The specifications listed for the transformer are 18 v , 80 va .What is the ampere rating ?
SOURCE: WHISTLE STOPPED WORKING on CW-80
replace the button with a new one just remember which wire goes to which terminal. you will need a soldering iron and electronic solder to do this trick , also make sure you un plug the transformer. by any chance you got any n-scale trains you want to get rid of . If you do send me the info @ [email protected] I'am a disabled veteran with little funds.
Posted on Dec 01, 2008
SOURCE: lionel CW - 80 transformer
Check out this link, I think it will help.
http://www.lionel.com/media/servicedocuments/71-4198-251.pdf
Posted on Jan 20, 2009
SOURCE: Why does my new CW 80 transformer show constant
It sounds like the variable resistor control is faulty or shorted, and supplying voltage all the time. If the unit's new, enforce your warranty or exchange priviledge. This problem shouldn't be happening for a few years.
If, for some reason, your warranty doesn't apply, you'll have to take it apart to figure out what's broken or shorted.
I would contact Lionel, if worse comes to worse- maybe they would send you an exchange.
Here's their support site:
Good luck, and hope this helps.
Posted on Nov 18, 2010
SOURCE: Can I use the cw-80 transformer on any Lionel
You should be able to. The Lionel transformers all put out AC power, not DC and many Marx and American Flyer transformers will work too. The real question is total amount of power being drawn and whether or not you have the wattage to match your engine and accessories. With the CW-80 though, it should put out plenty. I run my pre-war 1666E engine pulling a full compliment of metal cars with no problems using a CW-80.
Posted on Feb 10, 2011
SOURCE: how many feet can 1
If you are talking about how many feet of track than your answer is 50. You can get the manual on the link below.
Posted on Feb 19, 2011
