3answers
I have small JD tractor that stalls when I put in gear?? What s up
Most small tractors have a mechanism that increases the RPM when a load is put on the engine (putting it in gear). I suggest you go to the JD web site and enter your model number and download the manual.
If the information you need isn't there...JD is good at giving phone support to assist you in fixing your issue.
Semper Fi,
Z
Feb 01, 2018 • Garden
JD R-1 spreader controls
www.deere.com
Ask them, they made it.
L130 mower shuts down when getting off seat with parking break set and PTO disengaged. I know it's safety lock circuit problem, but I don't know how it's wired
you can bypass the seat switch and see if the switch itself is bad, I do not know on a JD but on a Cub Cadet the RMC controls the safety switches, which is a small black box with a connect plugged into it. Hope this helped Tim
Lwin brand jd-vd760 (invalid key)
sent back to mfg who not fix over phone.
2helpful
Looking for the switch to change from cat controls to john deere controls on a cat 315 excavator
Hey Rawhide.....have a Cat 315 myself and looking to do the SAME thing (just got it yesterday). Talk about confusing. I'm used to JD too, so if you hear.....please let me know and I'm going to try to find out from the guy I got it from 2morrow. I believe that it's a simple and easy fix but you never know. My email is [email protected] . Use Cat 315 in the header. Thanks (or anyone else too) Fran
1helpful
Nesesito un codigo para un dvd marca jwin grasias
Some unlock codes for Jwin DVD players are:
Jwin JD-VD100 / JD-VD703 / JD-VD753
1. Press SETUP
2. Press PREV CHAPTER, NEXT CHAPTER, PREV CHAPTER, NEXT CHAPTER, PREV CHAPTER
3. "VerX" is displayed (X=RC)
4. Select the RC with RIGHT and LEFT (255=Codefree)
5. Press RETURN
Jwin JD-VD120
1. Press SETUP
2. Press 1, 3, 6, 9
3. Current RC should be displayed
4. Select RC with UP, "DOWN" (0=codefree)
5. Press ENTER
Jwin JD-VD130
1. Method 1:Press SETUP
2. Press 1, 3, 6, 9
5. Press ENTER
1. Method 2:Open the disc tray
2. Press PROG
3. Press ENTER 3 x
4. A menu should appear.
5. Select RC with UP, "DOWN" (0=codefree)
6. Press STOP
7. Close the disc tray
Jwin JD-VD135 / JD-VD147
1. Open the disc tray
2. Press SETUP
3. Press 1, 3, 8, 9
4. Use Up/Down keys to change the region
5. Press SETUP
Jwin JD-VD140 / JD-VD501
2. Press 2, 8, 1, 2
3. Use the arrow keys to change the region (9 = multiregion)
4. Press SETUP
5. Close the disc tray
Jwin JD-VD145
2. Press 9, 7, 3, 5
3. Change the region
Jwin JD-VD200 / JD-VD203 / JD-VD500 / JD-VD503
1. (Open the disc tray)
2. Press SETUP
3. Press 1, 3, 6, 9
4. Press LEFT 3 x
5. Press RIGHT
6. A new menu entry appears (Version)
7. Select it and select RC (0=codefree)
Jwin JD-VD138 / JD-VD504 / JD-VD602 / JD-VD603 / JD-VD745 / JD-VD903
no known hacks
or you can try here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Top Kettler Toys Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Kettler Toy Expert? Answer questions, earn points and help others
