Question about Roland VersaCAMM VP-540i
BLACK INK IS NOT PRINTING
THE BLACK INK ON MY VERSACAMM VP-540i IS NOT PRINTING, OTHER 3 COLORS IS PRINTING FINE
Posted by CHRIS CLOETE on
I have a roland sp-540v, trying to print on banner material with black backing. Keeps on getting message to setup sheet while everything is loaded correct. The sensor is probably not picking up black.
Could you try
(1) Temporarily stick a white strip over the sensor where it detects the media or
(2) On the length of the media or
(3) Even staple same sized white media below the black one which you can un-staple after printing.
kindly ignore if these are (s) tupid answers
Mar 23, 2016 | Roland VersaCAMM VP-540i
Black ink not working lexmark pro915
Check ink level, clean contacts on cartridge and machine.
Oct 10, 2013 | Lexmark Pro915 Wireless All-in-One Inkjet...
My roland vp-540 will start printing and then when busy printing it will just stop, if you go into your versawork on computer it just says not connected? What could be the problem?
Just one Question?
Do you have your LAN Cable tied with your AC power Cable?
I have th same problem on two VP540 after seven years of trouble free working. A few months ago I was reorganizing my shop and I tied up both cables to avoid tangle cables with machine wheels every time I move It.
I think that the noise produced by AC Voltage Affect the VP540 ethernet port.
Aug 14, 2012 | Roland VersaCAMM VP-540i
My Printer prints a Colored Ink. But I type as a black Font Color.Then Black Ink Has full?? pls help me
Hi Carl Montero,
Your issue may be attributed to two possible points of failure. 1.) The Nozzle is clogged, 2.) the ink is already dry inside. You can try to clean the nozzle by doing the following steps. If it does not work, try to replace the cartridge with a new one.
FINE Cartridge Cleaning
1 Press [Menu] repeatedly until appears. 2 Use [ ] or [ ] to select . 3 Press [OK]. 1 Press [Maintenance] repeatedly until appears. 2 Press [Black] or [Color].
FINE Cartridge Deep Cleaning
Note If deep FINE Cartridge cleaning does not improve the print quality, contact a Canon service representative.
Jul 13, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Won't print black
chack your balck cartridges may be it's finish just tak out seak that will fome to know is the ink of finish
relpace that it will work fine
May 10, 2010 | Brother MFC 490cw Color Inkjet...
My black ink printing all of a sudden stopped..ink in cart.all other colors work fine
All brother machine have a one year in parts and labor this machine have a print head problem.
Oct 05, 2009 | Brother MFC 210C All-In-One InkJet Printer
Black ink wont print, but color works fine
The black cartridge needs replacing it sounds like. On many printers, that is the only way that you get black.
Jul 05, 2009 | Dell Photo 964 All-In-One InkJet Printer
Wont print black
Change the black ink cartridge.
Jun 08, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Color prints too dark
1. Took out the color ink cart and clean the copper contacts of the ink cart with cotton swab, make sure that you do not touch the silver nozzle .
2. Try new ink color ink carts as someime this issue came up when the ink carts are about to finish up.
3. Replace the ink carts and do not us a refill ink.
Dec 26, 2007 | HP OfficeJet D135 All-In-One InkJet...
Roland VersaCAMM VP-540i Logo
283 people viewed this question
Top Roland Office Equipment & Supplies Experts
Ekse
Marvin
Marvin
Are you a Roland Office Equipment and Supply Expert? Answer questions, earn points and help others
