Question about Teac AG-V1050 Receiver
Lost audio sound on 1970's magnavox console stereo
2 Related Answers
Anonymous
SOURCE: no sound on early 70's magnavox stereo console
i have a 70's receiver ......well actually,,, my wife's from junior high days......acted the same as yours.........i took the cover off ....checked fuses.......3 amp.......glass type with silver ends.......1 was cooked......replaced it.........just like new.
Posted on Nov 02, 2009
larryforman5
SOURCE: Magnavox Console Stereo turntable does not turn at correct speed
I'm in Nashville, where can I have my 70"s Magnavox stereo console serviced to get bugs out of it as well as get new cartridges?
Posted on Aug 05, 2011
We have an Magnavox 26mf337B and we have no sound
A TV without sound is awful. So let's take some steps to see if we can get it up and running.
1) Check your input cables - if you're trying to watch something through another device (cable box/satellite box/dvd player ETC) make sure that the cables coming from it are inserted correctly into the TV. If the device has it's own seperate sound output (VOL controls) be sure they are turned at least midway UP.
2) Check the settings on your TV - Sometimes TV's have a setting where you can select audio output (speakers, 2.1 5.1, stereo, etc etc) Make sure you have it set to output sound to it's own speakers and adjust the volume to an audible level.
3) Check the audio OUTput on the TV itself - Connect the white and red (or in some cases black and red) RCA jacks to the audio input on a stereo receiver. See if sound comes out. If this is the case, you have either selected the wrong output on your TV's settings, or your Tv's speakers are dead.
Hope this helps you solve your issue!
May 11, 2011 | Astar Magnavox 26MF337B 26 in. HDTV LCD TV
PLAYSTATION3 HDMI TO PROJECTION THEATER SYSTEM AND SOUND SYSTEM
HDMI from PS3 to projector, then output audio from profector to stereo.
Jul 20, 2009 | Sony Playstation 3 (PS3) Console
Audio problem on my direct tv
Take it out of surround sound mode, some have enhanced sound in the audio portion of your menu. Put it to stereo.
May 17, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Picture but no sound
It is most likely the SAP setting is in place. This will kill the sound
To reset the audio, go to the on-screen menu and select the setting for audio and make sure it is on stereo rather than SAP (second audio channel).
toggle the two and see which is compatible to ur Dvd player
thank you
Apr 07, 2009 | Philips Magnavox 51MP392H Rear Projection...
No sound on early 70's magnavox stereo console
Mar 11, 2009 | Teac AG-V1050 Receiver
Magnavox Model 2P3602 - Turntable will not turn
This is a DIRECT DRIVE turntable (no belts) you are going to have to replace the drive motor (if you can find one!)
Please rate response!
thank you!
Jan 26, 2009 | Teac AG-V1050 Receiver
Nov 24, 2008 | Teac AG-V1050 Receiver
Philips magnavox model# 9p5040c102
Goto www.TvRepairKits.com and get their shrinking/expanding video repair kit. It works on the Philips sets.
Nov 12, 2007 | Philips Magnavox 51MP392H Rear Projection...
Philips Magnavox plama
check audio connection in stereo & tv carefully it has to run if it is connected properly. you can check with headphone so you will come to know that socket is ok also check for wire also.
Oct 05, 2007 | Philips Magnavox 27MS343S 27" TV
29 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
