Question about Oregon Scientific Measuring Tools & Sensors
From first setup, I have not received signal from the remote sensor. The indicator light (1) is not lit. How is the Reset (4) activated and what with? In which of the three possible postions should the CHANNEL (5)be placed? Apart from not reciving a signal form the above unit, the main receiver station located indoors does appear to be operationg correctly. I have just inserted new battery so that is not the problem.
2 Related Answers
Steve
  • 3289 Answers
SOURCE: The outdoor temperature & hygrometer
Hi Walter,
I found this in the manual, simply pressing the RESET button won't start communication again. Try this:
Your main unit displays current, minimum, and
maximum temperature and humidity readings
collected by the remote sensor and main unit.
Outdoor data is collected and displayed every
40 seconds and indoor data is collected and
displayed every 10 seconds.
The red LED flashes whenever the sensor
transmits an RF signal to the receiver.
select sensor or use auto scan
• Press CHANNEL to switch between
sensors 1-3.
• To auto-scan between sensors, press and hold
CHANNEL for 2 seconds. Each sensor's data
will be displayed for 3 seconds. To end autoscan,
press CHANNEL or MEMORY.
• Press and hold CHANNEL and MEMORY
simultaneously to search for remote sensors.
resetting the system
The RESET buttons are located on the back of the
main unit and sensor. Use a pointed subject to
press RESET when you change the batteries and
whenever the system malfunctions.
Posted on Jul 13, 2011
Flying Dragon
SOURCE: I have a 433MHz cable
You have to push some buttons to tell the MAIN unit to scan, then put battery into the REMOTE, set channel, and hit reset through a little hole. And the MAIN should see it.
Posted on Sep 23, 2011
Tip
Genie Intellicode Remote Transmitter Programming Instructions
USE ONLY WITH SERIES II ELECTRONICS.<br /> Older Transmitters and Receivers will not work with these new electronics. There are no Security Code Switches inside the Door Operators, Transmitters and Receivers.<br /> <br /> <br /> To Program Receiver <br /> Step 2-1 Locate the Learn Code Button and Radio Signal Indicator on the Power Head Receiver of your Door Operator.<br /> <br /> Step 2-2 Press a Transmitter Button once within 30 seconds.<br /> <br /> Step 2-3 Press and release the Learn Code Button<br /> &bull; The Radio Signal Indicator will blink approximately 2 times per second.<br /> &bull; The Radio Signal Indicator stays lit - SOLID.<br /> <br /> Step 2-4 Press the same Transmitter Button within 30 seconds.<br /> &bull; Radio Signal Indicator will go out.<br /> <br /> NOTE: If a second Transmitter Code is not confirmed within 30 seconds or if a different Transmitter Code is sent, the Radio Signal Indicator will blink approximately 4 times per second, then programming will stop. If programming stops, repeat Steps 2-2 through 2-4.<br /> <br /> Step 2-5 Repeat Steps 2-2 through Step 2-4 for each Transmitter, Wireless Keypad or other access device to be learned.<br /> <br /> NOTE: A maximum of 7 Transmitter, Wireless Keypad and other access device Codes can be stored into Receiver Memory at one time. If a Transmitter becomes lost or if you want to delete a Transmitter, Wireless Keypad or other access device, proceed to ERASING ALL RECEIVER MEMORY.<br /> <br /> <span style="font-weight: bold;">Multi-Button Transmitters</span><br /> <br /> NOTE: Only ONE button of a Multi-Button Transmitter can be programmed into a single Receiver. The other buttons are to control other Door Operators.<br /> <br /> NOTE: If you are replacing a lost or stolen Transmitter:(1) Erase ALL Transmitter Codes from the Receiver memory. (2) Reprogram the Receiver with the remaining Transmitters Codes.<br /> <br /> <span style="font-weight: bold;">Erasing All Receiver Memory</span><br /> <br /> Step 4-1 Press and HOLD the Learn Code Button for 10 seconds or until Radio Signal Indicator goes out.<br /> <br /> <span style="font-weight: bold;">ALL Transmitter Codes are erased from Receiver memory.</span><br style="font-weight: bold;" /> <br /> Step 4-2 Reprogram the Receiver with the remaining Transmitter Codes (Repeat Steps 2-2 through 2-4).<br /> <br /> <span style="font-weight: bold;">Step 5-1 Battery replacement</span><br /> &bull; Slide Battery Cover off of Transmitter back.<br /> &bull; Replace with new batteries.<br /> &bull; Slide Battery Cover back on.<br /> <span style="font-weight: bold;"><br /> Step 5-2 Visor Clip installation</span><br /> &bull; Slide Visor Clip into back of transmitter until it snaps into<br /> place.
on Jun 21, 2011 | Genie Company IntelliCode GICT390-1BL...
Why can't I receive input from the outside sending unit?
Make sure that all the batteries are good!!
This procedure outlines the typical process to pair the sensor and base.
Base Station Battery Installation
·Remove the printed vinyl label from the LCD screen of the base station
·Position the remote sensor near the base station
·Open the battery compartment at the back of the base station and insert (2) AA batteries according to the polarity markings. Replace the battery compartment cover.
·Within a short time the RF signal icon (located to the left of the outdoor temperature channel indicator) will start flashing. This indicates that the base station is ready to pick up the RF outdoor temperature signal from the remote sensor. It will continue to flash for 3 minutes or until the signal from the remote sensor is detected.
Register the Remote Sensor
·Open the battery compartment at the back of the remote sensor and slide the channel selector switch to your desired channel. For the first remote you may select any channel, for additional remotes select any unused channel
·Insert (2) AAA batteries according to the polarity markings. Be sure to install the batteries in the remote within the time that the RF signal icon is flashing on the base station. 1541 WeatherGuide Wireless Weather Forecaster with Barometer
Jan 07, 2016 | Measuring Tools & Sensors
Lg 50pc3d plasma
Procedure is
Step 1: Turn on the device (VCR, DVD, TV, Satellite receiver etc.) you wish to program.
Step 2: Press and hold the "CODE SEARCH" or "SETUP" button on the remote until the indicator light turns on, then release.
Step 3: Press and release the button for the device you are programming (VCR, DVD, TV etc.). For AUX, press AUX button, then the device button you are assigning to AUX. The indicator light will blink then remain lit.
Step 4: Enter the three-digit or four-digit code (depending on your GE remote model) for your device using the number buttons. After your code is entered the indicator light will turn off.
Step 5: Aim the remote at the device you want to control and press the POWER button. Your device should turn off. If your equipment does not respond to the first code listed in the documentation, repeat steps with the next code. If the device responds correctly to other functions like Volume or Program up/down, no further programming is required.
If you can't find a working code for your device or your brand is not listed try the "Code Search" method described below.
The CODE SEARCH function
Step 1: Turn on the equipment you wish to program.
Step 2: Press and hold "CODE SEARCH" or "SETUP" until the light turns on, then release.
Step 3: Press and release the button for the device you are programming (VCR, DVD, TV etc.). The indicator light will blink once, then remain lit. For AUX, press AUX then the device button you are assigning to AUX.
Step 4: Press and release the "POWER" button until your device turns off. Wait at least two seconds between each time you press "POWER". Note that you may have to press "POWER" up to 250 times!
Step 5: When your device turns off press the "ENTER" or "SAVE" button. The indicator light will turn off. Check other functions to see if your code is correct.
Jul 07, 2013 | Universal Remote Control Televison & Video
I need to program an emerson tv/dvd with a vibe 4-in-1 VA-405 remote
Setup code for Emerson TV/DVD combo is: 0456
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Jul 04, 2012 | Televison & Video
How do I get the passcode to reset a samsung tv
Hello
Do the following steps first, and find whether you could unlock your TV or not. If can't, follow the rest.
Steps To Unlock A Samsung TV 1. Turn the power off.
2. On the remote, press Mute followed by 1, 8, 2, Power in sequence.
3. You should now see the service menu. To exit the Service Menu always select RESET.
Three digit universal remote code for Samsung are:-
004/ 005/ 009/ 015/ 104/ 105/ 106/ 109/ 133/ 172
Four Digit Universal remote code for Samsung are:-
0105 0077 0076 0109 0007 0009 0004 0005 0085 0172 0942 0358 0012 0015 0080 0104 0106
Direct Code Entry
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
Nov 20, 2010 | Samsung Televison & Video
I lost the codes for my reomote control i need to program my remote to my television
Hi! Try searching for your codes by following the steps below.
1. Turn on the device you wish to program.
2. Press and hold CODE SEARCH/SETUP until the INDICATOR LIGHT lights, then release.
3. Press and release the device button for the device you are programming (TV, VCR, DVD, etc.). The INDICATOR LIGHT will blink once then remain lit. For AUX, press AUX then the device button you are assigning to AUX.
4. Press and release POWER until your device turns off. Wait at least 2 seconds between each time you press POWER. Important: You may have to press POWER up to 250 times.
5. When your device turns off press the ENTER/SAVE button. The INDICATOR LIGHT will go off.
try searching for your codes by following the steps below.
I hope this helps.
Oct 12, 2010 | Universal Remote Control GE174Universal...
Reset bridge to different router without the disk.
Follow these steps :
•1
Reset the bridge. Accomplish this by manually disconnecting the power source from the wall or the back of the bridge. Leave it disconnected for 30 seconds to a minute so that the software contained therein can fully reset. Reconnect the bridge and wait two to three minutes until the network is back up and running again. In many cases, a simple reset can solve your network-related bridge problems.
•2
Ascertain whether there is network activity on your computers. Accomplish this by looking at the back of each computer at the network card. There should be two lights next to your Ethernet port--at least one of these lights should be completely lit without flickering. This indicates that the network card in the machine is operational and ready to receive a signal, eliminating that as a possible problem source.
•3
Move the bridge to a different location to determine whether interference is preventing the network computers from receiving a proper signal. If possible, relocate the bridge to the same room in which the computers are located and try to reset the connection again.
•4
Determine whether the bridge has failed altogether or whether the wireless signal from the bridge has failed. Accomplish this by physically connecting the computers to the wireless bridge through the use of Ethernet cables. If this restores network connectivity, you know that the only problem with the bridge is the wireless signal emission.
Oct 01, 2010 | Computers & Internet
I lost the code to the ge universal remote jc024
hi...
From this website you can get the for your remote
http://www.jascoproducts.com/support/universal-remote-codes.asp
follow the steps to set up the remote
Method 1
Step 1: Press and hold the "SETUP" button until the red indicator stays on, then release.
Step 2: Press and release the desired Mode button (VCR, TV etc.). The red indicator will blink, then stays lit.
Step 3: Enter the 4 digit code for your device. After a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes!
Step 4: With your device on, press "CHANNEL UP" or "CHANNEL DOWN." If the device responds, no further programming is required. If some buttons do not operate your device, try one of the other codes for your brand. Note, when all codes have been searched the red indicator flashes rapidly for 3 seconds.
Code Search instructions
If your device does not respond to any of the codes listed with your equipment, or your brand is not listed, try the following steps:
Step 1: Manually turn on the device to be controlled.
Step 2: Press and hold the "SETUP" button until the red indicator stays on, then release.
Step 3: Press and release the desired Mode button (VCR, TV etc.). The red indicator will blink once, then stays on.
Step 4: Press the "CHANNEL UP" button repeatedly until the device to be controlled changes channel. The red indicator will blink, then stays lit.
Step 5: Press and release "MUTE" button to install the code. The indicator light goes off.
Jul 20, 2010 | Universal Remote Control GE174Universal...
Lost remote control. have universal RCA and
i found that your brand is not listed RCA code list,
your G&E remote is good one and easy to detect code for your tv.
solution
using your GE remote :
1. Turn on the device(TV) you wish to program.
3. Press and release the device(TV) button for the device you are programming . The INDICATOR LIGHT will
using your RCA controller:
1. Press and hold CODE SEARCH until the INDICATOR LIGHT lights, then release CODE
SEARCH.
2. Press and release the device button for the device’s code you are retrieving (TV,VCR or
DBS•CABLE). The INDICATOR
Note: For AUX, press DVD•AUX
then the device button for the
code you are retrieving.
3. Press and release CODE SEARCH. The INDICATOR LIGHT will turn off.
4. Starting with 0 on the keypad,
press the number buttons in
order (0-9) until the
INDICATOR LIGHT blinks.
5. The number which causes the INDICATOR LIGHT to blink is the first digit of your code.
6. Repeat step 4 until you have retrieved all three numbers in code
i hope this will solve your problem
regards,
cseian
Apr 22, 2010 | Durabrand DWT2704 TV
Measuring Tools & Sensors Logo
276 people viewed this question
Top Oregon Scientific Measuring Tools & Sensors Experts
Marvin
Marvin
Lawrence Oravetz
Are you an Oregon Scientific Measuring Tool and Sensor Expert? Answer questions, earn points and help others
