Question about DISH Network Televison & Video
Dish network error codes 848 - DISH Network Televison & Video
david willimes
    Sergeant:
  • 260 Answers
Network area code .to solved this issue call our network opreater
for more computer software issue visit https://cbrtechsolutions.net
Posted on Oct 05, 2015
Dish network error 31 12 45
I use Dish and have had no signal at all. The error codes are Tuner 2 31-12-45 and tuner 1 11-12-45
Oct 28, 2013 | DISH Network Televison & Video
Error code 006 dish network
que significa el codigo de error 006
Jan 20, 2013 | DISH Network Televison & Video
Dish network error 004
Hi there, Tim!
It's possible the dish may need to be repointed. Try running a check switch test. Go to Menu > System Setup (6) > Installation (1) > Point Dish (1) > Check Switch > Test. This will provide more info on the satellite signal.
If you have run that test and the problem continues I would need to see about getting a tech out. If so, you can send me an email at [email protected] for further assistance!
Tommy Faust
DISH Social Media Representative
Mar 25, 2012 | DISH Network 625 Duo DVR Receiver...
Error code 04ee on Dish network 722 vip HDD,
Hello this is luke. I do not know of any 04 ee error code on dish network. The closest will be 004. Try to check if it is coming from the receiver or from the tv by unplugging the receiver from wall outlet while tv is on. If the code stays, then it is from the tv, if it goes away with the lights on receiver, it is from the receiver. Let me know.
Jan 23, 2011 | DISH Network ViP622 DVR DTV Receiver /...
Getting an error code 311, dish says its the hard drive and i have lost everything help
Hello! Daniel Busa here with Dish Network's customer service department. If you're getting the 311 message this is most likely an indication your hard drive is bad. Try unplugging it for ten seconds if it persists you may need a replacement. If it does persist I will send a replacement please e-mail me at : [email protected]
Jan 04, 2011 | DISH Network 311 DTV Receiver
Yamaha receiver mdl RX-V367. What code will let it work with the Dish Network remote?
Here are the codes for your Yamaha RX-V367: 733, 663, 732,747, 730, 731, 745, 848, 847, 657, 786, 684, 849, 655, 823, 841, 646, 650, and651.
Step 1:
Press and hold the AUX button until all mode button back lights come on, thenrelease.
Step 2:
Press 2, and then enter the device code corresponding to the equipment (listedabove).
Step 3:
Press the POUND (#) button. If the code entered is valid for the remote, themode light flashes three times. Try using the DISH remote to control the component,if it doesn't work with one code try another.
Although we try and facilitate a one remote solution, wecannot guarantee that our codes with work for all brands and models components.Thank you for being a valued DISH Network customer!
Phillip Chang
DISH Network Customer Support Representative
Dec 15, 2010 | Yamaha RX-V663 Receiver
0521 code on dvr
Hello! Daniel Busa with Dish Network I saw your post and would like to apologize for the inconvenience. If you've gotten that error message it may be a sign your hard drive is down. If you reset the reciever by unplugging it and it keeps happening you will need a replacement.
Jul 21, 2010 | DISH Network ViP722 DTV Receiver /...
Universal remote control code
Based on the limited information posted I will say with the current remote no it will not. However they do have a remote that may support this receiver however since I have never dealt specifically with your model in teandem with a 20.0 remote I can not assure you of its compatability. It is however your best shot at resolving this issue.
Thanks for using Fix Ya.
Yamaha Amplifier 646, 650, 651, 655, 657, 663, 684, 732, 733, 786, 823, 841, 847, 848, 849 Yamaha Amplifier 646, 650, 651, 655, 657, 663, 684, 732, 733, 786, 823, 841, 847, 848, 849
Dec 20, 2009 | DISH Network IR Remote Control
Error code 05
delete all recordings from hard drive unplug the receiver from the wall for 5 minutes and plug it back in, if 311 error message appears call dish network
Jul 27, 2008 | DISH Network DVR-625 DTV Receiver /...
Code for trutech
dish network remotes dont work with very many tv/vcr or tv/dvd combo units
Jul 11, 2008 | DISH Network IR Remote Control
Televison & Video Logo
133 people viewed this question
Top DISH Network Televison & Video Experts
matt martin
matt martin
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
