Question about Canon P27Dh Calculator
Printing Error I just bought the calculator and plugged it in. When I switch it on to print, it has an E in the bottom left corner. I can not feed the paper in either.
Posted by Tahlia Gage on
2wsx
  • 128 Answers
Probably you need to feed the paper first, then plug it in.... try to read manual and check what E means in error messages.....
Posted on Jan 13, 2014
3 Related Answers
Anonymous
SOURCE: Won't print/feed
Try removing the batteries in addition to reseting the calculator.
Posted on Nov 29, 2007
Anonymous
SOURCE: How do you load paper into the printing calculator?
Cut paper at a 45 degree angle and load into back slot with angle (apex) of paper to the right of machine when facing it. Be sure to push it thru when loading. You should see tip next to calculator number wheel. Hit the additon sign several times to advance. You may need tweezers to pull paper thru if it doesn't advance by itself.
Posted on Jan 23, 2009
corykoby
Cory Koby
  • 46 Answers
SOURCE: how to feed paper into a canon palm size printing
There should be a small slot in the rear, gently feed the end into it while pressing the paper feed/advance button.
Posted on Sep 08, 2009
The paper feeder does not work. It hums and shows error.
DEBBIE LOOK IN THE OPERATORS MANUEL OR CALL CASIO CUSTOMER SUPPORT
Jan 21, 2016 | Casio Office Equipment & Supplies
I will be adding up multiple things, it is printing great, and then the screen goes blank except for a small "e" appears in the lower left hand corner and I have to start all over. WHY?
our calculator is beyond repair. You can use it in no print mode ohly. The printer is not working, causing the error code.
Turn it off and back on and only use the display mode.
Oct 22, 2015 | Canon P23-DH III 12 Digit Printing...
When I push the feed button, an E shows up in the left hand corner of the display.
The E is an indicator that the Paper Spool is EMPTY so either the paper sensor is defective or You have forgotten about a "bar" that the Paper must go through to be sensed. Or Your Feed motor has fed it's last. Best of Luck!
Sep 28, 2014 | Casio HR 100TM Portable Printing...
Are there spare part type belts for Sharp printing calculators?
Please contact your local Sharp service. Usually professionals have more extensive access to Sharp spare part databases.
Regards,
Juha-Matti Vihtanen
Oct 09, 2012 | Sharp Office Equipment & Supplies
How to feed the paper into the SPL-500 and how to set for printing?
You feed it from the back,(you will see an horizontal line) you're paper has to be straight cut, than you press the arrow on the left corner until you see it on the front.
Apr 20, 2012 | Staples SPLP500 Scientific Calculator
How to feed paper roll into calculator
Installing the Paper Roll
Caution: Avoid placing a double thickness of paper into the mechanism.
Do not pull the paper through the mechanism without pressing feed button.
1. If necessary, press on to turn the calculator on, and press P
to turn the PRINT display indicator off.
2. Remove the printer compartment cover by placing a thumb on each of the lower ridged corners of the cover. Push until the cover pops open, and lift the cover off.
3. Unroll a few inches of paper from the small roll and cut the end squarely.
4. Hold the paper so that it unrolls from the bottom, and insert the end of the paper into the slot under the printing mechanism.
5. Press feed button until the paper feeds out of the top of the printer compartment.
6. Place the small roll of paper inside the compartment.
7. Feed the end of the paper through the slot behind the clear plastic "window" of the printer compartment cover. Then snap the compartment cover back onto the unit.
Jun 07, 2011 | Texas Instruments TI-5006 II Calculator
WILL FEED PLAIN WHITE PAPER BUT WILL NOT FEED PHOTO PAPER
Follow the steps:
•1
Turn on the printer and press the Paper Feed switch until the Auto Sheet Feeder indicator light turns on.
•2
Pull up on the paper sheet feeder on the top and back of the printer and slide out the paper support.
•3
Take a stack of no more than 10 pieces of photo paper and flatten the corners, if they are curled. Curled corners may cause jams within the printer.
•4
Place the paper in the paper sheet feeder with the printable side of the paper facing up. The printable side of photo paper is the shiny or whiter side of the paper.
•5
Print your documents as needed.
Paper Cassette :
•1
Switch on the printer and press the Paper Feed switch until the Cassette indicator light turns on.
•2
Pull on the cassette on the bottom of the printer to slide it out of the printer.
•3
Flatten the corners of a stack of no more than 10 sheets of photo paper if the corners are curled. The paper may become jammed in the printer if the corners are curled.
•4
Place the stack of paper in the cassette so the paper is touching the right side and the printing side of the paper is facing down. Adjust the plastic paper guides so they touch the paper. The paper stack guides help facilitate the paper moving into the printer.
•5
Slide the cassette back into the bottom of the printer. The printer is ready for printing.
Oct 20, 2010 | HP PSC 2355 All-In-One InkJet Printer
I have a TI-5045 II Calculator that wont print
I have the exact same problem (just happended recently) with my TI-5045 II after 25 years of good service. My solution? I just bought another model: Sharp EL-1801V at Stapels for about $31.00. To get the old one fixed will probably cost me $25.00-30.00 just to diagnose, plus shipping and parts and labor. And that assumes I can find a shop to do it, or that TI still stocks the part(s) gone bad. Same old problem with all technology.
Sep 16, 2009 | Texas Instruments Office Equipment &...
Won't print/feed
Oct 12, 2007 | Canon P23-DH Calculator
Printing
it needs fine adjustment to printer by service center.
Sep 15, 2007 | Sharp EL-2630P Calculator
Canon P27Dh Calculator Logo
451 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Tareq Bin Mostaq...
Tareq Bin Mostaq...
