Question about Samsung R519-53S Notebook
My laptop didinot showing any wifi - Samsung R519-53S Notebook
My Dell laptop will only connect to public WiFi with limited connectivity
Follow the following steps to resolve Wifi issues on your Laptop. Open Control Panel - Select Network and Sharing Center - Manage Wireless Networks - Highlight your Wifi Network - Right Click and Remove. Reset the TCP/IP stack of the windows system with limited connection status.
My laptop is showing limited Internet access over my home WiFi - Quora
https://www.quora.com/My-laptop-is-showing-limited-Internet-access-over-my-home-W...
Nov 13, 2016 | Dell Computers & Internet
How do my turn on my wifi on this laptop?
Hi Ken, The link below is a youtube video showing how to connect your laptop to the WiFi, Also There's videos down the right side of the link that may help as well...........CHEERS..
How to connect your Laptop to Wifi
Apr 30, 2016 | Gateway M675 Notebook
Wifi wont turn on
Did it ever work?
Try taking the battery out for 5 minutes, see if that resets the wifi.
Oct 17, 2014 | Gateway NV53A24u Laptop
Email cutomer support
Go to remotes.com
Not cheap but they have remotes for thousands of units.
Oct 14, 2014 | Televison & Video
I'm using fujitsu lifebook s2020 and i have a problem with the wifi..my wifi is kind of disappeared or lost..how can i get it back? thank you
Good Day
The first thing you should check is that you WiFi is on. What I mean with that is that laptops usually have a button to switch on or off WiFi to generally save battery life. If you are sure that WiFi is on (usually the WiFi button's light is on) than check if ou can see a netwok adapter.
If you dont see it, there can be two reasons. 1. Another program which got installed on the laptop has controll over the WiFi and the WiFi will not be controlled my your Operating system. 2. Check the properties of your network place. It might contain the WiFi adapter disabled. Ceck under the properties and ut the tick poxes on "Show if adapter is connected" and "Show if there is a problem".
Last resort is to check under you Device manager (Right click My computer, Manage, Device Manager) and make sure the WiFi adapter's drivers are proberly installed.
Hope this helps
Jul 23, 2011 | Fujitsu LifeBook S2020 Notebook
My Laptop specifications are, ASUS F80Q, dual core, 3 gb ram, Windows 7 ultimate. when i first installed windows 7 (long time ago) it detected my bluetooth device, but now in the middle suddenly it...
Seems like your Bluetooth and Wifi settings are disabled from BIOS.
On laptops usually there is a setting in BIOS where you can disable/Enable Wifi+Bluetooth. Shutdown computer Turn on computer and press "F2" to go to BIOS settings Find settings for Wifi+Bluetooth and set it to default.
Save settings and restart computer You will be able to see your Bluetooth and Wifi.
Hope this works
Jun 29, 2011 | ASUS F80Q-X2AM Notebook
My netbook doesnt show any wifi connections how can they show up again?
Install wireless driver and enable wireless using function keys or button..
Apr 01, 2011 | Acer Aspire One PC Notebook
ASUS wifi switch
Make sure that wifi is enabled in wireless switch utility. You can find that in the system tray next to the clock.
May 28, 2009 | Computers & Internet
Open Questions:
See all Samsung R519-53S Notebook Questions
Samsung R519-53S Notebook Logo
21 people viewed this question
Top Samsung Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
ThaMp3Doctor
ThaMp3Doctor
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
