Maxi-Cosi CabrioFix (Black Reflection) Infant Car Seat Logo
Question about Maxi-Cosi CabrioFix (Black Reflection) Infant Car Seat
Remove isofix base - Maxi-Cosi CabrioFix (Black Reflection) Infant Car Seat
  • Dorel UK
    Dorel UK Aug 17, 2014
    Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Which model Maxi-Cosi base do you have?
3 Related Answers
Anonymous
  • 419 Answers
SOURCE: what's the difference between Easybase (non
The Easy Fix Base is used for cars which have isofix points in their car. The Easy Base fits into your car using the seatbelt.
Both of these bases can be used ONLY for the CabrioFix Carseat and cannot be used for the next stage seat (Group 1).
I hope this helps.
Posted on Oct 12, 2009
pan_stak
Pan Stak
  • 182 Answers
SOURCE: how do you remove the isofix base from the car
Every ISOFIX base has a button which you can press and release the base from the car seat.
Usually it's a round one at the junction of the ISOFIX base and it's LEG
Posted on Jul 29, 2011
Dorel UK
Dorel UK
  • 1637 Answers
SOURCE: Can the isofix easyfix base
Good Afternoon
The yellow plastic IsoFix guides are for assistance only when fitting the unit and make no difference to the performance. If you are able to fit the base so the indicators go green it is fine to continue using without the guides. Alternatively if you need replacement guides they can be ordered via your retailer or direct from our customer service department on 01284 413 141 Mon-Fri 8.30-4.30.
Posted on Nov 10, 2011
Why is the bottom of the isofix base is not level with the seat?
Hi Andrew
It is not possible to diagnose without inspection.
Was the unit approved for use in your vehicle on our online fitting list?
Was the unit physically fitted by a carseat fitter trained member of staff to confirm suitability prior to purchase?
Please contact us with further information so that we can best assist.
Dorel UK Customer Service
How to remove the isofix base from the car seat
Hi
Is it removing the carseat from the base or removing the base from the car that you're having difficulties with?
Maxi-Cosi Familyfix base Isofix base warning beep
Yep, there's a switch underneath to turn off the sound, but the lights will still work.
Does maxi cosi cabriofix easy base require anything to be removed from it before fixing it? we cant find where the button is that fixes it to the seat
Hi
Can you clarify - what button are you looking for?
The EasyFix base is fitted into the vehicle using the IsoFix points OR the 3 point seabelt. (Never both) The carseat then clicks onto the base and the metal rods on the underside of the CabrioFix carseat are grabbed by clamps on the base.
Can the isofix easyfix base be used safely without the isofix guides, ours are missing, thanks.
Good Afternoon
4helpful
How do you remove the isofix base from the car seat?
I have a maxi cosi cabriofix and need a base to go with it. Which base fits this model? What is the difference between the easy base and easy fix? My car does not have the iso fix adaptors so that will...
The Maxi Cosi CabrioFix can be fitted using the EasyFix base (IsoFix or seatbelt fitted) the EasyBase and EasyBase 2 (fitted with seatbelt only) or the FamilyFix base (IsoFix only). If you do not have IsoFix points you need either an EasyBase or EasyBase 2 to be fitted with seatbelt.
The yellow anchor points that attach to the car fittings and then the isofix base fits on to them. where can I get 2 more
If you mean the plastic caps that click onto the isofix points in the car, then you can buy these on eBay, just search for ISOFIX GUIDERS.
I hope this helps.
What's the difference between Easybase (non isofix) and Easyfix base (isofix)? can I use the second one for both maxi cosi cabriofix and car seat up to 3.5 year?
I hope this helps.
Top Maxi-Cosi Baby Gear Experts
Marvin
Marvin
ADMIN Andrew
ADMIN Andrew
ray gallant
Are you a Maxi-Cosi Baby Gear Expert? Answer questions, earn points and help others
