If I plug the sat box directly to the projector video is fine. If I plug hdmi from sat box into the denon it kills the signal...any suggestions.
SOURCE: no HDMI video output from AVR-588 receiver to plasma TV ???
You can also use a digital coax cable (color orange) to go into coax 1 for DVD coax 2 for cable box. Just make sure to set the coax in input settings. The coax cables are a little cheaper than the optical cables and work just as well.
Posted on May 10, 2008
SOURCE: Mac Mini and Denon 3801
http://www.retrevo.com/samples/Denon-Receiver-manuals.html
Posted on Aug 09, 2008
SOURCE: HDMI XBOX360 Elite -"No Signal"
The connection order can be a key issue as to whether or not the HDMI
signals will pass through the system. For best results the receiver
should be turned on first, then the source device(s) and then the
display. The reason for this has to do with getting the equipment to
handshake properly for the HDCP protocol.
If HDMI video will not pass through your receiver, you may with to just connect the xbox using the component cables. Since component will pass through 720p and your TV is 1080i you should expect the same qualtiy and a more crisp picture.
Posted on Jan 06, 2009
SOURCE: No audio running TV through Denon AVR 1910
I had the same problem. You're not doing anything wrong. the thing is you can't (I don't know why but the owner manual says it) have sound going to your tv AND your HT speakers when you're using HDMI. You should try going to input setup, choose hdmi audio out to your TV instead of the speakers, and then run an optical cable from your satellite to your receiver, assigning it to the TV/Cable input.
Posted on Jan 20, 2010
SOURCE: Denon AVR 1610 hdmi to component video conversion missing?
hello i believe your problem is that you are trying to downconvert from hdmi to component connections and Denon receivers will not do that.
I have a 4310 and I know it will UPconvert from an analog signal to HDMI but won't do it the other way around.
you may have to use component inputs for all your equipment. You will also have to go into the receivers menu and designate which signal is being used for each component as it won't auto select between analog and digital signals when it comes to video.
hope that helps
Posted on Jan 25, 2010
Testimonial: "Thanks. Very helpful"
Nov 16, 2013 | Denon AVR-4800 Receiver
Jul 07, 2012 | Denon AVR-1312 5.1-Ch A/V Home Theater w/...
Mar 04, 2011 | Denon AVR588 Receiver
Oct 11, 2009 | Denon AVR588 Receiver
Oct 06, 2009 | Denon AVR-2308CI
Apr 14, 2009 | Denon AVR-3300 Receiver
Feb 25, 2009 | Audio Players & Recorders
Feb 08, 2009 | Denon AVR588 Receiver
Feb 01, 2009 | Denon AVR588 Receiver
Jan 02, 2009 | Denon AVR-3805 Receiver
46 people viewed this question
