Question about Canon MultiPASS F60 All-In-One InkJet Printer
Canon Muiltcast F60 "Check Printer" error
I came back from vacation and when attempting to print I received the "Check Printer, Press Resume" error. I ensured the printer cartages were correct. I made sure there is no paper jams. I also used a Canon forum to "Reset Waste Ink Code".
All of the above did not clear the "Check Printer" error.
Where do I go from here?//
Posted by Myer229 on
  • 6 more comments
  • tom dooley Dec 09, 2007
    check printer, what is the waste ink reset & how do you do it
  • Anonymous Dec 21, 2007
    Have same problem - Alarm light keeps blinking. Resume does not help as it usually did in the past. I think the printer has had it.
  • debbiemcl Jan 10, 2008
    My f60 also is doing the "check printer, press resume", but when turned on, it sounds like the ink return is stuck on some thing, It makes a grinding noise. What can be done. Debbie
  • dinu dornescu Feb 05, 2008
    I have the same proble with my Canon iP4300. No printing, and it tells me to press RESUME button. I press and..nothing's happened. Please, help me .Sorry for my english, i am from Iassy, Romania.
  • Crombie Apr 13, 2008
    I sent something to the printer and the warning light come on saying check printer. When I open the printer the ink holder does not move to the centre and it sounds like it is jammed. I discunected the printer from the power and it did not resolve it?
  • kriebel Sep 09, 2008
    yes, plus a screeching noise..i dont see any paper stuck in there...help i need my printer...
  • Anonymous Oct 15, 2008
    I tried the reset code but the paper did not pass through any more ideas? Tried the pushing down on the opening of the memory card too, No go.
  • Anonymous Oct 22, 2008
    I have a problem with my Canon Multipass F60. I tried to print a document and when I clicked print nothing happened. A gray box later popped up saying: could not communicate with device and to check and make sure printer is on and that the the printer is connected. Everthing is connected and I have replaced the USB cable and also reinstalled the printer and still nothing when I try to print.
    The weird thing is that I can scan from the printer.
    I have noticed that when I open the printer the print head does not return to the center where you can replace the ink, it just stays all the way to the right. Does anyone have any answers for this problem?
    Thanks, Steve
Anonymous
I got the same problem and contacted Canon and this is what I got.
Thank you for your inquiry. We value you as a Canon customer and
appreciate the opportunity to assist you. We regret to hear that your
MultiPASS F60 is displaying the Check Printer error.
The Check Printer error usually indicates that the printer carriage will
not move to or from home position. The carriage may not move for the
following reasons:
* The print head may not be installed correctly.
* There may be an obstruction in the printer path.
* The print head may have overheated.
* The print head may be defective.
* The unit requires service.
Please perform the following procedures to clear the message on the
display.
Check the print head installation.
1. Press the Open button and lift the Scanning unit. The printer
carriage will automatically move to center when the Scanning unit is
opened.
If the printer carriage will not move to the center, skip to
'Obstruction'.
2. Wait for the printer carriage to stop moving. Once the carriage has
centered, raise the lock lever to release the print head. The lever is
on the right side of the print head holder.
3. Remove the print head out of the MultiPASS.
4. Place the print head back into position.
5. Press down the lever to lock the print head in place.
6. Close the printer cover.
Obstruction:
1. Check for a paper jam, paper clip, or other foreign material that
may keep the printer carriage from sliding left or right.
2. Carefully remove the obstruction and then close the Scanning unit.
3. If you cannot remove the obstruction, the unit will require service.
Overheated print head:
1. Press the ON/OFF key to power off the MultiPASS.
2. Allow the print head and printer to cool off for approximately 10
minutes.
3. Press the ON/OFF key to power on the MultiPASS again.
4. Press the Open button and lift the Scanning unit to make sure the
carriage will move to center position.
Note: The unit has a battery back-up for your fax's user settings (i. e.
your unit's fax number, name, etc.). However, any faxes stored in
memory will be lost. Once power is restored and the unit is able to
print, a Memory Clear report will print. This report will provide you a
listing of the faxes that were lost due to power interruption. Contact
the parties on this list to have them resend you the faxes.
Defective print head:
opened.
2. If the carriage has stopped in the center, remove the print head out
of the MultiPASS and replace it.
If the carriage will not move to the center, the unit will require
service.
3. Open the print head packaging and remove the new print head.
4. Lift off the orange protective cap.
5. Slide the new print head into position.
6. Press down the lever to lock the print head in place.
7. If the ink tanks still contain ink, you can remove them from the old
print head and install them into the new one.
8. Close the printer cover.
If the issue continues to persist, then the MultiPASS F60 will require
service.
The first option is Canon's Loyalty Program. This option allows you a
one-time opportunity to purchase a new printer that uses Canon's next
generation of technology at a discounted price. To help you get up and
running quickly, we also offer free next business day shipping (if the
order is completed by 12:30PM).
Your information is now registered for the Canon Loyalty Program and you
will be provided with a Discount Code. The Discount Code will be
e-mailed to you separately along with further instructions on how to use
the Canon Loyalty program.
The second option is to have an Authorized Service Facility repair your
product, at standard market rates for parts and labor.
There are two ways to find a local Canon Authorized Service Facility
(ASF). You can call 1-800-OK-CANON. Pay close attention to the options
given so it will direct you to the information that you need. You can
also find this information online.
Please follow these steps to access the online database of Authorized
Service Facilities:
1. Visit http://www.canontechsupport.com.
2. Select the product type, series, and model number from the three
drop-down menus on the center of the page and then click GO.
3. Click on Service Locator in the box on the right side of the page.
4. Enter the ZIP code of choice and it will give you the local
facilities.
Once you have found a local facility, please call the ASF first to make
arrangements to take the unit in for repair. Take the print head, ink
tanks and power cable with you to the ASF. The ASF will need these
items to perform proper troubleshooting. Unfortunately, we cannot
provide an estimated time it will take for the unit to be fixed. The
speed at which the unit is repaired is based entirely on the ASF and
their current work load.
If the unit is not in warranty, and there are no local facilities
showing up, please know that you're not obligated to use an ASF of
Canon. You may choose another service facility to fix the unit.
If you perform a search online and there is not a local ASF listed,
please let us know. There may be other options available.
We hope this information is helpful to you. Please let us know if we
can be of any further assistance with your MultiPASS F60.
Thank you for choosing Canon.
Sincerely,
George
Technical Support Representative
Special Note: Certain issues are very difficult to resolve via email.
If your question remains unanswered after you have received this email,
you may call our special toll-free number for email customers with
unresolved issues and speak to a technician* by dialing 1-866-261-9362,
Monday - Friday 10:00 a.m. - 10:00 p.m. (excluding holidays).
If you prefer to continue to communicate via email, reply to this
message and we will respond as quickly as possible.
*Telephone support for products no longer covered under the
manufacturer's warranty may require a $9.99 fee for support.
Posted on Oct 25, 2008
Anonymous
I've try to reset it with the code but the paper won't go through
Posted on Oct 15, 2008
    Guess I wasn't suppose to ask for assistance there sorry.
Anonymous
F60 Alarm Blinking "Check Printer" "Press Resume Key"....tried everything and fixed it by pushing the darker gray piece which lies below the opening where the memory card is inserted. I mean it when I tell you I did everything! And as soon as I pushed on that piece my alarm stopped blinking lcd error message cleared and my printer is perfect....go figure!
Posted on Sep 04, 2008
Scott Yeoman
  • 121 Answers
Clean your encorder strip with a soft dry cloth.
Posted on Oct 24, 2007
Anonymous
This works on the F30, F60, and F80.
Resetting the Waste Ink Volume Counter
1) Enter SERVICE MODE.---
By pressing Menu-Copy-#
2) Select TEST MODE.
3) Select [8] PRINTER TEST in TEST MODE.
4) Select 3. [EEPROM CLEAR].
5) Select 0. [INK COUNT].
6) Press the [OK] key.
7) Press the [Stop/Reset] key (returning to the state of 3)), and then press the [ON/OFF] key.
Skip step (6) since there is no [OK] key on F30 printers.
Posted on Apr 29, 2008
Canon Color Bubble Jet Printer i550 wiil not print - (greenlight then orange light blinks 8x - then green light) When attempting to print receive "Printer not responding" - "Paper thickness lever...
try this. It is the reset for the waste ink error (8 flashes)
1) With the printer power OFF, while pressing the Resume button, press the Power button. (Do not release the
power button.)
2) While pressing the Power button, release the Resume button, press the Resume button again twice, and then
release the Resume button and Power button.
3) The green indicator flashes during initialization.
When the indicator stops flashing and remains on, press the Resume button 4 times to clear waste ink message.
(The indicator toggles between orange and green each time the Resume button is pressed.)
4) Next, press the Power button, and the green indicator will light, and the function will be executed.
5) Turn off the printer then back on and error should clear.
Aug 04, 2010 | Office Equipment & Supplies
My MultiPass F60 Alarm light is blinking. It says "Check Printer/Press Resume". I have swabbed print head with alcohol to clean it. Could waste ink tank/reservoir be full. If so, where is it located and...
Fello there try
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Nov 27, 2009 | Canon MultiPASS F60 All-In-One InkJet...
Canon multipass F60 blinking alarm - press resume- check printer
Hi. if your multipass is connected to a computer you can check in the printer monitor status the exact error . Or you can count how many time the error display blinks
May 18, 2017 | Canon MultiPASS F60 All-In-One InkJet...
Canon MP F60
I had this problem also. None of the reset tricks worked. I replaced the print head with one from ebay and problem solved. Costs around $45 new.
Sep 20, 2008 | Canon MultiPASS MP700 All-In-One InkJet...
Canon MultiPass F60
You need to do the print head cleaning. The steps are listed below.
Print Head Cleaning / Head Refreshing
If the printed Nozzle Check Pattern is broken, missing, or a specific color is not printed, clean the print head.
1. Press the <Menu> button on the printers operation panel.
2. Press the left [<] or right [>] arrow buttons to select [MAINTENANCE].
3. Press the <Set> button.
4. Press [<] or [>] to select the cleaning setting you want. Select [HEAD CLEANING] for normal print head cleaning. Select [HEAD REFRESHING] for deep print head cleaning.
Note: [HEAD REFRESHING] uses more ink than [HEAD CLEANING], so perform [HEAD REFRESHING] only when necessary.
5. Press <Set>.
6. Print a Nozzle Check Pattern and perform at least two Head Refreshing if the pattern is not correct.
Sep 15, 2008 | Canon MultiPASS F60 All-In-One InkJet...
Canon i860 - Service Error 5100 I have tried the reset procedure several times (Resume, then power and hold power, resume 2x, release power) but the light never stops blinking to go on. Any...
Start with the printer OFF
1. Hold down RESUME and then hold down POWER
2. release RESUME (while still holding down the POWER)
3. press RESUME twice, then release POWER
4. The green light will blink and the printer will make some noise. Wait until this is finished, you are now in the printer's diagnostic mode.
To select one of the functions below, use the RESUME button and then press POWER to execute:
# of RESUME Presses - Light Color - Function
0 - green - Power Off
1 - orange - Service Test Print: Extended nozzle check pattern
2 - green - EEPROM information print
3 - orange - EEPROM initialize
4 - green - reset waste ink counter (For the Canon waste tank full error)
Remember... ATTEMPT THIS AT YOUR OWN RISK!!!
May 03, 2008 | Office Equipment & Supplies
Canon service 6000
Well... here it is :
The POWER Lamp Flashes Orange title-bar.gif An error has occurred in the printer. The number of flashes indicates the type of error, as outlined below. Check the cause and take the appropriate action.
When a printer error occurs, the POWER lamp flashes. The number of flashes indicates the type of error that has occurred. Count the flashes and take the appropriate action to correct the error.
bullet.gif Two flashes: Printer is out of paper /Paper does not feed
Reload paper to the sheet feeder or cassette and press the RESUME button.
bullet.gif Three flashes: Paper jam/Paper output tray is closed
If paper is jammed, remove the jammed paper, reload paper in the printer, and then press the RESUME button. If the paper output tray is closed, open it.
See Paper Jams
bullet.gif Four flashes: Empty ink tank
Press the RESUME button to resume printing with an empty ink tank. Replace it with a new ink tank immediately after the printing. It may damage the printer if you continue printing with an empty ink tank.
bullet.gif Five flashes: Print head not installed/Print head not installed correctly/Print head is defective
Install the Print Head. If the Print Head is already installed, remove the Print Head and check the electrical contacts for foreign matter, then reinstall.
After reinstalling the Print Head, you may need to realign it.
If this error still remains, the Print Head may be damaged. Contact a Canon service representative.
bullet.gif Six flashes: Inner cover error
To print on paper:
Close the inner cover. Then press the RESUME button to start printing.
Do not move or close the inner cover during printing. It may damage the printer.
bullet.gif Seven flashes: The CD-R or DVD-R is not set on the CD-R tray
Reset the CD-R tray feeder with a CD-R tray containing a CD-R or DVD-R, and then press the RESUME button. Printing will resume.
This function only works with models that support CD-R printing.
bullet.gif Eight flashes: Waste ink absorber almost full
The printer has a built-in waste ink absorber for the ink used during print head cleaning. Eight flashes indicates that the waste ink absorber is nearly full. Press the RESUME button to cancel the error so you can continue printing. Before the waste ink absorber becomes completely full, contact a Canon service representative.
Important
Canon recommends that you call for service as soon as this error occurs. Once the waste ink absorber becomes completely full, printing will no longer be possible.
bullet.gif Nine flashes: A specified period of time has lapsed without receiving no response from the digital camera / The digital camera or digital video camcorder connected is not compatible with this printer
Disconnect the camera cable, press the printer's RESUME button and reconnect the cable.
If the error is still not solved, there is a possibility that you are using a digital camera or digital video camcorder that is not supported by this printer. Use a digital camera or digital video camcorder compatible with this printer.
bullet.gif Ten Flashes: Cannot print on both sides of the page
The size of paper may not be compatible with automatic duplex printing. For information on the size of paper compatible with auto duplex printing, see "Automatically Printing on Both Sides of the Page." Pressing the RESUME button will discharge the paper, and restart printing from the front side of the next paper. The reverse side will not be printed when an error occurs.
bullet.gif Eleven flashes: Cannot perform automatic print head alignment correctly
Possible causes are as follows:
bullet_s.gif A4 or Letter-sized paper is not loaded on the sheet feeder.
bullet_s.gif Ink has run out or ink tanks are not installed correctly.
See Ensure that the ink tank is installed properly.
bullet_s.gif Ink level is low.
bullet_s.gif Print Head nozzles are clogged.
Press the RESUME button.
For information on how to print a nozzle check pattern, see "Printing the Nozzle Check Pattern."
bullet_s.gif The paper output slot has been exposed to a strong light source preventing correct print head alignment.
Press the RESUME button to resolve the error. Align the printer so the paper output slot will not be exposed directly to a strong light source.
After carrying out the above measures, if the problem continues after aligning the print head again, press the RESUME button to resolve the error, and then perform manual print head alignment. For details on manual print head alignment, see "Aligning the Print Head."
bullet.gif POWER lamp flashes alternate green and orange:
An error that requires contacting a Canon service representative may have occurred.
Disconnect the printer cable from the printer, and then turn the printer off and unplug the printer from the power supply. Plug the printer back in and turn the printer back on after leaving it for a while.
If the problem remains, contact a Canon service representative.
Apr 21, 2008 | Canon PIXMA iP1600 Printer
WASTE INK NEAR FULL
I have the same problem and my power will not turn on if the resume button is depressed. Is there a way to fix the waste ink problem?
Feb 06, 2008 | Canon MultiPASS F60 All-In-One InkJet...
Canon f60 print check
i cannot print alarm light is on window reads "waste ink near full"
Mar 04, 2007 | Canon MultiPASS F60 All-In-One InkJet...
Canon MultiPASS F60 All-In-One InkJet Printer Logo
old marine
old marine
efs_perpends
efs_perpends
