Question about Maytag Washing Machines
Washing machine starts agitating before fill
My Maytag washing machine acts like it starts in the middle of the fill cycle. it is supposed to fill, determine the load size then start agitating. instead the agitator starts right away and after the cycle is done the clothes are wet
Posted by anthony godinez on
  • anthony godinez
    anthony godinez Jan 25, 2014
    From the research I did on this problem, it was suggested the water level/ temperature control valve was bad. I bought a new one and replaced it today. That was the culprit. I looked on you tube for a video on how to replace and it was a five minute job. The part was $85 but can be found cheaper on the internet. While at the part store a guy heard the part I was asking for and immediately asked if I had a Maytag. Apparently this is a common problem with this line of washers. I also found out that this problem is caused by opening the lid after the cycle is started. Word to the wise, gather all your laundry then start the cycle. If you have something left over, leave it for the next load unless you have a stack of money lying around.
RonW
    Scholar:
    New Friend:
  • 111 Answers
Pressure switch stuck you can pop the hose off the switch and blow thru hose it may reset and fill correctly before agitation will eventually stick again.
Posted on Jan 17, 2014
5 Related Answers
prem mathew
  • 1294 Answers
SOURCE: clothes still damp to wet after spin cycle
You need to clean out your outlet filter; this needs to be done periodically - according to your usage. If this does not solve your problem check out your outlet pump. Plug off the wall first before you do the jobs. The machine will not drain water if the outlet is clogged. And rate me pl, if the solution has worked......
Posted on Dec 02, 2007
shaggyrat
Christophe Thompson
  • 1224 Answers
SOURCE: Series 70 prob: Recently started wrapping clothes around agitator
some fabrics are known to do that you have on wrong cycle setting there should be a setting for delicates and clothing and blankets and things when loaded to close to agitator will attract each other together so its wise when loading machine load in a circle leveled out till desired fullness away from agitator they shouldnt attract as much
Posted on May 07, 2008
Robert Siegel
  • 36 Answers
SOURCE: maytag washer won't fill or agitate; only spins on cycle
sounds like you have a blown fuse. I dont have a schematic so I dont kno where you have to look to find it
Posted on Jan 03, 2009
onthejob5130
onthethejob1
  • 640 Answers
SOURCE: wont agitate unless you move the agitator
defective motor,,,start whindin gone ,,,replace motor
Posted on Jan 18, 2009
Anonymous
  • 544 Answers
SOURCE: washer will not agitate or spin
HI,
you can view this site to have some ideas about your agitator problem.
http://sites.google.com/site/sublimeappliancerepair/washer-will-not-spin/agitator-woes
any further question let me know.
thanks,
Posted on Mar 29, 2009
Where is the pressure switch hose on Maytag Centennial MVWC6ESWW1 located?
Pressure switchnhoses are usually located off the bottom or lower half of the drum. It willnormally be about women diameter hose that connects to a plastic box with a few wires at one end, and the drum housing at the other
Jan 16, 2018 | Maytag Washing Machines
No agitation on extra rinse cycle on Maytag Washing Machine MAV8557AWW
The manufacturer may have found there was little or no advantage to having agitation in the second rinse cycle so omitted it.
Jan 08, 2014 | Maytag Ensignia MAV2757AWW Top Load Washer
I have a Maytag Centennial washer, model number MVWC6ESWW, when I start the machine, it immediately starts agitating and adding water simeltaneously. At the end of the cycle, the clothes are soaking wet,...
I had the same issue. When I started the machine it began agitating and then began to fill as if it is beginning the second rinse cycle - well I think it was.... SO, I threw in some towels and began the cycle at the second rinse part of the cycle. Low and behold, the next load started and finished just fine.
I hope this helps. This is just one of many issues with this machine, but luckily I haven't had to call the repairman yet! They all seem to revolve around the thing being out of sync.
May 01, 2011 | Maytag Centennial 3.2 cu. ft. SuperSize...
Machine fills up with water then when its suppose to agitate it just stops working will turn timer & push knob in & out & reset then it will work
How long do you let it sit after the water fills up, somtimes the timer will take a little extra time to get to the point that starts the agitation cycle.
When it dose this, without pulling the knob out, turn the disk on the timer clockwise 1 click and see if it starts up agitating, if it dose dont worry about it it is normal
Nov 09, 2009 | Maytag PAV2300 Top Load Washer
Washing machine begins the wash cycle going immediately to the agitate cycle, without filling up with water first.
water will not stop running into drum unless shut off at faucet does not happen all the time and wife can't find her rubber boots
Apr 26, 2009 | Washing Machines
Wont agitate unless you move the agitator
Jan 17, 2009 | Maytag PAV2300 Top Load Washer
Maytag washer won't fill or agitate; only spins on cycle
Dec 30, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Washing machine fills, but won't agitate
Lid switch if its a Maytag Alantis... You said you have a GE top load in the start of your problem and ended witha maytag?
Dec 18, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machines Logo
377 people viewed this question
Top Maytag Washing Machines Experts
Sheldon Dedek
Michael Thomas
Michael Thomas
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
