Question about aFe 2003 Dodge Durango - 4.7L V8, with 3-bolt throttle body - Silver Bullet Throttle Body Spacers
The check engine light does not turn off - aFe 2003 Dodge Durango - 4.7L V8, with 3-bolt throttle body - Silver Bullet Throttle Body Spacers
My Holden barina won't start and check engine light is flashing
Check Engine Light On - Auto Diagnosis Repair Help
www.aa1car.com/library/mil.htm
The Check Engine Light (which is actually the Malfunction Indicator Lamp or ... you can assume the fault that is causing the Check Engine Light to come on is probably minor and won't hinder your ability to continue driving. ... When the ignition is turned on (don't start the engine yet), the tool will .... flashing check engine light ...
What Causes the Check Engine Light to Come on in a Car?
www.wisegeek.com/what-causes-the-check-engine-light-to-come-on-in-a...
Nov 7, 2015 - When the check engine light comes on, take the car to a reputable mechanic .... I went to go home. the check engine light was blinking and it won't start. ... I looked in my manual book for 2001 holden barina car to see what the ...
Car cranks but won't start, Check Engine light blinking ...
www.evolutionm.net/...engine.../424408-car-cranks-but-won-t-start-chec...
Jun 1, 2009 - I tried to turn it back on but it would only crank and not start, the check engine light is also being really weird, it's blinking on and off pretty quick.Missing: barina
Check engine light flashing car won't start - RX8Club.com
Dec 09, 2015 | Holden Cars & Trucks
Tip
RESET THE CHECK ENGINE LIGHT ON THE 99 HONDA ACCORD
THIS IS HOW YOU RESET THE CHECK ENGINE LIGHT ON THE 99 HONDA ACCORD. 1. With the Car Off, Press and hold down the Odometer Trip Reset Button. 2. While still pressing the Trip Reset Button, Turn the Ignition Key half way on where all your oil, check engine lights etc.. turn on. Don't turn it as far as you would to normally start the car. Wait a few seconds and the Check engine light will turn off. 3. Turn the key back to the Off position and you're done. What a scam Honda has with the BS Check Engine Light.
on Dec 07, 2009 | Honda Accord Cars & Trucks
Turn off check engine light
You cant just turn check engine light off. You have to hook car up to a code reader or scan tool and read trouble codes. Repair trouble codes then erase codes and if problem was repaired check engine light will turn off.
Apr 14, 2014 | 2000 Volvo V40
Check engine light solid
Most of the newer vehicles have a senser that will turn the check engine light on, even when it's time to change the oil. After they change it, they reset the check engine light to turn it off. It could be something as simple as that or even an air filter needing to be changed. The dealer can tell you how to reset that light to turn it off. Good luck!
Nov 14, 2013 | 2003 Chevrolet Silverado 1500
How to reset engine lite in dash
Check engine light comes on and off, these are indication that there is some error code stored in your vehicles ECM. The engine module computer needs to be scanned. These will give the code and as per the error code the further problem can be detected and confirmed. The engine light indicator blinks or remains steady on dash when engine computer noticed any problem with any engine electrically operated components.
For more help, I suggest you to refer the help links provided below. These will let you know more about which areas to look, check, when there is engine light coming up on dash panel.
Click the link below: -------
Check Engine Light Reset Procedure?
http://whoisbyme.blogspot.in/2012/06/check-engine-light-reset-procedure.html
Check Engine Light ON?
http://whoisbyme.blogspot.in/2012/06/check-engine-light-on.html
Intermittent Check Engine Light?
http://whoisbyme.blogspot.in/2012/06/intermittent-check-engine-light.html
WHY Check Engine Light On car?
http://schematicsdiagram.blogspot.com/2011/06/check-engine-light-on-car.html
Check Engine Light, VSC light and Traction Control Light ON?
http://whoisbyme.blogspot.com/2012/06/check-engine-lightvsc-light-and.html
Check engine light flashing?
http://technoanswers.blogspot.in/2012/02/check-engine-light-flashing.html
Service engine soon Light Turned OFF after Jump Start?
http://whatisbyme.blogspot.in/2012/06/service-engine-soon-light-turned-off.html
After replacing throttle body the Check engine light starts blinking?
http://technoanswers.blogspot.com/2012/01/after-replacing-throttle-body-check.html
2005 Chevy Impala: Service Vehicle Soon Warning Light?
http://whoisbyme.blogspot.in/2012/06/2005-chevy-impala-service-vehicle-soon.html
Malfunction Indicator Light ON
http://whoisbyme.blogspot.in/2012/06/malfunction-indicator-light-on.html
Check power-train message with orange engine light came on?
http://howtobyme.blogspot.in/2012/02/check-power-train-message-with-orange.html
2007 Toyota Highlander Hybrid: Yellow Check Engine Light ON dash?
http://whatisbyme.blogspot.in/2012/05/2007-toyota-highlander-hybrid-yellow.html
1999 Toyota Tacoma: Check Engine Light Read Code P0171?
http://whatisbyme.blogspot.in/2012/05/1999-toyota-tacoma-check-engine-light.html
Car Runs Fine But Check Engine light is ON?
http://whatisbyme.blogspot.in/2012/05/car-runs-fine-but-check-engine-light-is.html
Check engine light with codes P2195 and P2197?
http://howtobyme.blogspot.in/2012/01/check-engine-light-with-codes-p2195-and.html
How to Read Codes from Check Engine Light?
http://schematicsdiagram.blogspot.com/2011/12/how-to-read-codes-from-check-engine.html
Vehicle smog test failed Due to NO MIL/check engine light?
http://schematicsdiagram.blogspot.com/2011/12/vehicle-smog-test-failed-due-to-no.html
OBD Code is cleared but check engine light will not RESET?
http://schematicsdiagram.blogspot.in/2012/02/obd-code-is-cleared-but-check-engine.html
Car jerks while going uphill and Check engine light is ON?
http://schematicsdiagram.blogspot.com/2011/12/car-jerks-while-going-uphill-and-check.html
Toyota Camry Check engine light flashes while driving?
http://schematicsdiagram.blogspot.in/2012/02/toyota-camry-check-engine-light-flashes.html
These details will help.
Thanks.
Nov 28, 2012 | 1999 Acura CL
Engine turns over but will not start.
Hi there:
When the light comes on, one or more diagnostic trouble codes (DTC) are stored in the engine control module. These DTCs remain even if the light goes out. To address a Check Engine Light problem, the DTCs are retrieved and the appropriate troubleshooting information is followed in order to determine the problem.
Just scanned the computer and send us code number find it.
Hope helps.
Mar 14, 2012 | 1995 Dodge Ram 2500
My kia is a 2004 optima. I started it and it turned off. And when i started again it turned on but my check engine light was on... whats wrong with my kia..
Read this please concering the check engine light.
The information below was complied by me, it explains what causes the check engine light to come on and the process of finding the cause.
When the Check Engine light (or Service Engine Soon or small picture of an engine) is turned on, the systems computer control unit (called the PCM) has sensed a fault in the electronic controls of the engine and/or the emission system. When this happens you will seldom feel the car engine run any different. There are about 200 possible system faults (the gas cap is just one of them) that turn the Check Engine light on, to know what has developed a problem you must have the system tested, this is called an OBD2 fault code test, Kragen/Oriley and Autozone parts stores (USA only) do this testing for free.
Feb 10, 2012 | 2004 Kia Optima
Hi my I have a toyota 4-runner 1998, and I noticed that my check engine light turns on after a 50+ mile long drive. So when I pull over and turn off the engine for about 15 minutes, the check engine...
this is generally the O^2 sensor it will go in and out of value corresponding to the vehicle temperature. it would be a good idea to replace the coolant temp sensor and the O^2 sensor.
Apr 18, 2011 | Toyota 4Runner Cars & Trucks
How do I turn out the check engine soon light on Mitsubishi outla
Hello. The check engine light comes on when the vehicle's computer has detected a problem with one of the components in one of the systems. To find out what exactly that check engine light means you have to hook the vehicle up to a computer scanner. Many auto parts stores now offer this scan for free, as do the AAMCO repair shops. After the scan is finished, the scanner will turn out the check engine light. Some vehicles check engine light also turns off if the battery is disconnected for two full minutes. Regards, Joe
PS kindly rate my answer. Thank you. Joe
Jan 23, 2010 | 2003 Mitsubishi Outlander
Engine light and battery light
No, and a new battery may not cure the battery light being on. A low or no charge condition will turn the red battery light on, a bad battery will not. A low charge condition could have turn the check engine light on. I would have it checked before I would start replacing parts.
Jan 31, 2009 | 1998 Dodge Stratus
aFe 2003 Dodge Durango - 4.7L V8, with 3-bolt throttle body - Silver Bullet Throttle Body Spacers Logo
632 people viewed this question
Top aFe Renewable Energy Experts
Greg Scott
Greg Scott
Lukas Alexander
Level 1 Expert
Are you an aFe Renewable Energy Expert? Answer questions, earn points and help others
