Olympus DS-30 Digital Voice Recorder Logo
A
Anonymous Posted on Jan 11, 2014
I own an Olympus VN 7200 voice recorder that is stuck in "FAST" mode. How do I get regular speed back on playback?
The problem happened when I accidentally pushed the play button a couple of times while it was already playing.
5 Related Answers
Anonymous
  • 3 Answers
  • Posted on Jun 01, 2008
SOURCE: Olympus VN-3100PC Digital Voice Recorder "Err" Message
Download the digital wave player and install it. That will work for your VN-3100PC http://www.olympus.it/consumer/2590_software.cfm?category=0&productgroup=347&product=421&os=7&result=
Anonymous
  • Posted on Dec 29, 2008
SOURCE: Olympus DS30 voice recorder play speed issue
Hi, the solution to the problem seems to be the following. When u press play, once, you get 1x play. If whilst playing you press play a second time the DS-30 goes into slow play mode, and if you press a second time it goes into fast mode. For those of us who accidentally went into either fast or slow mode, just press the play button again, during playback, until "play" appears on the LCD screen. Apparently it is as simple as that.
Anonymous
  • Posted on Mar 10, 2009
SOURCE: drivers for Olympus VN-4100PC Digital Voice Recorder.
I called the number and here is the link that has the software and drivers.
http://www.olympusamerica.com/files/digitalwaveplayer.zip
Anonymous
  • 919 Answers
  • Posted on Mar 23, 2009
There are many steps in installing Digital Wave Player on VISTA, it is important to follow every step since installing Digital Wave Player on VISTA is dependent on this process.
Install a VN recorder on VISTA
1. Make sure the device has been uninstalled in device manager
2. Make sure the old version of digital wave player is uninstalled.
{Delete Temp files in Internet Explorer --Tools--Internet Options --Delete Files-- Delete offline content--OK}
3. Install digital wave player (The newest Version).
http://www.olympusamerica.com/files/DigitalWavePlayer.zip
4. Install the 2.1.4 vista update
http://olympusamerica.com/cpg_section/software_results.asp?id=1291&os=w
5. Restart the computer.
6. Plug in the VN recorder to the USB port and turn the recorder on.
"Found new hardware" will appear,
7. install automatically.
This may fail, if you see VNUSB device, skip the final steps and proceed to Digital Wave Player to Download files from the Digital Voice Recorder.
If you will see "Other devices" listed in Device manager with "digital voice recorder" underneath it.
8. Right click on the "digital voice recorder"
9. Select update driver from the pop up menu.
10. Choose the browse computer Option
11. In the next window browse to the location that you downloaded the Digital Wave Player application to
12. Click Next
A security warning window will open,
13. Choose "install anyway" and the device will install.
When successfully installed you will see the "other devices" disappear and a VNUSB device with a "VN series device"
underneath it appear at the bottom of the device manager list. There will be a blue question mark next to the device. At this point you can close the device manager and the properties window and open Digital Wave Player. You will see the recorder listed underneath the recorder folder and be able to download and use the program normally now.
Anonymous
  • 919 Answers
SOURCE: Need driver: Windows for Olympus digital voice recorder VN-120PC
igital Wave Player (2.0):
After unzipping the file, click on the SETUP.EXE file to begin installation.
Download update: http://olympusamerica.com/files/DWPUP2EN.zip
Download update 2.1.3: http://olympusamerica.com/files/DWPUP4EN.zip
Do not have recorder connected until all software installed and then reboot computer. Once computer rebooted then connect the recorder.
I need to download a prograam for my laptop (drivers) to access mij Olympus digital voice recorder VN 1000 PC. Where can I get the driver and prograam to manage my recordings?
I have had good luck with Express Scribe, a free software package. Note that Olympus DSS format is proprietary and not all settings will work. The software from Olympus will of course work, but can be pricey. Express Scribe supports SP on most recorders. www.nch.com.au/scribe/index.html This company also has other products for playback and conversion to other formats, which maybe helpful to you.
I've purched the Olympus digital recorder VN-100 VN-2000 a few years ago. I've never really used it. But i recently need to..and for some reason it cant record. Everytime I push the REC button ,the red...
take out the batteries , push the reset button, then put batteries back and try again.
If still not working properly , then it probably should go back to Olympus, if you bought it a few years ago , its probably out of warranty.
You can buy a newer model like the vn-6200-pc , which has way more memory and more features for much much less then it will cost to repair the vn-100 or vn-2000 , f
I have a digital voice recorder vn 4100PC olympus how many hours I can record?
XHQ mode: Approximately 11 hours, 40 minutes
HQ mode: Approximately 23 hours, 40 minutes
SP mode: Approximately 47 hours, 20 minutes
LP mode: Approximately 144 hours, 20 minutes
1helpful
I recorded my professors lecture and the recorder was right next to her, when I listen back I can barely hear a thing all there is is her voice but muffled because it sounds like a loud wind
During Playback you can press + or - buttons to adjust the volume. Maybe this is your problem. If you need more info watch video instructions chapters for Olympus on http://www.HandBookLive.com under Electronics-> Audio. There are 20 different video chapters. The info about + - buttons for volume during playback was chapter 7 (Playback)
15helpful
Help! My Voice recorder is stuck in Slow playback/record
To switch back to normal press the PLAY button during
playback.
"Every time the PLAY button is pressed, the playback speed will switch."
32helpful
3answers
Top Olympus Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
Ngoro
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
