Sony KP-41T65 41" Rear Projection Television Logo
Question about Sony KP-41T65 41" Rear Projection Television
My sony kp-41t65 standby light constantly blinks red with no picture
Ser#9517812
5 Related Answers
Anonymous
  • 4402 Answers
SOURCE: SONY KP-57HW40 TUNS OFF AND STANDBY LIGHT BLINKS 6 TIMES
6 blinks is usually associated with failure of the horizontal deflection amplifier - which shuts down the high voltage system as well.
The repair requires testing to determine the exact parts that have failed. There are, for example, a few hundred parts and a section of the Jungle IC chip involved. So, repairs could require something as simple as replacing some inexpensive passive components OR as complicated as replacing the jungle chip (very expensive).
most of the time it's the horz. transformer and transistor.
Posted on Dec 20, 2007
Anonymous
SOURCE: I have a Sony KP-61HS10 that will not turn on.....
hello read my comment on shadie333 i just posted the problem i had, my tv is a kdp65ws550 which is also the same as the kdp57ws550 and kdp51ws550 mine was doing the same thing... ours is fixed... please read it
Posted on Dec 17, 2008
Slinteriors
Sonny Berry
  • 8617 Answers
SOURCE: sony kp-51ws510 tv blinking light 6 flashes on timer/standby
6 blinks on your model means the +5V line is either overloaded or shorted on the A or B board. You can get replacement boards at the following link and they will assist you in determining which board of the two you actually may need.
http://servicemanuals.vstore.ca/
Posted on Mar 26, 2009
Anonymous
  • 10594 Answers
SOURCE: Sony KP-46WT520 Standby Blinks 10 Times
High voltage in TV got problem and thats why TV gives 10 time blink error code.
Qualified TV tech will fix it as its bit complicated fix.
Posted on Apr 15, 2009
Anonymous
  • 13 Answers
SOURCE: Sony wide screen projection tv model kp-57wv600.
I found this solution from SONY's website.
The STANDBY light will flash if an issue is detected within the television. This can sometimes be resolved by simply following the steps below to reset the television.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
I hope this helps.
Posted on Aug 05, 2009
1helpful
STANDBY TIMER IS A CONSTANT FLASHING
This older model the light should blink at turn on for 10-15 seconds before picture appears.
The set is checking for certain voltages and other things---if any are missing it will not come up.
This is like saying car will not start--the Battery? Or?
Someone would have to go inside and check voltages first and then check to see if horz or vertical drive etc.
May be too old a set as some parts for it no longer available.
4helpful
2answers
Sony KP-41T65
is there a cadence to the blinking timer light?
Kv40xbr800 standby flashes 7 times, sony 40" Hello. I hope some 1 can help. I've a 41" rear project Sony TV ModelKP-41T65. One day it just decides not to turn on. When you turn on thepower you hear the...
7 blinks on a sony indicate that high voltage has exceeded 33K and the set is going into safety shut down. Check your Horizontal and rgulator circuits. Something in those circuits are causing the increased voltage.Hope this helps let me know if I can help you further.
Sony KP-46S17
does the standby light blink?
Help
does the standby light blink? how many times
Top Sony Televison & Video Experts
Jaime Hernandez
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
