Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Outlook express xp
Can't send an email to yahoo.com or sbcglobal.net. get error 554 Message not allowed.
5 Related Answers
Anonymous
  • 15 Answers
SOURCE: My Outlook Express Won't work
Sounds like it's self explanatory. Perhaps Hotmail is no longer free for Outlook Express. If you would like to use Outlook Express as your defautl email client and use a POP3 based email account, may I refer you to www.hotpop.com? You can apply for a free POP3 email account which you can set up to run with your Outlook Express. You may also want to check into www.gmail.com. They support web based inboxes as well as POP3 configuration for your Outlook Express.
Posted on Apr 06, 2008
Anonymous
  • 150 Answers
SOURCE: can't send email in outlook
You may want to try to access the mail server through
another email client, such as "Courier Mail" from rose city:
http://www.rosecitysoftware.com/Courier/
This will tell you whether the problem is in your outlook settings,
or elsewhere. If Courier works, you may decide to stick with it,
it is simple to setup, and far superior.
If the courier mail does not solve the problem, you may have to
go through the "re-install network wizzard routine" again, disable
the windows firewall, disable the router firewall, disable all other
security widgits until you find what is blocking the email access.
This is assuming of course that you do not have server or
server settings problem as you said.
You may also have a rootkit or a virus lurking in the IP stack,
or the email protocol drivers, so scan your machine.
Martin
Posted on Apr 25, 2008
Vernon Simkins
  • 108 Answers
SOURCE: Email set up problems
from the data you have given, me, it sounds like you are using Either Outlook, or the bundled Windows Mail service.
What is happening, is that an email your program is trying to send, an email with "test" in the subject line, but is unable to because it cannot connect to the server. looking at the string, I see several problems. make sure your settings are configured a mentioned below:
  • Incoming Mail (POP3) Server: plus.pop.mail.yahoo.com (Use SSL, port: 995)
  • Outgoing (SMTP) Server: plus.smtp.mail.yahoo.com (Use SSL, port: 465, use authentication)
  • Account Name/Login Name: your Yahoo! ID (your email address without the "@yahoo.com")
  • Email Address: your Yahoo! Mail address (e.g., [email protected])
If this doesn't resolve your problem, refer to this page for more information. (Note: if you do not subscribe and pay in to a "Yahoo Plus" plan, this could also pose a problem, as Yahoo does not allow you to use third-party email programs with their "free" service, as they like to restrict it to webmail only. If you want a free email service that *does* however, I strongly suggest you check out google's Gmail service [what I use])
Posted on Sep 29, 2008
Anonymous
  • 1605 Answers
SOURCE: Outlook Express Setup - error message
contact comcast and get the pop3(outcoming) address, and the SMTP (incoming) address
"mail.comcast.net seems correct but the outcoming smtp.comcast.net seems wrong.
Posted on Oct 13, 2008
Lakshman P
  • 103 Answers
SOURCE: outlook express
hi,
Error 0x800c0133 when you are retrieving email with your Outlook Express (OE) is because of currupted Inbox file.
To remedy please follow these steps:
  1. Open OE, on the left pane, right click "Local Folders", select "New Folder...", specify a name for your new folder as "Temp".
  2. If you are still able to access "Inbox", move all mails in "Inbox" to the new "Temp" folder.
  3. Go to menu "Tools" -> "Options" -> "Maintenance" tab -> "Store Folder" button. It will show the location of your Inbox file, please remember this location.
  4. Close OE, go to the location mentioned above, delete the file "inbox.dbx".
  5. Restart OE, the "Inbox" folder should be auto recreated. Move back your mails to the new "Inbox", remove the "Temp" folder.
or
Another solution
Error Number:0x800c0133
Error Number: 0x800C0133 = a corrupt Inbox.
Move any mail you wish to save to a local folder you create. Then:
Tools | Options | Maintenance | Store Folder will reveal the location of
your Outlook Express files. Press the Tab key to highlight the folder
location, then Ctrl+C. Close OE, then Start | Run | Ctrl+V will put the
location in the box - Click OK and you'll see the OE files. Otherwise, write
the location down and navigate to it in Windows Explorer.
In WinXP, Win2K & Win2K3 the OE user files (DBX and WAB) are by default
marked as hidden. To view these files in Windows Explorer, you must enable
Show Hidden Files and Folders under Start | Control Panel | Folder Options |
View.
With OE closed, find the DBX file for the folder in question {Inbox.dbx} and
delete it. A new one will be created automatically when you open OE.
General precautions for Outlook Express:
Do not archive mail in default OE folders. They will eventually become
corrupt. Create your own user defined folders for storing mail and move your
mail to them. Empty Deleted Items folder regularly. Keep user created
folders under 100MB, and Default folders as empty as is feasible.
After you are done, follow up by compacting your folders manually while
working *offline* and do it often.
Click on Outlook Express at the top of the folder tree so no folders are
open. Then: File | Work Offline (or double click Working Online in the
Status Bar). File | Folder | Compact all folders. Don't touch anything until
the compacting is completed.
Turn off e-mail scanning in your anti-virus program. It is a redundant layer
of protection that eats up CPUs and causes a multitude of problems such as
time-outs and account setting changes. Your up-to-date A/V program will
continue to protect you sufficiently. For more, see:
http://www.oehelp.com/OETips.aspx#3
In Tools | Options | Maintenance: Uncheck Compact messages in background and
leave it unchecked.
Posted on Apr 16, 2009
1helpful
2answers
How Can I Fix Yahoo Mail Error 554?
Hello -
Apparently, you will need to revise the email you are trying to send.
https://help.yahoo.com/kb/SLN5067.html
Error: 554 Message not allowed - [numeric code]
You'll receive an SMTP error or failed delivery message that includes "554 Message not allowed" when the content of a message you're trying to send violates Yahoo Mail policies. Content that violates policies includes; objectionable links, malicious attachments, or bad header information.
Review the Yahoo Mail and Yahoo Messenger Terms of Service to learn more about Yahoo policies that can effect your ability to send messages to Yahoo Mail accounts.
If you're the administrator for the mail server in question, review your outgoing messages for obectionable content or practices.
How did I find this information? I used my favorite search engine, Google, and entered this search phrase, using quotation marks as shown:
"Yahoo mail" "Error 554"
How hard was that?
Best wishes.
Feb 12, 2018 • Yahoo Mail
Can receive but can't send email
I can receive but can't send mail using my POP mail client. Why? If you're able to receive but unable to send mail using your POP mail client (such as Outlook), please review the possible trouble areas below.
SMTP Server
In the fight against unsolicited commercial email (spam), some Internet service providers require their subscribers to send mail through the ISP's own SMTP servers. If you experience problems sending email, please contact your ISP to determine if it requires different SMTP server settings. You will need to use the ISP's SMTP server in place of Yahoo!'s SMTP server when configuring your POP mail client.
The following is a partial list of ISPs that require you to use their SMTP servers. If your ISP is among them, try replacing the Yahoo! SMTP server with the ISP server in your POP mail client settings, or consult the ISP's help files. (Learn more about configuring your client.) If your ISP does not appear in the list below, please contact your ISP directly for more information.
MSN smtp.email.msn.com NetZero smtp.netzero.net Verizon outgoing.verizon.net Earthlink/MindSpring Please visit its help pages AT&T Please visit its help pages Bell Sympatico Please visit its help pages SBC See below SBC Your SMTP settings will vary based on your account setup. Choose the SMTP setting that corresponds to the email address most like the one provided to you by your ISP.
[email protected] smtp.ameritech.yahoo.com [email protected] smtp.flash.yahoo.com [email protected] smtp.nvbell.yahoo.com [email protected] smtp.pacbell.yahoo.com [email protected] smtp.prodigy.yahoo.com [email protected] smtp.sbcglobal.yahoo.com [email protected] smtp.snet.yahoo.com [email protected] smtp.swbell.yahoo.com [email protected] smtp.wans.yahoo.com For more information about AT&T's SMTP requirements, please visit the AT&T help center or contact AT&T DSL support at 877-SBC-DSL5 (877-722-3755) or AT&T DIAL support at 866-SBC-DIAL (866-722-3425).
SMTP Port
If you have adjusted your SMTP server, and you're still experiencing a problem, you may need to use an alternate port. In an attempt to control spam, some Internet service providers now block port 25, which means you may need to use port 587 when sending email via Yahoo!'s SMTP server. Learn how to change ports.
Antivirus Protection
If you have Norton AntiVirus enabled on your computer, you may have to make configuration adjustments to use Outlook or Outlook Express. For more information, visit the Symantec web site.
Authentication
The Yahoo! SMTP server requires authentication. Learn more.
Cannot send from outlook express for yahoo account
Please try to use 2525 instead of 25.
I’m happy to assist further over the phone at https://www.6ya.com/expert/ramy_d9e7ebea3891f482
Jan 31, 2010 • Yahoo Mail
2answers
Outlook Express 2003 sending email permanent failure
check the configuration... for yahoo.. you should member of plus or you account is plus.. you can recieve and sent.. but if free only, you can receive only can't sent a message.. bu gmail.. all can sent and receive even its free account...
check you configuration should be rigth..and the POP and IMAP is turn on from you server....
Sep 10, 2009 • Yahoo Mail
1helpful
2answers
1helpful
The message could not be sent because one of the recipients was rejected by the server. The rejected e-mail address was '[email protected]'. Subject 'testing', Account: 'mail.eastern.com.ph', Server:...
Greetings,
this is a server rejected recipient error message for Outlook/ outlook express. mainly if this is a correct email address that you were trying to send the email on then you need to check for the configuration settings for Outlook express.
Goto Outlook express- higlight mail tab- select the user a/c- click properties on right- goto server tab check that server is
incoming: pop3.eastern.com.ph
outgoing: smtp.eastern.com.ph
click save
Regards,
TechSup1
Send/Receive Error with Outlook 2002
What are the incoming pop3 & outgoing SMTP settings.they should be pop.sbcglobal.yahoo.com & smtp.sbcglobal.yahoo.com
Please check
Which antivirus are you using?
Top Microsoft Computers & Internet Experts
Steve Nordquist
Steve Nordquist
Marvin
Marvin
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
