Sony DHG-HDD500 400-Hours Video Recorder Logo
A
Anonymous Posted on Jan 11, 2014
Poor signal reception - Sony DHG-HDD500 400-Hours Video Recorder
Poor reception when trying to get MW
Poor reception or with heavy noise aas the interference is very high on the MW. If there is no signal strength then the fault can be due to faulty RF in the radio, poor MW oscillator settings or a faulty IF settings.
Also a faulty antennae can cause poor reception and pick of stray signals.
Check for other interferances from household applicances.
2answers
TV comes on but will not recieve channel. It displays no signal & the code65535. The cable is working here so it is in the TV. It is a 37" dynex flat screen bought 2 yrs plus 4 months.
Hello
Try the resetting the TV. To do this unplug the power chord from power socket, and wait for atleast 45 minute. TV will reset itself. The try to get signals.
If your TV receive poor quality telivision signals, captioning may contain errors, or there might be no captioning at all. Some possible reasons for poor quality are automobile ignition noise, electic motor noise, weak signal reception or multiplex signal reception like ghosts etc.
If reset also didn't help you, the tuner inside your TV is defective, or weak. It should be replaced with same type and number. OK.
Poor radio reception on a Santa Fe that has the aerial as part of the near side rear window, is there a mod to improve reception.
if you live in a weak reception area the only answer is a signal booster or a new aerial on the roof.
I have a 1970's Sony AM Receiver ICR-9. Reception is poor and sounds almost like it is receiving on another band. It has been a great radio and would like to retain. Bill
Do you use an indoor antenna ? Nowadays, with all gear around, like micro-waves receptors, strong motors, satellites, etc., reception becomes quite poor, unless you use an external antenna, properly set to catch broadcast stations. FM reception particularly has its signal much improved in that way. Correct demodulation requires a good an somewhat large outdoor antenna. Hope I could help. Good Luck.
Flavio/Brazil
Some channel no sound
Hello Blwas5 hi, If some channels have sound and others none, its either the TV has poor reception or, its the channel's weak signal. check them both or see if your neighbors TV acts like yours. If thy neighbor reception is good, then thy TV has poor reception, you can't do anything to fix that. get another TV with good reception qualities.
2answers
Poor radio reception 04 Jetta
It may be more of a design flaw oppose to a actual problem. However, you can purchase signal booster that simply plug between the radio and the cars antenna.
3helpful
!994 Park Avenue FM radio reception poor. AM signal OK
Check antenna connections at radio and antenna assy.. Poor connections will only receive AM and hardly any FM
Poor reception
Go to a radio shark or to a phone store and tell them u want the Reception Booster that goes inside ur battery pack and this should improve ur Signal. :)
Poor FM reception
The Phone must be on.
The SIM card must be a valid one.
The station you listen to and the network operator you use, must support the service.
The headset or enhancement needs to be attached to your phone. for the FM radio to function properly, it's an aerial as well as a headset.
Therefor if you are in a poor reception area for making/receiving calls it will also affect the radio signal.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
