Question about Home
Pearl bathtub Can my Pearl Luxury S4 Whirlpool Bathtub be retrofitted with an inline heater?
Posted by Judith Huff on
US Parts Center
  • 719 Answers
You can add an inline heater to any almost any jetted bathtub. Here is a link to site that sell all kinds of them.
Posted on Feb 26, 2014
5 Related Answers
Anonymous
SOURCE: Installing an Aqualux (Desiree) whirlpool bathtub
call the manufacturer Asteria Bath Company at1-800-288-4002 and they can send it to your email address.
Posted on Dec 05, 2008
Anonymous
  • 125 Answers
SOURCE: How do I install a whirlpool bathtub?
here is a link to the some installation and operating instructions.
basically you need to put a 2" x 2" runner under the lip of the tub along the three sides of the tub that touch the walls to support the lip of the tub. that pretty much covers it.
Posted on Feb 24, 2009
Anonymous
  • 63 Answers
SOURCE: bathtub whirlpool leaks. problem is that the tub
Stop leak in a bottle absolutely does not work, look closely there should be some sort of access panel (maybe well hidden) to get under there.
Posted on Mar 24, 2009
Joe Hogan
  • 10865 Answers
SOURCE: Maax bathtub Palace model Error code C01 jets don't turn on.
first of all check the circuit breakers to be sure one or both aren't kicked. be sure to turn the breaker all the way off and then fully on as a tripped breaker is in a halfway off position. if that doesnt fix your problem remove the access panel to the mechanical space in your tub. there are generally one or two reset buttons in there which can also kick off and need to be reset.
Posted on Sep 01, 2009
Alan
  • 80 Answers
SOURCE: Bathtub Whirlpool button isn't working when pushed
It sounds like a bad air switch. This switch is located on the pump/motor, and is usually found at the end of a clear piece of tubing going to a box on the pump/motor, the other end of the tubing is connected to the push button on the tub. The replacement switches are avaliable through online parts companies. The best thing is to pull the pump and open the box with the switch in it. I have replaced the switch without pulling the pump/motor, but it is difficult and requires plenty of room. If you are not comfortable with doing this repair, call a reputable spa repair company.
Posted on Sep 06, 2009
Can Jacuzzi Rapid Heat inline heater be installed upside down?
You do not want to install any heater upside down because if any debris gets inside the heater pressure switch while it is running it will NOT shut off once the pump shuts off.
Rod
US Parts Center
888-521-6183
Feb 17, 2013 | Jacuzzi RapidHeat In-Line Heater U395000 [...
I need to know how to re program my tub , it seems to be stuck in the pause mode
Disconnect the power for a min or two and then turn it back on this should reset everything back to default. Then go through the setup instruction as if you were starting new. If that dosen't do it the control unit is faulty.
Jan 30, 2011 | Whirlpool Pearl Navarre 7242 True Bathtub...
I need new trim parts to change from gold to nickle on a pearl jetted tub model 143391-1 trim rings handle light cover..ect.
go to http://www.uspartscenter.com/shopbybathmfg.aspx you should be able to find the parts for your tub there.
Dec 16, 2010 | Whirlpool Pearl Navarre 7242 True Bathtub...
My pearl whirlpool bathtub has turned on mysteriously when no one is home and no water in the tub...only one years old! Is this a sensor problem? Motor problem? touch-pad control problem? Please help, I...
Sorry, didn't realize I would need to pay money for the answer. I will deal with Pearl bath on my own. Thanks for the help, please remove my email from your mailing list.
Nov 02, 2009 | Whirlpool Pearl Ballade True Bathtub with...
Parts for my pearl corner tub
any plumbing suply house would have it. good luck
Feb 18, 2009 | Whirlpool Pearl Navarre 7242 True Bathtub...
Broken back massage jet unable to purchase locally
Hi robrezza,
Here's the number the Pearl/maax Plant.
For maintenance, installation or general technical queries about your MAAX products, we encourage you to contact us at: Tel.: 1-888-957-7816 option # 2 Fax: 1-800-201-8308 (418) 387-9086
Have your tub model when you call. They usually are pretty helpful. Sometimes it goes to voice mail for the tech person but they call back after a bit
Please rate this response and Good Luck, Phil
Jan 18, 2009 | Whirlpool Pearl Ballade True Bathtub with...
Difference tubs and air baths
whirlpool tub has jets that circulate the water, where an air bath uses bubbles that rise gently from the bottom of the tub. Whirlpools are typically used for therapy, air baths are used for a much gentler experience. Air baths can be used with aromatherapy/essential oils. Both offer a spa-like experience.
Aug 27, 2008 | Whirlpool Pearl Ballade True Bathtub with...
Bath Operating Cost
No more than any other household major appliance. The motor, heater, and any other options are standard 110 volt so the average cost to operate your whirlpool is only pennies a day.
Aug 27, 2008 | Whirlpool Pearl Navarre 7242 True Bathtub...
Home Logo
134 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
