Question about Toshiba 57H82 57" Rear Projection Television
Toshiba big screen The tv is like double exposed .
Posted by penaj on
  • 1 more comment
  • taotao Nov 08, 2007
    double image in red & green......no steps taken, I don't know how to get rid of it.
  • bus56 Aug 08, 2008
    the picture is like double vision and blurry
  • jjjohn1999 Oct 06, 2008
    only the bottom portion and words are double
Dewayne Turner
  • 87 Answers
You need convergence output IC's.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
Posted on Oct 23, 2007
Anonymous
Getting double image on my toshiba 50h82 can't figure out the problem.
Posted on Jul 11, 2008
1 Related Answer
Anonymous
  • 505 Answers
SOURCE: toshiba big screen
This is likely your convergence ICs(chips). If you can bump it then the ICs (chips) are still ok, it just needs resoldering.
my company charges $300-400 for the full repair (replacing ICs, full realignment plus cleaning)
if you can find a company that will resolder for you, it could cost $100-200 maybe. if you are a handy person with soldering skills, you could repair yourself. i can instruct if needed, but convergence IC soldering requires decent soldering skills. you will find the ICs on the largest heatsink in the tv. the part number starts with STK. if you replace them, check the resistors in front of them and replace accordingly. most toshiba will blow up to 3 fuses (f850, f851, f852)
Posted on Dec 08, 2008
Old 1995 Big screen T.V.
You need a manual convergence youd have to open it up clean the color guns properly and throuroughly and manually adjust the color guns to the proper setting. maybe even any mirrors for deflection if any.
Jun 29, 2008 | Toshiba DVD Recorder AND Series2 TiVo...
Toshiba Big Screen Tv Has Bad Colors
this is a rear projection tv not lcd the color is off because the convergance chips are bad take the board out that has the tow stand up chips attached to heatsinks out order the stk number search for on google then take a om meter check all the resistors aroung the chips replace them also you must be a excellent soilder person or a tech to install and remove these chips
Oct 19, 2009 | Toshiba 32 AV 500 PG 82cm 32 in. LCD TV
Big screen TV corners of tv blue and red
I HAVE A 57" TOSHIBA REAR PROJECTION TV. HALF THE SCREEN HAS A BLUE TINT AND THE OTHER HALF IS CLEAR.
Jan 19, 2009 | Televison & Video
Toshiba big screen The tv is like double exposed . I have a toshiba big screen tv and I have double images in red and green. How do I fix this problem?
Dec 08, 2008 | Televison & Video
Toshiba big screen tv
I have a 50" big screen tv by toshiba. I need a replacement protective screen or a place I can get it.
Aug 26, 2008 | Televison & Video
Tv problem
you might have a convergence problem. it can be fixed.
Jul 10, 2008 | Toshiba 42H81 42" Rear Projection...
Screens broke
You can go to www.tritronics.com and use your model number to see if they are still available . They are somewhat easy to install by removing the speaker grille on the bottom thus exposing the screws hold the frame that secures your screens . Sometimes the screws are on the back side holding the screen . Send a picture of your tv if you think you might want to try it yourself . The screens can be expensive . Also try to call around to see if a repair shop might have some used ones that will work with your tv that are in good condition . Could save big bucks . Good luck
Feb 29, 2008 | Toshiba 42H83 42" Rear Projection...
Picture shadow on rear projection Sony big screen TV
OUR TOSHIBA HAS A DOUBLE VISION/BLURRIE PICTURE. THIS PROBLEM IS ALWAYS THERE. SOMETIMES THE PICTURE IS GREAT, BUT MOST OF THE TIME ITS BLURRIE/DOUBLE. LOOKS AS IF IT ALWAYS ON 3D!! ANY SUGGESTIONS? WE WOULD REALLY APPRECIATE ANY HELP WE CAN GET FROM ANYONE. THANK YOU!
Mar 03, 2007 | Toshiba 55H70 55" Rear Projection...
Toshiba 57H82 57" Rear Projection Television Logo
524 people viewed this question
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
