Question about Sony VAIO FX150K Notebook
CMOS battery Sony Vaio PCG-4G1L
Where is the CMOS Battery located in a Sony Vaio PCG-4G1L Notebook so I can be changed?
Posted by Cheryl Finke on
Where is the BIOS CMOS battery located please
How to change the CMOS battery in your Desktop Computer
visit this and wish you BEST OF LUCK........MAY GOD BLESS YOU THANK YOU
Apr 04, 2015 | Computers & Internet
I want to clear CMOS
The CMOS is a block of static RAM that will lose its data if power is removed.
most newer laptops are using a small block of Flash RAM (perhaps a block of addresses within the Flash BIOS chip itself) or other type of EEPROM chip to store the password.
No amount of removing batteries and pressing power buttons will change it
http://esupport.sony.com/US/perl/model-documents.pl?mdl=PCG-3E2L
you might get some more information from the manual
hope this helps
Jul 24, 2012 | Sony VAIO Notebook
HAVE TRIED CHANGE THE CMOS BATTEWHAT CAN I DO NXTRY TO REMOVE BIOS PASSWORD BUT IT COUDNT WORK,?
Sony Vaio PCG and some Vaio VGN Series use the last 7 digits of the laptop serial number to calculate the bios master password. The serial number for a Sony Vaio is often located on the bottom of the laptop on a white sticker. The serial number may also be found by removing the battery and checking in the battery compartment. The link to unlockbiosrecovery.com below works on the following models:
PCG-C, PCG-F, PCG-GR, PCG-GRS, PCG-GRT, PCG-GRV, PCG-GRX, PCG-GRZ, PCG-N, PCG-NV205, PCG-QR, PCG-R, PCG-SR, PCG-SRX, PCG-TR, PCG-V, PCG-VX, PCG-X, PCG-Z, VGN-B, VGN-FS, VGN-S, VGN-T, VGN-TX1, VGN-X
I use http://www.unlockbiosrecovery.com/Unlock_Sony_Bios.php
For $20 they use the last 7 digits of the laptop serial number to calculate the bios master password and then email it to you in an hour. They guarantee it to work and you can call them if you have a question.
Sep 10, 2011 | Sony VAIO VGN-FS640W Notebook
I need sony pcg-4g1l notbook drivers
http://support.vaio.sony.eu/computing/vaio/index.aspx?l=en_GB&m=0
on this link front page put in the 2 numbers from ya lappy.on a white strip....
cheers
Apr 05, 2011 | Sony VAIO PCG-4G1L Laptop Charger...
How to reset bios password on sony vaio laptop?
Please open you vaio laptop from bellow instruction link.
http://www.insidemylaptop.com/how-take-apart-sony-vaio-vgn-sz-series-laptop/
Follow step 14
You can manege the idea about CMOS battery.
http://www.insidemylaptop.com/disassemble-sony-vaio-vgn-bx-series-laptop/
Follow step 11
But this is your actual model
http://www.insidemylaptop.com/?s=PCG-K33+PC+Notebook
Just remove the Cmos battery And wit 2 minutes again fit the battery .Your password will be soon reset.
Hope it will help you.
Dec 26, 2010 | Sony VAIO PCG-K33 Notebook
Cmos battery
open the case at back of your notebook you will see the motherboard, look for the battery just a size of a coin, thats the cmos battery and replace it with a new one.
Nov 08, 2009 | Sony VAIO PCG-K23 Notebook
Can anyone tell me where the cmos battery is on a Sony Vaio PCG-7
at the back there would a white strip containing some info. it would be sticked on battery . there would be 2 buttons. first slide lock and then slide release and its done
Oct 30, 2009 | Sony VAIO FX150K Notebook
Sony Vaio PCG-9J3M - where is the CMOS battery located?
You can find CMOS cell on motherbord chipset.
it is in back side of laptop.
Open back side of laptop then find motherbord chipset you can find 1 CMOS cell on motherbord chipset pull that CMOS cell for 15 minutes then all settings are defaults.
Aug 13, 2009 | Sony VAIO FX150K Notebook
CMOS battery
the cmos battery is under the palm rest of the viao....requires you to take off the keyboard and undo 2 screws holding the palmrest on....slide the palmrest off....battery is plugged into the touchpad circuit board
Dec 15, 2008 | Sony VAIO GR370 Notebook
Sony VAIO FX150K Notebook Logo
242 people viewed this question
Top Sony Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Michael Thomas
Michael Thomas
Muntejaya Ginting
Muntejaya Ginting
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
