Question about Whirlpool 24 in. GU3200XTP Built-in Dishwasher
Ran reset, after reset finished hit start button and #2 appeared on display and sounds to be draining slowly, still water in tub, could this be the problem why it will not start? Could it be pump motor even though its pumping some of the water? Could it be obstruction in discharge hose? Or could it be actual electronic control panel? If you have any input it would be greatly appreciated
SOURCE: water won't discharge from tub
If the pump is not bad and drain hose is connected right. if connected to a garbage disposal make sure the plastic is knock out of drain hole. If still does not drain check voltages at drain pump. If under warranty service call should be free.
Posted on May 22, 2010
SOURCE: I ran a load of laundry in whirlpoo[ duet ht,
It is your mixer value that is malfunctioning.
Posted on May 06, 2011
Jul 09, 2018 | Whirlpool Dishwashers
Apr 01, 2013 | Whirlpool Cabrio WTW6800W Washer
May 22, 2011 | Canon MP830 All-In-One Printer
May 08, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Nov 02, 2010 | Fisher and Paykel IWL12 Top Load Washer
Aug 13, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Jun 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Apr 13, 2009 | Whirlpool LSN1000LW Top Load Washer
Mar 15, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Jan 06, 2008 | Maytag Neptune MDG5500AW Gas Dryer
137 people viewed this question
