Projector will play as normal. After 5 minutes, no picture on projector screen, lamp goes out, with red light showing on lamp button. Lamp has been recently replaced
SOURCE: BENQ PB2140 PROJECTOR - RESET LAMP AFTER REPLACEMENT
Hi Terence
Yes you have to reset the lamp timer.
How to do this :
1.) Hold in the up arrow key on the Projector for 5 seconds , a on-screen display will appear in the top left hand corner.
2.) It will read : Press left or right and then Menu or Auto.
Just follow the steps and the lamp timer will be reset.
Thanks for using Fixya !
SOURCE: Projector shuts down after only a few minutes.
enter in Factory Menu
1. How to enter factory menu:
I. Hold press "UP" button until the "Lamp hours info." OSD display on bottom-right of screen.
Press keypad <Power> and <Blank> key simultaneously again, then enter Factory menu.
enter in fan menu and increse the speed of fans.
[email protected]
SOURCE: BENQ PROJECTOR
Mine needed a "fan module" replaced. The part number is 60.J8613.011.
Cost was $60, plus $100 for labour.
SOURCE: BenQ PB8220 DLP projector - lamp button continues to flash after bulb replacement
Hello!
After 2 years I finnaly solved the problem. There was a flaw in the lamp´s temperature circuit. A technician disassambled my BENQ PB8253 unit and fixed the problem. Charged me US$ 75.00. I´m in Brazil.
Hope this can help.
SOURCE: Ballast error status - lamp voltage too high
You need to replace the balast as the voltages are buringing the bulb out and this is caused by a balast that is bad. The baslast is what the bulb connects to this has a sensor on it that relays voltages and heat back to the main control unit.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
