Question about Fisher and Paykel DE06 Electric Dryer
Help with a noisy Fisher & Paykel dryer
Fisher & paykel DEO4-US6 dryer runs and heats but makes a screeching noise. help. thanks.
Posted by randyray on
  • 4 more comments
  • gsce84 Feb 24, 2008
    how do you get inside the dryer box?
  • Anonymous Nov 11, 2008
    dryer squeaks so loud that even closing the door to the laundry room does not help. Is out of warranty. Any ideas besides a new one?
  • Anonymous Mar 16, 2014
    fisher & Paykel top load tryer barely heats
  • Anonymous Mar 19, 2014
    when starting dryer cold it will usually run for a while, but when it keeps running longer it tends to shut off. Will not start again until you let it sit. for 30 or 45 min.
  • Anonymous Mar 22, 2014
    how do I reset my Dryer
  • Anonymous Mar 26, 2014
    Noisy
Anonymous
I have the same problem. Replacing the front glides (two glides cost under $20 plus labor and service call). The second time it seems to be more than the front glides. Service tech says that it is the blower moving back and forth on the motor shaft. (Because of a worn indentation on the shaft..). Therefore, he says that I must replace the motor and the blower--parts cost approx. $290, plus labor and service call. Ouch! Also says that the plastic front support piece is worn. More money! So, I am looking at a new dryer instead of trying to patch up the one I have (it's out of warranty.)
Posted on Dec 22, 2007
Screeching noise during operation of machine
If it only screeches when the drain pump is running you can spray some crc or wd40 in to the bearing on the drain pump. That usually helps. You will have to turn power off at wall, tip machine back against a wall and get at the pump underneath on the right side at the front.
Jun 24, 2017 | Fisher and Paykel Washing Machines
My Fisher Paykel is making a high pitched whine. Similar to some one running the finger around a wine glass.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Sep 07, 2011 | Fisher and Paykel DEGX2 Dryer
FPaykel Dryer model # DE05US2 is making a screeching LOUD sound ... still turns and dries just VERY VERY LOUD and high pitched squeeling
It could be bearing or guides in the drum.Go to http://fisherpaykelparts.net/techhelp/fisher-paykel-top-load-dryers-us-models/ This forum will work you through your problem
Sep 27, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Hello, My Fisher Paykel dryer is making a very loud motor noise when it is on Does this ring a bell??
The motor is going bad...
heatman101
Sep 20, 2010 | Fisher and Paykel DG06 Gas Dryer
Obnoxious screeching sound when the drum turns. Short consistent screech on revolution, which turns into one long non-stop screech. Stops after 45 seconds or so, then starts all over again with longer...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Sep 05, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Makes a scrapping sound when running. It dries okay but it makes that awful scrapping/screeching sound, especially when it reverses
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
May 20, 2010 | Fisher and Paykel DEGX1 Electric Dryer
My Fisher Paykel dryer runs as normal just doesnt put out any heat.
Usually when an electric dryer runs but stops heating, the heating element has failed and needs replacing. I don't know if you are a do-it-yourself type, but you can get the model/make/serial information and obtain the correct element at your appliance parts store.
I hope this helps... Good luck.
Oct 23, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Fisher paykel dryer DE04-US6 just get a buzz sound when i push start button.
Open up the door and push the door switch and hit the start button and try to turn the drum by the baffle in the dryer and it it starts to go then you need a new motor.
Aug 20, 2009 | Fisher and Paykel Dryers
Dryer Problem
Grinding noise most likely due to the front drum bearings worn out - result is the metal drum making contact with the rim of the from panel.
This requires a total disassembly of the dryer to investigate & likely replacement of the front slipper pads (dry nylon slipper bearings 4 x ).
This will only be a succesful repair if you stopped using the dryer the moment it started screeching.
If you have let it run, the metal-on-metal will have gouged the edge of the drum and will rip up any new replacement bearing pads.
Do not attempt this unless you are a very competent handyperson. Many screws lost, cut fingers and swear words will ensure if you are not confident in approaching this job, so either toss the dryer or get a competent repairman to do the job.
Mar 18, 2008 | Fisher and Paykel Dryers
ED55 dryer making screeching noises
sounds like the rear tub bearing has worn out that would explain the noise and if it got too bad the bearing can break causing the drum to stick and not be able to turn
Nov 26, 2007 | Fisher and Paykel DG05 Gas Dryer
Fisher and Paykel DE06 Electric Dryer Logo
879 people viewed this question
Top Fisher and Paykel Dryers Experts
Nathan Van Boven
Nathan Van Boven
Bill Eager
Dennis Boxerman
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
