Washing Machines Logo
S
STORMY Posted on Jan 12, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
PROGRAMM MODULE INDESIT WIA121UK AFTER FITTING NEW MODULE WHERE CAN I FIND THE PROGRAMMING DETAILS IS PROGRAMMED FROM THE FRONT BUTTONS AS THERE IS NO PORT ON THIS MACHINE THANKS STORMY
john
Level 2:
Prodigy:
An expert who has answered 500 questions.
  • Indesit Expert 517 Answers
  • Posted on Jan 13, 2014
 john
Indesit Expert
Level 2:
Prodigy:
Answers
517
Questions
Helped
134296
Points
901
It is best left to indesit to program parts will cost more then they can do it for
5 Related Answers
dazmaraz
Darren Moxam
  • 67 Answers
  • Posted on Jun 25, 2007
SOURCE: w134s silver indesit
the heater, sounds like its gone
Anonymous
  • 97 Answers
  • Posted on Nov 07, 2007
SOURCE: Indesit WE14UK front loading washing machine door locked
try turning the timer knob/programme selector dial round to a black dot, switch appliance off then back on again. the red light should flash once, then pause, then twice then pause then three times. the appliance should now be reset and your door should open, if not there could be a fault on the main pcb control unit.
hope this helps
kj
Anonymous
  • 139 Answers
  • Posted on Nov 21, 2007
SOURCE: washing machine
The knob keeps turning when you have a problem with the machine the most common problem with indesit is the pump. check to see if there is any thing in the filter compartmet located at the bottom on the front of the machine if so clean and replace.. THEN you will have to reset the knob. you do tis by turning the dial to one of the off position (the big black dot ). Then leave the door open and keep switching the machine on and off quickly from the button on the front of the machine untill you c the lights flicker rappidly.. once this happens the machine is reset and ready to wash ... p.s The pump can be one source for a problem... others include brushes on motor.....but most likely it will be the pump tell tell signs are water in the drum
Timon90
Timon Gr?nlund
  • 126 Answers
  • Posted on Jan 31, 2008
SOURCE: indesit W133 washing machine
Seems to be a defect doorlock.
Anonymous
  • 15935 Answers
  • Posted on Sep 15, 2010
SOURCE: the program dial keeps turning and turning, and the WM does not seem to start
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Where is the fob module located on 2006 chevy malibu
Why ? Fob not working ? You think changing the RCDLR - remote control door lock receiver will fix it ? Did you test using a professional scan tool ,view input data an DTC'S for that module ?
Transmitter Programming
Important: All transmitters that are to be recognized by the remote control door lock receiver (RCDLR) must be programmed in a single programming sequence. If the system is placed in program mode, all previously programmed transmitters will be erased upon receipt of the programming signal from the first transmitter.
Up to 4 transmitters can be programmed. Do not operate or program the transmitters in the vicinity of other vehicles that are in the keyless entry program mode. This prevents the programming of the transmitters to the incorrect vehicle. The order in which the transmitters are programmed is important. The first transmitter programmed will be transmitter #1, and the second transmitter programmed will be transmitter #2. Use care to program the transmitters correctly.
The scan tool must stay connected until all of the transmitters are programmed. All doors must be closed to perform this function.
Install CANDI module.
Install a scan tool.
Turn ON the ignition with the engine OFF.
With the scan tool, select Vehicle Control Systems.
Select Computer/Integrating Systems.
Select the proper engine size.
Select Module Setup.
Select Body Control Module (BCM).
Select Program Key Fobs.
Follow scan tool on screen instructions.
Remove the scan tool.
Exit the vehicle. Attempt to lock/unlock the doors to verify the programming.
Operate the transmitter functions in order to verify correct system operation.
Remote Control Door Lock Receiver (RCDLR) (Sedan)
Attached to the center of the rear package shelf support under the trim panel
tip
How to program Chrysler Remote Transmitter
A Chrysler Transponder Key once programmed into a one car cannot be programmed to work any other car.
The transponder code identification is learned by the Sentry Key Immobilizer Module during programming. The Sentry Key Immobilizer Module sends the "Secret Code" to the transponder key and is retained by the transponder key during programming. After programming of the transponder key identification to the Sentry Key Immobilizer Module and the Secret Code is exchanged, the Sentry Key Immobilizer Module will ask for the transponder identification and the Secret Code every time the key is turned to ON or START.
No Emergency "Start" procedures for Chrysler vehicles.
Chrysler Key Operation and Programming
Model: 300 Year: 2005 - 2008
Model: 300C Year: 2005 - 2007
Remote alarm / central locking
System Operation
  • Pressing key LOCK button activates alarm and central locking.
  • Pressing key UNLOCK button once deactivates alarm system and unlocks driver's door.
  • Pressing key UNLOCK button twice within 5 seconds deactivates alarm system and unlocks all doors and trunk.
  • Pressing trunk lid button twice opens trunk lid.
  • System will automatically lock all doors when vehicle is driven above 15 mph.
  • Additional functions can be set to respond to the transmitter.
Programming
When
  • Key transmitter added or replaced.
How
  • Key transmitter is programmed during immobilizer programming procedure.
Immobilizer
System Operation
  • Switch ignition ON.
  • Immobilizer warning lamp illuminates for approximately 3 seconds.
Programming
When
  • Keys added or replaced.
How:
NOTE: Two programmed key transmitters must be available for the following procedure to operate. If none available key transmitters can only be programmed using diagnostic equipment.
  • Insert first programmed key into ignition switch.
  • Switch ignition ON for at least 3 seconds but no longer than 15 seconds.
  • Turn ignition OFF and remove key.
  • Withing 15 seconds insert second programmed key into ignition switch and turn ignition ON.
  • After 10 seconds an acoustic signal will be heard and immobilizer warning lamp will flash.
  • Turn ignition OFF and remove second programmed key.
  • Within 60 seconds insert non programmed key into ignition switch and turn ignition ON.
  • After 10 seconds an acoustic signal will be heard and immobilizer warning lamp will illuminate for 3 seconds.
  • Switch ignition OFF.
  • Remove Key.
Check operation of programmed key transmitter.
Repeat procedure for additional key transmitters if required.
Model: 300M Year: 1999 - 2003
Model: Concorde Year: 1998 - 2003
Model: LHS Year: 1998 - 2001
Model: PT Cruiser Year: 2000 - 2005
System Operation
  • Pressing remote transmitter UNLOCK button once deactivates alarm system and unlocks driver's door only.
  • Pressing remote transmitter UNLOCK button twice within 5 seconds deactivates alarm system and unlocks all doors.
  • Alarm / Central locking functions can be altered using remote transmitter.
Programming
When
  • Remote transmitter added or replaced.
How:
NOTE: One programmed Remote transmitters must be available for the following procedure to operate.
  • Obtain all remote transmitters.
NOTE: Any existing remote transmitters not used during programming will become inoperative.
Using a programmed remote transmitter proceed as follows.
  • Press and hold remote transmitter UNLOCK button.
  • After holding the UNLOCK button for at least 4 seconds but no longer than 10 seconds, press remote transmitterPANIC button for at least 1 second and release both buttons.
  • Ensure acoustic signal is emitted indicating programming mode active.
  • Within 30 seconds carry out the following procedure for each remote transmitter (including previously programmed remote remote transmitter)
  • Press any button of each remote transmitter to be programmed.
  • Ensure acoustic signal is emitted after each remote transmitter operation.
  • Programming must be completed within 30 seconds.
  • Switch ignition OFF or wait 32 seconds to exit programming mode.
Ensure final acoustic signal is emitted.
Replacement remote transmitters can also be programmed using diagnostic equipment.
Immobilizer
System Operation
  • System arms after switching ignition OFF.
Programming
When
How
NOTE:Two programmed key transmitters must be available for the following procedure to operate.
  • Obtain all keys.
  • Using first programmed key turn ignition switch ON and wait 3 seconds, return to OFF position and remove key.
NOTE: First and second programmed key operations MUST be performed within 15 seconds.
  • Insert second programmed key and switch ignition ON.
  • Wait approximately 10 seconds.
  • Ensure immobilizer warning lamp begins to flash and an acoustic signal is emitted.
  • Switch ignition OFF and remove key.
  • Within 50 seconds, insert new key and switch ignition ON.
  • Ensure acoustic signal is emitted and immobilizer warning lamp remains illuminated for 3 secondsindicating programming completed.
For each additional key repeat procedure starting from the beginning.
Replacement keys can also be programmed using diagnostic equipment.
Automotive and Commercial Locksmith Chrysler Remote Control Programming...
on Mar 26, 2015 • Televison & Video
Ignition key programming
This can only be programmed by the dealer. Please return to your local dealer and they can program it in short order.
How do I program the module in an Indesit IWDC6125
indesit washing machines are only made to last just outside the guarentee period these days as the drums are sealed to stop you replacing the drum bearings. much better to buy a reconditioned Hotpoint wm62 they also wash much quicker than any new machine
Forumla for adding speed dial numbers
Personal speed (the 12 F buttons on the right) depend on whether you dial "9" to get an outside line. Then the buttons are programmed by pressing PROGRAM the button and dialint the speed dial number with a 9+ then STORE. System speed dial number sare programmed in SYSTEM programming 001 and they have "9" also in front of them.
Carl
2helpful
2answers
NEED TO REEPROGRAMING A REMOTE CONTROL FOR A MALIBU 1998 HOW '?
1. Make sure ignition is in the OFF position.
2. Locate the Programming Connector in the trunk (center of rear shelf). It is a plastic connector with
two wires leading up to it. The connector is not plugged into anything. You may have to pull back
trim to access the connector.
3. The programming connector should have two terminals. Connect both terminals with a suitable
jumper wire. The Keyless Entry Module will lock then unlock all the door lock motors once. Make
sure the terminals remain connected throughout the programming procedure.
4. Press and hold the LOCK and UNLOCK buttons on the transmitter simultaneously for at least 15
seconds or until the vehicle automatically locks and unlocks the door locks. Your new remote has
been accepted and all existing remote codes have been erased.
5. Repeat the previous step for each transmitter to be programmed. Do not remove jumper wire in
between programming of transmitters.
6. Remove the jumper wire from the Keyless Programming Connector.
1helpful
How to cancel drying?
Please press the reset switch which should be on the control panel or next to the loading door
5helpful
2answers
Chrysler PT Cruiser remote key fob how to program?
1. Insert the key into the ignition switch and turn the switch to the ON position.
2. Press and hold the Unlock button on the transmitter between four and ten seconds.
3. continue to hold the unlock button and press the Panic button. A chime will sound to indicate that the transmitter programming mode has been entered.
4. Press a button on all transmitters to be programmed to the system, including any previously programmed transmitters. A chime will sound when each transmitter has been programmed.
5. Turn the ignition switch off to exit the transmitter programming mode."
7helpful
Programming keyless remote for Neon 2004
There is a way to program a remote if there is already a valid remote. Unfortunatly if you don't have a valid remote the only way to get one programmed is at the dealership with their scan tool.
I have pasted directions for programming a remote if there is already a valid transmiter.
CUSTOMER PROGRAMMING For a customer to be able to program RKE transmitters themselves, at least one RKE transmitter must be programmed already. This procedure is to add additional transmitters. If all transmitters are lost, the DRB III® scan tool must be used to program the new transmitters.
  1. Insert the key into the ignition switch, and turn the ignition switch to the RUN position without starting the vehicle (allow chimes to stop).
  2. Using the RKE transmitter programmed to the RKE module, press and continuously hold down the UNLOCK button for 4-10 seconds.
  3. Within the 4-10 second time range, continue to hold the UNLOCK button and press the PANIC button. Both buttons may then be released. Upon the PANIC button being depressed, the message for customer programming mode will be transmitted to the RKE module.
  4. A chime will be heard to verify that the customer programming mode has been entered (allow 3 seconds to hear chimes).
  5. Press and release any button on each transmitter that is to be programmed to the RKE module, including any transmitters which were previously programmed to the RKE module (with a maximum of four possible). After each transmitter is successfully programmed, a chime will be heard to verify that successful programming of the transmitter has occurred.
  6. After thirty seconds, or upon the ignition switch being turned OFF, the RKE module will exit programming mode.
Fitting new module
just switch off the machine and re start the programming procedure again did you get the programme sheet with the module
Top Indesit Washing Machines Experts
ZJ Limited
ZJ Limited
xxxxxx xxx
Sean Wright
Sean Wright
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
