Question about Activision Virtual Villagers for Windows
CODE VUIRTAL VIULAGER 5
CODE
Posted by TAKI on
How can i drill a hole into my keepsafe wall safe to open it?
Keep the drill motor in the toolbox, you'll likely just ruin the safe.
Go here instead: https://www.sentrysafe.com/CustomerCare/Lost_Your_Combination
There are 3 possible ways to unlock and access
the safe:
1. Factory code
(Found on the first page of the factory guide) You can
always open the safe by entering the pre-set 5-digit
factory code. This code cannot be deleted.
2. User code
If you prefer to employ your own code, you can
program the safe to open using a 5-digit user code
of your choice.
3. User pin
If you wish to give someone else temporary access
to the safe, you can program a 5-digit user pin that
can later be erased.
Programming the user code
NOTE: One (1) user code is allowed.
To add:
1. Press the Prog key , then enter the 5-digit
factory code.
2. Enter the 5-digit user code of your choice.
To delete:
1. Press the Prog key.
2. Enter the 5-digit factory code twice.
Programming user pin
NOTE: One (1) user pin is allowed.
To add:
1. Press the Prog key 2 times.
2. Enter your 5-digit user code.
3. Enter the 5-digit user pin of your choice.
To delete:
3. Enter 0, 0, 0, 0, 0.
NOTE: If your safe does not appear to be working,
please check batteries before calling Sentry
Customer Care.
Jul 26, 2014 | Sentry KeepSafe Combination Fire Safe 12...
How to reset key pad on door
If you are looking to put your own code in then please do the following:
1. Select 5 digits that you wnt to put in 2. Enter the code that the dealership gave you (also on the decal on the right trunk hinge). 3. Within 5 seconds, press 1/2 4. Within 5 seconds of pressing 1/2, enter your personal code, pressing each digit within 5 seconds of the previous digit.
To erase your personal code, enter the original code, press 1/2 within 5 seconds, then wait 6 seconds. It will then resort back to the original code which cannot be erased.
Mar 20, 2011 | 1996 Lincoln Mark VIII
I would like to be able to lock the keypad with a code
If you will be the only user you can Changing the Lock Code and no body can enter in the system once you make the change.So don,t share the code with anybody.
Your SX5T is preconfigured with a lock code for use in entering Configuration Mode and to use
with the Call Barring feature. The default lock code is the last four digits of the phone number.
(If no number is programmed, the default is 0000).
You may use Configuration Mode to change your lock code to any 4-digit number.
To change the Lock Code:
• From Configuration Mode, press: # * 1 4 3 *
For example, to change the default lock code from 0000 to 5555, press
# * 1 4 3 * 0 0 0 0 * 5 5 5 5 * 5 5 5 5 #
Dec 01, 2010 | Verizon Communications Telular CDMA Dual...
How do I change the code for key less entery on the key pad on door
Programming a personal entry code The factory set code cannot be reprogrammed but you can create your own 5 digit personal entry code. When pressing the controls on the keypad, press the middle of the controls to ensure a good activation.
Up to three personal entry codes may be programmed to the vehicle. To create your own personal entry code:
  • 1. Enter the factory set code.
  • 2. Within five seconds press the 1-2 on the keypad.
  • 3. Enter your personal 5-digit code. Each number must be entered within five seconds of each other.
  • 4. Press 1-2, 3-4 or 5-6 to indicate which of the three personal entry code positions you wish to use.
  • 5. The doors will again lock then unlock to confirm that your personal key code has been programmed to the module.
Tips:
  • Do not set a code that uses five of the same number.
  • Do not use five numbers in sequential order.
  • The factory set code will work even if you have set your own personal code.
  • If you program a code to a position that already contains a set code, the previously-set code will be erased.
Erasing personal code
  • 1. Enter the factory set 5 digit code.
  • 2. Within five seconds, press the 1-2 on the keypad and release.
  • 3. Press and hold the 1- 2 for two seconds. This must be done within five seconds of completing Step 2.
All personal codes are now erased and only the factory set 5 digit code will work.
Good luck (remember commend and rated this).
May 03, 2010 | 1996 Ford Explorer
I BOUGHT A 95 LINCOLN CONTININTAL USED AND I DO NOT KNOW WHAT THE CODE IS ON THE DOOR KEYPAD AND I WOULD LIKE TO RESET THE CODE HOW DO I CHANGE IT WITHOUT KNOWING WHAT THE OLD CODE WAS.
The factoty code is found in the trunk on the right side lift support. The factory code can never be deleted. To reset and delete any added codes, key in the 5 digit factory code. Within 5 seconds press the 1/2 button. Within 5 seconds again press the 1/2 button again. All previously added codes are delete. To add your own code, key in the 5 digit factory code. Within 5 seconds press te 1/2 button. Within 5 seconds again enter your personal 5 digit code. Note that when you complete these steps, the doors will lock then unlock meaning that the command to add or delete a code is complete. You can add 5 different codes in the memory, but when you complete the delete command, it deletes all added codes but never the factory code.
Feb 23, 2010 | 1995 Lincoln Continental
I need help I changed the key door code on my 1996 Lincoln
1. Enter the original factory code, 2. within 5 seconds, press1/2 3. within 5 seconds enter your chosen new 5 digit code, pressing each digit within 5 seconds of the previous. 4. all of the doors will lock and then unlock to confirm programming of the new code. you can now use either factory or this new code. 6. To erase all of the personal entry codes and remote transmitters programmed - 1. Enter the factory code 2. press 1/2 within 5 seconds 3. press and hold 1/2 for two seconds
May 08, 2009 | 1996 Lincoln Town Car
Door key pad, won't unlock door
  1. Enter the permanent factory remote keyless entry (RKE) keypad code.
  1. Press the 1/2 button within 5 seconds to activate the programming mode associated with the memory position 1 settings. Holding the 1/2 button for more than 2 seconds after activation erases the stored personal code.
  1. Within 5 seconds, enter the new 5-digit RKE keypad code. The door locks lock and unlock to confirm the new code is programmed and associated with the memory position 1 settings. Entering any new personal code automatically erases the old personal code.
  1. Press the 3/4 button within 5 seconds to activate the programming mode associated with the memory position 2 settings. Holding the 3/4 button for more than 2 seconds after activation erases the stored personal code.
  1. Within 5 seconds, enter the new 5-digit RKE keypad code. The door locks lock and unlock to confirm the new code is programmed and associated with the memory position 2 settings. Entering any new personal code automatically erases the old personal code.
  1. Press the 5/6, 7/8, 9/0, 7/8 and 9/0 button within 5 seconds to activate the programming mode or allow the system to timeout.
  1. Within 5 seconds, enter the new 5-digit RKE keypad code. The door locks lock and unlock to confirm the new code is programmed. Entering any new personal code automatically erases the old personal code.
Jan 23, 2009 | 2005 Ford Freestyle
Keyless entry keypad
retrieving is probably not an option however if you know the factory code , you can add 1 personal code which in turn would erase any other personal codes . your owners manual should back this statement up . follow these steps >>>>>
The keyless entry touch pad can use two codes. The factory code and one
personal code .
To program your own personal code, select a 5 digit code that doesn't use 5 digits in
sequence or the same button 5 times.
Enter your factory code
Within 5 seconds of pressing the 1/2 button, enter your 5 digit personal code,
You can now use either code to operate the keypad
Jan 12, 2009 | 2003 Ford Expedition
I can't power on my mobile(Nokia 6708) because of startup security lock
Hi i can give you the master override code that gives you acess to the phone and resets the code to what it was when new usually 1234 or 12345 or 0000 depending on network but the code im giving you will only work with your imei number and will also only work if the code hasnt been entered wrong more than five times enter this code when you switch phone on and its asking for code.
If you have entered more than 5 goes at getting the code and you got it wrong more than 5 times then this code wont work and the only way to unlock it is using flash lead and unlocking software the problem with this is that alot of new nokias cant be reset after the code has been wrong 5 times they done this so stolen mobiles couldnt be used again.
Anyway here is the master override code you need
make sure you have given me right imei number but if you have the code for that imei number is 6 2 4 4 3 4 3 5 5 7
Let me know how you get on and also if you need further assistance ok
Feb 08, 2008 | Nokia 6708 Cellular Phone
Activision Virtual Villagers for Windows Logo
154 people viewed this question
Top Activision Video Game Consoles & Games Experts
Muntejaya Ginting
Muntejaya Ginting
ray gallant
Are you an Activision Video Game Console and Game Expert? Answer questions, earn points and help others
