Disney DT1350-C 13" TV Logo
A
Anonymous Posted on Jan 11, 2014
Lost remote lost the remote to the TV and I am unable to operate the DVD and TV.
1helpful
I lost my remote for the GT1417DV and purchased a universal remote AVEX R6. I have followed the instructions to program the universal remote with my TV/DVD. So far, I can get the remote to turn on the TV...
I do not recoomend universal for this brand please check this website and buy www.remotes.com they sale only brand name remotes that came with your TV and there pretty darn cheap as far as prince no quality! You be glad you did!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
tip
Why Am I Unable To Program The RCA Remote Control To Operate My Components
Why am I unable to program the RCA remote control to operate a component? Why am I unable to program the RCA remote control to operate a component? If you are unable to program the remote control to operate a component, review the following information:
Compatibility
If none of the programming procedures work, the universal remote control may not be compatible with your components, based on the type of infrared technology and the age of the components. Some RCA universal remote controls will only work with components manufactured after 1990.
Distance
If you are testing the remote control after you have entered a code, you may be too far away from the component or you may not have the remote control aimed directly at the component. Because the remote control uses infrared (IR) technology to communicate with components, there must be an unobstructed path between the remote control and the IR sensor on the component.
Code Entry Methods
If the Direct Code Entry method was used to enter the codes for your brand and the unit is still not functioning properly, try one of the automatic code search methods instead. During automatic code search, the remote searches for the correct code to program.
Modes
For the remote control to know which component you wish to operate, you must put the remote control in the correct mode by pressing the corresponding component button.
Combo Units
To program the remote control to operate combo units, such as TV/VCR’s, TV/DVD’s, or TV/VCR/DVD’s, use the combo codes in the Code List to program the individual corresponding component buttons. Once programmed successfully, the TV button controls the TV functions on your unit, and the DVD or VCR button controls the DVD or VCR functions, respectively. The codes in the combo section should be tried first, using the Direct Code Entry method on the TV and DVD or VCR buttons. If this is unsuccessful, use one of the Code Search methods to program your combo unit.
Batteries
Make sure the batteries are new and properly installed.
Unable to programme universal remote to TV/DVD
I found that this website should have all the codes and instructions for most remotes
http://www.xdiv.com/remotes/
or http://www.remote-codes.com/
if this helps please give a fixya rating as thats how we get paid.
1helpful
Remote tv compatible codes
the default for the rh7823w remote is to operate lg tvs. Popping out the batteries should reset the default. my manual saysto select a different tv hold down the tv power button, press the number buttons for the manufacturer code then release power button.
codes are
LG/Goldstar 1(default), 2
zenith 1,3,4
samsung 6,7
sony 8,9
hitachi 4
good luck
Lost remote! How do you turn off the closed captioning?
Try using the channel down button until you reach the menu and proceed from there. Or, you can try purchasing a replacement remote.
2helpful
Unable to switch on DVD function on a Bush 14" combo
Switch on t/v press TV / DVD button on remote to ensure it is in TV mode. Select DVD by pressing
AV button once or by using input select menu
Press TV /DVD button until DVD RC appears on top left (The remote is now set to DVD mode)
Insert disc ensuring label is to rear of set and Auto play function will start
Lost remote and rca universal remote no can be programed
I used the remote control code of "69" for Thompson which makes GE & RCA according to another post. This worked to program the remote of my GO Video DVD-VCR for the TV
DVD SETUP
hi try these Code For Model RCR450 (the closest i found) Code 1000/3160/2000 for RCA TV/VCR/DVD Code 1000/3408/2000 for RCA TV/VCR/DVD http://www.rca.com/customerservice good luck windman
Top Disney Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Alexander
Are you a Disney Televison and Video Expert? Answer questions, earn points and help others
