Question about HP Deskjet 5940 Photo InkJet Printer
WILL NOT PRINT
I PRINTED 2 PAGES AND THEN WENT BACK AND ASKED FOR A SECOND COPY AND IT WOULD NOT PRINT. THE LEFT INK INDICATER LITE CAME ON THE PRINTER, AND A MESSAGE CAME UP SAYING
"INCORRECT PRINT CARTRIDGETHE FOLLOWING PRINT CARTTRIDGE IS NOT INTENDED FOR USE IN THIS PRINTER" tHE PRINTER CARTRIDGE IN USE IS NO. HP 97. COULD THIS MEAN THE CARTRIDGE IS OUT OF INK?
Posted by IRISH-1 on
Anonymous
    Sergeant:
    Champion:
  • 214 Answers
Cartridge must be damaged and need to replace
Posted on Jul 22, 2008
Deskjet 1050A is not printing black. Help?
The black ink cartridge is cloged or empty. Try to refill it in case of empty, or clean in case of cloged ( left the printhead for 1 hour in clean solution or in hot water if you don't have )
All the best !
Jan 18, 2018 | HP Office Equipment & Supplies
Savin 9935DPE is printing one thick vertical balck line down the copy or print pages. About 2 of every 3 pages printed. What's wrong?
are you printing from Doc feeder or glas?? if from feeder then try to make a copy from the glass, does it still do it? yes problem is with drum.
No? problem is with the small scanning glass to the left, look carefully see if any spots or lines on the 1inch glas --- clean it
Sep 05, 2012 | Savin 9945dpe 9935dpe 2035dpe 2045dpe...
I cannot get my F4100 printer to print. It will scan. It will copy but not print documents from the computer. I have unplugged everything and replugged it. I have converted the document to try and print it...
Can i know what is the application you are using to print from ? Like is it Microsoft word or Excel etc.
Also, let me know your PC model and Operating system please.
Regards,
Ron
Dec 06, 2010 | HP Deskjet F4100 All-In-One InkJet Printer
My dcp165c printer print quality prints black & yellow colour. i clean print head through maintance 76 but problem cannot be solved
How is the printer printing black and yellow color? Is it a smudge?
When I print, the pages are smudged with ink. What should I do?
Description:
- If smudged stains appear at the top center of the printed page:
  • Make sure the paper is not too thick or curled.
    Also, verify that the appropriate paper is being used and that the paper type set in the machine matches the media used.
  • Make sure the paper is not curled when you print on the back side of the paper with the Print Odd Pages and Print Even Pages settings.
- If smudged stains appear at the right or left corner of the printed page:
- If smudged stains appear on the reverse side or at the bottom of the page:
NOTE: Illustrations shown below are from the representative product and may differ from your Brother machine.
  • Make sure the printer platen is not dirty with ink.
    How to clean the machine's printer platen
    1. Unplug the machine from the AC power outlet.
    2. Lift the scanner cover until it locks securely in the open position.
    3. Clean the machine's printer platen(1) and the area around it, wiping off any scattered ink with a soft, dry, lint-free cloth.
    4. Close the scanner cover.
  • Make sure you are using Genuine Brother Innobella™ Ink.
    > Brother Genuine Supplies information
  • Make sure you are using the paper support flap.
    To use the paper support flap, pull out the paper support (1) until it clicks and unfold the paper support flap(2).
Aug 03, 2010 | Brother Computers & Internet
Ink is on the back of my printed pages
open the printer and clean all rollers you find. should fix your problem if the line goes from top to bottom
Jul 20, 2009 | OKI C3200n Led Printer
Constantly cleaning the print head
I feel you should take it back. Under warrantee?
May 01, 2009 | Kodak ESP 5 Printer
Brother MFC 7820N Smudging Concern
  • Make sure the paper is not curled when you print on the back side of the paper with the Print Odd Pages and Print Even Pagessettings.
Sep 11, 2017 | Brother MFC-7820N All-In-One Laser Printer
Kodak 5100 will not print consistently
I am currently having the same problem with a 17" iMac Intel Core Duo.  The printer worked fine for a few months, now it will only print in black and white and sometimes in color that is extremely faded.  I have tried every troubleshooting tip in the book and still no luck.
Apr 28, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
HP Deskjet 5940 Photo InkJet Printer Logo
89 people viewed this question
Ekse
Thomas F. Schneider
