HDTV to DVD vcd CD MP3 player
SOURCE: Dish network
With the dish remote and do a code search as described in the remote manual and see if you can find it that way. If you go through the entire code search and none of them turn off the VCR/DVD combo, then there is nothing you can do, as those codes in the remote are all stored in the remote and they cannot be programed in. If you do not have a remote manual to set up the remote, to do a code search, simply go to the dishnetwork web site and search for it.
SOURCE: Oritron DVD 3116 Dvd Player
I have an oritron dvd3119 dvd player. I keep getting the message that "your selection is unrated and exceeds the player's rating limits." How do I fix this or get around it?
SOURCE: Oritron dvd 3119 player
You have to blindly instruct the NTSC/PAL menu item, which toggles between NTSC and PAL;
This is how it is done:
1) turn your dvd player off.
2) Turn it back on and make sure there is no DVD in the player tray.
This will ensure the menus are active
3) Using the remote, press the dowm menu selector key exactly three times
4) press the center menu select key once.
This will activate the display adjustement menu
5) press the down menu key exactly once.
This will activate the NTSC/PAL menu
6) press the center menu key
DONE.
The player should now have switched back to NTCS if it was in PAL.
IF it was in NTSC it should have switched back to PAL.
Note: If you still have the manual you can follow the menu tree blindly using the instructions in the manual. The above sequence is for activating the NTSC/PAL menu.
This player can also switch to progressive scan, which creates a similar problem. At least the progressive scan menu has enough warnings before it will actvate.
SOURCE: I need the code Magnavox MWD200F DVD Player.
The code for MAGNAVOX MWD200F is 447 (247 partially works). It had been tested in two Philips universal remote controls (CL015 and CL035A).
Greetings
CRENDON
SOURCE: my player doesn't play any
Failure of the Optical head assembly. You can try to clean the head lens eye as a last resort.
If not the optical head must be changed, get the same type model OE component.
If not familiar change the Head with the help of an expert as the procedure to remove the static proof, solder short must be removed.
