Garden Logo
A
Anonymous Posted on Jan 11, 2014
No compression on sthil lawn edger - Stihl Garden
Plink-plonk
Level 3:
  • Stihl Master 1,807 Answers
  • Posted on Feb 27, 2016
Plink-plonk
Stihl Master
Level 3:
Answers
1807
Questions
Helped
818585
Points
15648
Which model.? possibly damaged piston rings or valve timing (depending on model)
Sthil fs 38 grass trimmer will not start
does it have spark, compression and fuel.? more info please
Sthil cutting out
more information required
250 sthil weed trimmer flywheel magnets .how many magnets on it
Hi diana
You have just one magnet...it is the one that activates the electronics to give fire to the spark plug
Bud
Oct 21, 2013 • Garden
250 sthil weed trimmer burning spark plug with oil
Diana reduce the oil mix slightly in the fuel mix and then give it a few goes to reduce the oiling.
My sthil fs 80 has new carb and new rings. has spark but wont start
Is fuel getting into the cylinder.? Is the spark continuous, check gap between flywheel and ignition module. 0.25 filer guage.
Replace primer bulb for sthil FS40
four screw remove the primer bulb plate from the carb, switch it out and put the screws back in..
1helpful
Oil & Gas Mixture
if you are using sthil oil the mix is 50:1
Just want the gas oil mix for a 25cc weed wacker
if using sthil oil the mix is 50:1 if not then its either 32:1 or 40:1 not to much dif
Top Stihl Garden Experts
Thomas Perkins
Thomas Perkins
Kardoc
ADMIN Andrew
ADMIN Andrew
Are you a Stihl Garden Expert? Answer questions, earn points and help others
