Question about Samsung SC-D353 Mini DV Digital Camcorder
Entire camera is locked up
I have a partially recorded tape in my SC-D353.  I charged the battery with the tape in the camera. After it was fully charged, I tried to use the camera.  The display flashes TAPE END! and then the eject icon flashes.  When I try to eject, the door won't open.  I can hear the mechanism trying to operate, but the door does nothing.  Also, nothing happens when I try to rewind, fast forward or play.
Posted by cagc on
  • Anonymous May 11, 2010
    THE CASSETTE COMPARTMENT FAILED .YOU MIGHT WANT TO GET A USED ONE OR SEND IN FOR REPAIR
Anonymous
  • 73 Answers
THIS IS A PROBLEM WITH SAMSUNG SCD 353 LET ME NO IF U NEED MORE REPAIRS
Posted on Mar 02, 2008
Samgung SC-D353 camcorder 'EJECT' problem
sc-d353 got wet slightly the camera part is working but good tapes display eject sign and in the middle of the screen displays the eject symbol and ...r please help
Jun 02, 2009 | Samsung SC-D353 Mini DV Digital Camcorder
Sc-d353 video transfer from Mini dv to computer
In order to transfer the taped video, the software that came with the camera, has to be installed. Once this is done, plug your camera into the computer, using the USB cord, and it should be recognized, and the software program should kick in and you can then transfer the files. Sometimes you will have to go to the actual drive itself and copy the images over to your folder of choice.
Aug 29, 2008 | Samsung SC-D353 Mini DV Digital Camcorder
Transfering the video form the cam to the computer
i have a samsung sc-d353 and i was wondering if i can transfer the video that i have recorded on the tape and transfer it on to the computer using the usb cord if so how would i go about doing this?
Mar 29, 2008 | Samsung SC-D353 Mini DV Digital Camcorder
Tape want come out
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
good luck
please mark the post with a fixya
Mar 03, 2008 | Samsung SC-D353 Mini DV Digital Camcorder
D-eject problem
try cleaning tape? maybe tape path is outta balance. try new tape?
Dec 14, 2007 | Samsung SC-D353 Mini DV Digital Camcorder
Samsung sc-d353 Eats Tapes
THIS NEEDS A NEW CASSETTE COMPARTMENT. SAMSUNG IS REALLY EXPENSIVE. YOU MIGHT TRY TO PURCHASE A USED ONE OR I MIGHT BE ABLE TO HELP YOU WITH PARTS
Nov 18, 2007 | Samsung SC-D353 Mini DV Digital Camcorder
Samsung sc-d353 blurry now black
Problem is fixable and not expensive either : CCD sensor is faulty and needs replacing.You do have a case for having this problem sorted out by Samsung agent free of charge because the sensor should last 10 years +.
Sep 04, 2007 | Samsung SC-D353 Mini DV Digital Camcorder
Wont Take Tape
BAD TAPE TRANSPORT. NEED TO SEND IN FOR REPAIR
Apr 25, 2007 | Samsung SC-D353 Mini DV Digital Camcorder
"No Tape" on Samsung SC-D353 Mini DV
BAD TAPE TRANSPORT PROBLEM NEED TO SEND TO SAMSUNG FOR REPAIR.. THEY ARE CRAZY SO U MIGHT WONT TO CALL ME 717 733 3543
Apr 22, 2007 | Samsung SC-D353 Mini DV Digital Camcorder
Turn off "protection"
This seems to be an on going problem with all of the Samsung models sooner or later. 1st, check to make sure the protection tab on top of the tape is in record mode. Remove battery, wait a minute and replace battery, turning on the camera, place tape back into camera and close the door. If this does not work, the sensor is not reading that the tape is not protected. It is a service call but not worth the 150-195 in repairs to correct. Sometimes you just need to keep going, and going....
Sep 18, 2006 | Samsung SC-D353 Mini DV Digital Camcorder
Samsung SC-D353 Mini DV Digital Camcorder Logo
204 people viewed this question
Top Samsung Video Cameras Experts
Marvin
Marvin
302lab
Level 1 Expert
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
