Question about GE A730 Digital Camera
Where can i find the proprietary power adapter for My ge a730 digital camer?
Where can i find the proprietary power adapter for this camera ? I can't seem to find it on ebay
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • GE Master
  • 102,366 Answers
Proprietary? The GE A730 uses standard AA batteries. If you choose to use rechargeable batteries then you can charge them using any standard AA charger. Such chargers should be available at just about any department, electronics, or office-supply store.
Posted on Jan 13, 2014
3 Suggested Answers
Anonymous
SOURCE: my ge a730 digital camera
Try this...Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Posted on Jun 20, 2008
Anonymous
SOURCE: WHERE DO I GET DRIVERS FROM
WHERE DO IGET DRIVERS FOR GE A730 DIGITAL CAMERS .I LOST DRIVERS DISK
Posted on Jun 29, 2008
Anonymous
SOURCE: Driver and instructions to pull pics off camera
I have tried getting the driver from GE but after downloading it, it say this file cannot be opened (the ext. is .bin)
Posted on Oct 05, 2008
IS THERE A ELECTRIC PLUG FOR THIS CAMERA
Yes, Ebay sells one for about 10 to 12 dollars, it's called a AC to DC power adapter/charger. Enter your cameras model number in Ebay and scroll down until you see the adapter as they are a few sellers selling them.
Feb 28, 2015 | Canon PowerShot S5 IS Digital Camera
WERE DO I FIND A AC ADAPTER MODE
Check where the battery charger is connected
Jan 05, 2015 | Computers & Internet
I bought a power adapter for the camera, but it doesn't seem to work without batteries in the unit. If I use the batteries alone, I will eventually get a red blinking light at the back of the camera,...
Because the camera is what is technically known as 'Portable'and is designed to work purely from the internal battery. the Power Adapter merely charges the internal battery
May 08, 2017 | Kodak EasyShare C330 Digital Camera
Im after a bush ac power adaptor for a LCDS20TV011
You could get one from ebay , but they seem very expensive. http://cgi.ebay.co.uk/24V-AC-power-adapter-Bush-1LCD23TV022-LCD-TV-/360224352429?pt=Televisions&hash=item53df0b68ad#ht_2521wt_1094 (It does say make an offer)
Other models may use the same supply and its cheaper, You could check with the vendor if a cheaper one is suitable for the Bush, after all why pay more for the same thing. http://cgi.ebay.com.sg/24V-AC-power-supply-adapter-BenQ-FP231W-Q23W3-LCD-TV-/330393378073 You just need to make sure the current/wattage and the plug on the end are the same.
Jan 17, 2011 | Bush 24v Ac Power Adapter For Bush...
Power issues
Dell laptops use proprietary power supply adapters. Inside the adapter there is a communication device telling the laptop the power supply is a genuine dell product. Which in turn allows the battery to charge. Anyways it appears that your charger is having problems. You should probably try to locate one local (from friend or computer repair shop) to test. if you try a good one with no problems, then just get on Ebay and get you a genuine dell charger. they are about 40-60 dollars. Or try calling dell.
If trying a known good charger doesn't correct the issue, you could have broken solder pins on the power jack inside the laptop.
If this helps you solve you issue please rate my solution.
May 05, 2009 | Dell XPS M1730 Laptop
Power Adapter for X2Gen MW22U
It seems ebay also sells the 12 v power adapter as well Click on the link http://stores.ebay.com/LCDPAYLESS_LCD-monitor-Power-Supply_X_X2gen_W0QQcolZ4QQdirZ1QQfsubZ2783434QQftidZ2QQlnsZ1QQtZkm
Jan 22, 2009 | Computers & Internet
Trying to find a replacement mini pci wireless card
That jack is 4-pins of USB and 2-pins for 3.3 volts .  The card is somewhat proprietary. EBay WM168b  it was manufactured by Airvast Tech
Dec 28, 2008 | Averatec Computers & Internet
Video upload....
well, the connector that comes from the 2nd speaker goes into the speaker port in the back of the first speaker.
The wierd cord possibly fits into the 12v dc slot in the back.. and the other end would go to a power adapter..
Seems you are missing a power adapter,, like you said earlyer.
Basically you would need a standard power adapter which fits into the speaker.
You could get some universal power adapter for it like
http://cgi.ebay.com/UNIVERSAL-DIGITAL-AC-ADAPTER-ADJUSTABLE-VOLTAGE-NEW_W0QQitemZ150275118131QQcmdZViewItem?_trksid=p3286.m20.l1116
Or
something to this direction
http://cgi.ebay.com/UNIVERSAL-AC-TO-DC-POWER-SUPPLY-ADAPTOR-ADAPTER-CHARGER_W0QQitemZ230275174536QQcmdZViewItem?hash=item230275174536&_trksid=p3286.m14.l1318
If you want to make sure you get the right kind of power apdater
Try contacting jbl directly
http://www.jbl.com/home/product_support/JBL_contactus.aspx?ProdId=PLATINUM%20SERIES&ProdName=COMPAQ:%20Platinum%20Series
I was looking around ebay, found this
http://cgi.ebay.com/NEW-JBL-Platinum-Series-PC-Speakers_W0QQitemZ260266345340QQcmdZViewItem?hash=item260266345340&_trksid=p3286.m14.l1318
Theres the power adapter in the middle, I think the odd cord goes to the back of the first speaker and the other end would go to a power adapter.. try contacting jbl they should be able to get you what you need.
Seems you have everything else you need except for the power adapter.
Jul 26, 2008 | HP JBL Platinum Computer Speakers
GE A730 Digital Camera Logo
57 people viewed this question
Top GE Cameras Experts
Jeffrey Groves
Jeffrey Groves
Ekse
Jerry Greenberg
Jerry Greenberg
Are you a GE Camera Expert? Answer questions, earn points and help others
