Question about Sumvision Sempra PRO Digital Media Player
Sumvision cyclone tablet astro+ android 7"
My cyclone tablet will not turn on correctly I press the power button an then it just freezes on the start screen that says sumvision in big bold letters it has been like this for a hole day can u help please
3 Related Answers
Anonymous
  • 10 Answers
SOURCE: Problem accesing my Sumvision cyclone media player through my tv
Posted on Aug 12, 2009
Anonymous
SOURCE: Sumvision Cyclone Media Player - how do I get
hi
i have sumvision cyclone multimedia player. its not reading any files when im connecting to tv but works fine with usb
Posted on Apr 28, 2010
Anonymous
SOURCE: sumvision cyclone not working
i am having the same problem.
can anyone explain.
Power tries to turn on but fails to come up with screen that says HELLO.
It just flickers on for a second and then powers down straight away.
Posted on Feb 08, 2011
Forgot password on cyclone voyager tablet
How to reset a Sumvision cyclone voyager 7'' - Tablets and e ...
forums.digitalspy.co.uk/showthread.php?t=1777470
Digital Spy
Dec 31, 2012 - 7 posts - ‎4 authors
Hi a friend of mine had a 7'' Sumvision Cyclone Voyager tablet for ... it round for me to look at last night, i tried to get the password reset but ...
Do you know how to reset a Sumvision Voyager Tablet, i ...
www.askmefast.com > ... > Screen
Cyclone voyager tablet how to reset stuk on android screen .... Sumvision cyclone voyager password reset · I forgot my .... Cyclone voyager 10 tablet factory reset.
Topic: Cyclone Voyager ' Tech It [email protected]
Get rid of dead robot
try clearing your cache partition, you can get to the android recovery with your buttons.
1. Turn tablet off. You may need to use two hands in this process to press and hold buttons properly.
2. Turn on the tablet with power button, wait a full 2 seconds from the time the tablet starts showing the red Motorola logo, then press and hold the down Volume key. (you should not hold down the power button after it turns on and logo appears)
3. "Android Recovery" will appear on top of screen if timing is done correctly. Release volume button. (if you continue to press volume down at that message, the message will cycle through "RSD, Fastboot, and back to Android Recovery. Make sure message states Android Recovery before you go to next step). If stuck at a RSD protocol or Fast boot screen, reboot the tablet by holding power button then pressing the volume up).
4. While screen states "Android Recovery", Press volume up button, the screen will say "Entering Android recovery mode" and a few seconds later an Android robot graphic will appear alone on the screen. Release buttons.
5. Hold down power button and then press the volume up key together to see the Android Recovery screen menu selections.
6. Use the volume buttons to move up and down through selection in this menu.
7. Using the volume down button, scroll down to "Wipe data/factory reset"
8. Tap Power hard key to select option.
9. Scroll down to select "Yes, delete all user data".
10. Tap the power button to select. Wiping and formatting data will take a few minutes.
11. You will return back to the Android recovery screen menu.
12. Tap the Power button to "Reboot system now" which will power-cycle tablet and eventually power back on to the Initial Set-up / Welcome screen present when you first turned on your tablet.
I've had several issues but the one now is that all my tablet will do is show a pic of an android laying down with a red triangle on it bearing an exclamation mark. At the bottom of the screen it says NO...
Nabi jr has a green android laying on it's back with red exclamation make, want do anything. How do I fix it?
My daughters my tablet2 by bush has,frozen what do I do
if you can remove the battery start there. is not try to hold the power button for 1min. if that still doesn't work follow the bellow instructions
When Hard Reset is Necessary for Smartphones or Tablets ?
1. Forgotten Pattern Lock on Android Tablets or Smartphones.
2.Too many pattern attempts / Reset user lock.
3. Tablets PC,Smartphones stuck on Gmail account.
4. Android Tablet PC stuck / freeze on Android logo.
5. Tablet Android or Smartphones hang on start-up / Multiple errors generating by OS.
6. Android market having problems or generating errors.
7.Upgrading to new Android version.
Make sure to charge battery upto 60%.
How to Hard Reset Argos CnM TouchPad Android tablet pc ?
  • Make sure the tablet is charged up to 60%
  • Turn off the tablet completely .
  • Press Volume + button , while holding Volume + button , plug in charger.
  • Release the volume + button.
  • Press Volume + again and press Power button to boot the CnM Tablet.
  • When Android logo appear , release the volume + button.
  • Press Power Button again and press volume + button , Recovery Menu will be appear .
  • Press the volume down and select "wipe data/factory reset"
  • Power button to select it
  • You will see "Yes - delete all user data"
  • Select "Yes"press "Power" button to select it
  • Formating will start. it will delete all user data .
  • Few seconds later, you should see the recovery menu again. Select reboot.
  • It will take approximately 2 to 3 minutes to take you back to its factory (out-of-the-box) state .
you are done.
This Hard Reset method will work with all models of CnM touchpad tablets.
Sumvision astroplus cyclone
Kurio tablet won't charge or turn on
I have a sumvision cyclone voyager 7 It wouldn't turn off and after battery died it won't turn on even when plugged in Any suggestions? Thx Dave
Sounds like you may have a dodgy power button, you have a 1 year warranty I would call or e-mail sum vision, I have one of these systems and there not bad I've not had a power button problem though. Hope this helps!
What does it mean when android robot is laying on its back
I am giving you an example with an Motorola Tablet. I'd try clearing your cache partition, you can get to the android recovery with your buttons.
As you're going through the options don't do the factory data reset, look for wipe cache partition then follow the instructions to reboot.
Hope this helps!!! Let me know if you need more help
-Nadeem
Sumvision Cyclone HD Black Screen
there is a button on your remote control that says TV SYSTEMS just press this button until it changes back to the correct setting
stevie G
Sumvision Sempra PRO  Digital Media Player Logo
Top Sumvision Audio Players & Recorders Experts
Ekse
 Grubhead
Grubhead
Are you a Sumvision Audio Player and Recorder Expert? Answer questions, earn points and help others
