Question about Janome 1017 Mechanical Sewing Machine
Button holes foot
How do i fit buttonholer on to my janome 1017 machine
Posted by Carole Varley on
Badcat Besseya
    Novelist:
  • 268 Answers
Http://content.janome.com/userfiles/file/Inst%20Book%207318%20%28English%29.pdf See p. 22 You snap off whatever foot is currently on, and snap on the buttonhole foot, #J.
Posted on May 26, 2014
5 Related Answers
Anonymous
SOURCE: I keep getting the bl sound when trying to make automatic button
I'd forgotten to pull the little lever down that abuts onto the buttonhole foot! Simple!
Posted on Nov 29, 2008
Anonymous
SOURCE: Excell 11 Buttonhole Instructions
if you email me on [email protected] I can send you the scanned pages
Posted on Jun 25, 2009
Anonymous
  • 19 Answers
SOURCE: manual for Janome Harmony 2049 sewing machine
www.janomestuff.com answer it all
Posted on Sep 16, 2009
Zenqi
Paul Howell
  • 208 Answers
SOURCE: Not sure how to use the buttonhole foot J that
The buttonhole foot slides open so that you may insert the button which you are making a button hole for so that it may be sized correctly.
Slide open the foot, place the buttin on the spot and slide it closed.
Turn the pattern selector off and back on to the buttonhole pattern to reset. (Do this each time you make a buttonhole to reset)
Pull down the buttonhole lever located up and to the left of the needle bar. Pull it ALL THE WAY DOWN so that it will be tripped by the buttonhole foot as it moves.
Set the stitch width to about 4 or 4.5.
Set the stitch length to a very tight stitch (but usually slightly higher than the recommended marking)
Set the upper tension on 3.
Use an appropriate stabilizer. This is the key to a good buttonhole.
Lower the foot on the fabric, ensuring that the foot goes down without springing forward or back.
Make a few practice buttonholes, adjusting the width and length untill you get what you are looking for.
Posted on Jan 16, 2010
Eva Hack
  • 25 Answers
SOURCE: My Janome sewing machine has a buttonhole
Pull the BH (Buttonhole lever) down which is to the right of the needle bar.
Posted on Feb 11, 2010
I have a Janome 1017 can I lower the feed dog for freestyle embroidery?
According to this, your machine does not have that capability:
Janome 1017 Review
HOWEVER, when a machine's feed dogs do not drop, there is usually an accessory included with the machine that is a plate that covers the feed dogs so you can sew without the feed dogs moving your fabric.
Your owner's manual is probably the best source for this information.
Jun 07, 2018 | Janome Sewing Machines
HI WHAT FUNCTIONS DOES THE JANOME JFS 1817 COME WITH. CAN I DO BUTTON HOLES ETC
Even if your machine does not have the buttonhole function, you can still make nice buttonholes with a plain zig-zag machine.
Until Wednesday Calls How To Manual Machine Buttonholes
How to sew buttonhole with an old machine
Jul 13, 2017 | Janome Sewing Machines
Where can i get a presser foot for a Janome 1017
Sep 18, 2012 | Janome Harmony 1017 Sewing Machine
My janome DC 3050 keeps showing bl when i make a button hole
BL stands for buttonhole lever,, it's to the left side of the needle bar,,just pull it down when you want to make buttonholes & when your finished making buttonholes,, just gently push it back up
Sep 20, 2011 | Janome DC3050 Computerized Sewing Machine
Janome 3050 shows bl when i make button hole
bl stands for buttonhole lever--the buttonhole lever is to the left of the needle bar---pull the buttonhole lever down as far as it will go & when your done just push it back up
Janome 2030 QDC How to predict whether the buttonhole (24) will start forward or backward? I power off the machine and reselect stitch 24 and move the buttonhole presser foot to the start position every...
does it sew buttonholes both ways?
My Janome 6500 always buttonholes away from me, so when it starts, it sews the near bartack, then stitches backwards down the right hand side of the buttonhole. It then comes back with little straight stiches on other side and sews the zigzag backwards on the left side, then the far bar tack. I would have thought your Janome would do the same stitch sequence.
Jul 16, 2011 | Sewing Machines
What sort of cabinet do you currently have, and is a photo possible, .....
...have you measured the overall size of the "footprint" of your machine, and will it fit, some larger Janome's are larger than a "standard" size for the likes of a Horn Cabinet (see them here), although a larger insert is possible for certain models.........I think a little more info is needed for us to really be helpful.
Feb 09, 2008 | Janome 1017 Mechanical Sewing Machine
Janome 1017 Mechanical Sewing Machine Logo
73 people viewed this question
Top Janome Sewing Machines Experts
Colin Stickland
Colin Stickland
Paul Bade
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
