Question about Haier 539490003 Air Conditioner
Error code E1
E:1 room temp. sensor fault. / indoor unit.
see more pls Air Conditioning Fault Codes
Posted on Jul 06, 2014
SOURCE: E1 error code
highly annoying issue error code E1. After hours
of fan operation, the error code E1 will appear on the seven segment
LED temperature display. This error code is intended as a reminder for
the user to clean the air filter. However, because the procedure
outlined in the user manual does not clear this error code as
indicated, and the appliance has a nonvolatile memory that cannot be
reset by simply unplugging it, the user of the appliance will become
mightily frustrated, standing in potentially sweltering heat watching
the appliance repeatedly shut down in the midst of operation with the
"E1" display flashing.
Believe it or not, that is what it does: if you unplug it to remove the
"E1" code from the display, and plug it back in and re-start it, it
will simply run for anywhere from a few minutes to a few hours, and
then merrily shut down again with the same flashing "E1" code.
So you will come home to a hot bedroom, living room, etc. unexpectedly,
and you will NOT be amused, as I was not.
Many people at this point, having put the manual under the canary or
some such, will simply return the unit and never buy another Sharp air
conditioner. But for the tech-savvy and search-adept, I offer the
following procedure to clear the nefarious E1 indication, and obtain
1. Power down the air conditioner using the "power" button on the front
panel.
2. Unplug the air conditioner from the wall socket.
3. Hold the front panel "power" button down and plug the air
conditioner in. Continue to hold the power button down as the machine
goes through a brief test sequence (fan & compressor each come on
briefly, etc). There is a "beep" sound at the end of the test sequence,
and the machine will be off. At this point, you can release the power
button.
4. Unplug the air conditioner.
5. Plug the air conditioner back in.
6. Congratulations! You should now be able to operate the air
conditioner normally for another 720 hours, but only if you followed
the instructions above EXACTLY.
_____________________________________________________
Was this solution helpful? Show your Appreciation by rating it.
Thanks for using fixya support..You have a wonderful day
Posted on Jun 05, 2008
SOURCE: E1 error code on air
I called haier about this error code. E1 indicates that a button on the control panel or the reomote is stuck. I was instructed to unplug the unit and push each button at least 5 times, one at a time. Plug the unit back in, and this fixed my problem with error E1 and the unit works fine.
Posted on Aug 07, 2008
May 08, 2018 | Heating & Cooling
Jul 01, 2016 | Washing Machines
Mar 07, 2016 | Washing Machines
Feb 14, 2016 | Sewing Machines
Dec 05, 2015 | Heating & Cooling
Aug 28, 2015 | Dishwashers
Mar 18, 2014 | Frigidaire 38-Bottle Two-Temperature Zone...
Jun 13, 2012 | SNK Klimaire KSWG012H113 Split System Air...
Dec 18, 2008 | Kenmore Elite HE4 Electric Dryer
Jul 15, 2008 | KitchenAid KEBC207 Electric Double Oven
926 people viewed this question
