SOURCE: left channel not working
Probably Broken solder connections in unit. I have seen these units have many poor broken connections throughout amp espcially around poweramp ic .IC701
I have a service manual if you are interested in it [email protected]
SOURCE: both left and right speakers play audio for right speaker
I think you mean the left channel is out but when you use test tone, the sound comes from left and right channels through the right channel speaker. If this is case, the switching IC is malfuncting. Unit needs service
SOURCE: STR--DG910: no rear speaker sound, no center speaker sound
if you confirmed all connection repeat your speaker setup.
SOURCE: no sound out of rear speakers
I don' know what type of system you have, but try to switch system to "SURROUND" mode, or "DSP" mode.
SOURCE: Right front speaker channel has a lower than usual output...
very basically try swapping over the speaker cables, if this doesnt work i suspect you are in need of a new ouput i.c. these can go if the speaker wires are touched together, unless there is a protection circuit.
