worldwide.bose.com/.../soundlink_mini/.../owg_en_sou... Bose CorporationMini Bluetooth® Speaker. Owner's ... to charge and discharge the battery pack several times to obtain ..... the Bose® SoundLink® Mini speaker battery lasts up.
POWER TO THE AMPLIFIER. I HAD HE SAME PROBLEM ONCE. ALL WIRES GOOD ON THE STEREO AND IT WOULD LITE UP,PLAY,VOL. UP/DOWN....SPEAKERS HOOKED UP GOOD,BUT NO SOUND : ( MY BLUE/WHITE WIRE WAS NOT HOOKED UP TO RADIO BLUE WIRE AT HARNESS. AFTER THEY WERE HOOKED UP... HOORAY MUSIC TO MY EARS !!!! : )
If its under the 1 year warranty call 1800 252 6123 and they will do it no charge with any type proof of purchase, if over the 1 year they charge 45.00 maximum! and will repair it or replace it if it cant be fixed, then ship it back with a 1 year warranty, takes 4 weeks aproximately
First, determine if the TV device is putting out sound by plugging in a headphone into the audio out of the TV. If audio is there then the transmitter and wireless speakers system may be at fault. You can also plug in a CD player playing a disc into the transmitter to see if that source then transmits the audio.
The Wht/Blue wire is allways 12 volts; The Ylw/Red is switched only when the car key is on accessories.
1994 Isuzu Amigo Car Radio Wiring Schematic
Car Radio Battery Constant 12v+ Wire: White/Blue Car Radio Accessory Switched 12v+ Wire: Yellow/Red Car Radio Ground Wire: Black Car Radio Illumination Wire: Blue/White Car Stereo Dimmer Wire: N/A Car Stereo Antenna Trigger Wire: N/A Car Stereo Amp Trigger Wire: N/A Car Stereo Amplifier Location: N/A Car Audio Front Speakers Size: 5 1/4′ Car Audio Front Speakers Location: Dash Left Front Speaker Positive Wire (+): Blue/Green Left Front Speaker Negative Wire (-): Gray/Black Right Front Speaker Positive Wire (+): Red/Green Right Front Speaker Negative Wire (-): Brown/Black Car Audio Rear Speakers Size: 5 1/4′ Car Audio Rear Speakers Location: Side Panels Left Rear Speaker Positive Wire (+): Blue/Yellow Left Rear Speaker Negative Wire (-): Gray/White Right Rear Speaker Positive Wire (+): Red/Yellow Right Rear Speaker Negative Wire (-): Brown/White
Red - Power Yellow - primary power must be joined to the red blue - Remote Black - ground or negative To find your speaker wires check the color of the cord behind each speaker than match it with the same color in the dash. or the easy way is to use a normal 1.5v penlight battery and try each speaker cord behind the dash and listen to which speaker give off a crackling noise so you can get the balance on the cd player right. If u trying to find power in the car and don't have a tester than get a 12v light or bulb join the negative to the body and push the positive wire into each one of the holes in the factory plug in the dash one at a time until the light comes on. That is your positive the rest is easy. (DIY guru)
