Heater fan on primera nissan will not stop - Heating & Cooling
Posted by Keith Grandison on
Paul G
    Scholar:
  • 161 Answers
Sounds like a faulty switch my friend
Posted on Jan 15, 2014
How do u turn heater fan off
Does it shut off with the key out? If so you're probably ok, many cars fans do not shut off when the key is on, to constantly recirculate the air in the car.
Jul 20, 2014 | 2003 Nissan Primera
2002 nissan primera p12 blower fan for heater will not turn off nissan troubleshooting
Its either the switch , the relay, resistor , wire or blower that is shorted out. Remove the switch from the circuit if it stops the blower it was the culprit. If not move onto the relay then resistor, check circuit for shorts. Remember the blower itself could be the culprit. The name of the game here is to keep removing the items listed until the fan stops. Whatever item removed stops it has the short. If you have removed all items and fan still blows , remove fan from circuit and check it separately. Hope this helps you.
Jan 15, 2014 | Cars & Trucks
Nissan primera 2002
REMOVE INTERIOR FAN FUSE AND GET ELECTRICIAN TO CHECK ,MAY BE HEATER CONTROL UNIT OR HEATER VALVE PROBLEM
Jan 12, 2014 | Cars & Trucks
Nissan primera no heaters no sat nav no radio or cd plus the doors wont lock any solutions thanks
check all your fuses and relays could also be a short in a wire somewhere.
Feb 20, 2013 | 2003 Nissan Primera
Hi every time i switch the heater fan off it blows the resistor and heat sink nissan primera 2002
Switch is busted and sending multiple currents to the resistor. Replace switch.
Sep 18, 2010 | Infiniti G35 Cars & Trucks
Steam coming from the heating system on a 98 nissan primera 2 litre td
inside the car? probably heater core. u can try some bars leak radiator stop leak and run it for 15 minutes. This is temporary until u get it fixed
Feb 17, 2010 | 1998 Nissan Sentra
How would I install an upper suspension arm to
nissan primera in the US is called an Infiniti G20. the grinding or knocking if its coming from the front, is gonna be the tension rod bushings are warn out. get new tension rods for real cheap. thats all i can help with, suspension is my thing, motor is not.
Jul 16, 2009 | 1995 Nissan 200SX
Nissan primera gearbox
how much is the price for nissan primera 2003 gear box
Oct 06, 2008 | 2004 Nissan Armada
Primera 2002 p12 model. heater fan stopped working, checked fuses, there ok .Wondering what else to check. Fan works on auto or manual through on screen display, hope its not the computer
need more information on vehicle, my advice is to check blower motor resistor located under glove box area held by two screws into blower housing ( has about 5 wires to it ) check it for burned marks, smell, melting, or accessibly hot to the touch.
Aug 12, 2008 | 2004 Nissan Altima
Heating & Cooling Logo
107 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
